UN-baja-ing a 1960 Type 1: Build Thread
zwillisgosteli
zwillisgosteli is offline
PostPosted: Wed Jan 27, 2021 11:15 am    Post subject: Re: UN-baja-ing a 1960 Type 1 Reply with quote
Once the sheet metal work is all fixed we will be moving onto paint and painting.
I have a new wiring harness and headlights and taillights waiting.
TinCanFab
TinCanFab is offline
PostPosted: Wed Jan 27, 2021 11:44 am    Post subject: Re: UN-baja-ing a 1960 Type 1 Reply with quote
You can put one of those quick steer kits on the pitman arm to fix the tie rod angles
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
zwillisgosteli
PostPosted: Wed Jan 27, 2021 12:22 pm    Post subject: Re: UN-baja-ing a 1960 Type 1 Reply with quote
they should actually be flipped. I don't think my buddy knew the taper was reversed. We still have to finish up the chassis so I'll make sure I fix that before its driven at all.
zwillisgosteli
PostPosted: Wed Jan 27, 2021 12:32 pm    Post subject: Re: UN-baja-ing a 1960 Type 1 Reply with quote
Here is a few photos of where the previous owner cut the body for the Baja kit.
The other pictures show the body with a proper front and rear clip. Front clip is from a 65 so it has some more work to be done. Rear clip is from a 65 but we have sourced the proper H apron.
Before
After
Here is the rear clip when it arrived.
Last edited by zwillisgosteli on Thu Jan 28, 2021 10:39 am; edited 1 time in total
bad91teg
bad91teg is offline
PostPosted: Wed Jan 27, 2021 6:10 pm    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
you saved that bug . great job
zwillisgosteli
PostPosted: Wed Jan 27, 2021 6:28 pm    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
Thanks! It was in quite a bad place before. It has a long way to go still.
zwillisgosteli
PostPosted: Wed Jan 27, 2021 6:29 pm    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
The welds need to be cleaned up and a lot of finish work is still in process, but it is looking more like a complete car.
bk63rag
bk63rag is offline
PostPosted: Wed Jan 27, 2021 9:03 pm    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
Looking good ! That a big transfomation before and after .
63 rag under construction for 30 years and counting.
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Wed Jan 27, 2021 11:32 pm    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
Very impressed.. I've got to say, you're years ahead of every other thread that starts out "got a free baja bug i want to fix up'
Applause
Robert in Memphis
Engine rebuild thread
zwillisgosteli
PostPosted: Wed Jan 27, 2021 11:35 pm    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
Thanks for the kind words.
I'm still getting the hang of posting all the photos into the gallery then copying the link. I have a lot more photos to post. My buddy Corey is an iron worker so he's doing all the welding. That aside this is our first attempt at body work. It's a fun experience and it will be in better shape than it ever would be otherwise.
zwillisgosteli
PostPosted: Wed Jan 27, 2021 11:47 pm    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
We are building 2 different engines. I traded a bus engine for a couple bug engines. Here is a 40 horse power that is partially reassembled. We lapped the vales after we cleaned up the heads. We cleaned the pistons and honed the cylinders and installed all new gaskets. Its converted to a 12v alternator as you can see.
There is also a 1600 s/p in the works. I had a clutch kit laying around and bought a top end kit. Soon it will have all new gaskets, new top end, and a rebuild fuel pump and carb.
Some of the 40 hp parts cleaned up pretty nice.
There are a few finishing touches to put on the carb. It was rebuilt.
The fuel pump was rebuilt as well. A spacer was added between the intake and carb to accommodate the 12v alternator conversion.
Last edited by zwillisgosteli on Thu Jan 28, 2021 10:41 am; edited 4 times in total
zwillisgosteli
PostPosted: Wed Jan 27, 2021 11:48 pm    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
I'm recovering phots out of order. Here is an interior shot of the pans and heater channels in test fitting the body. You can see the replaced rear cross members Corey welded in as well. Stuff still needs to get cleaned up and finished but we are just working on getting rid of all the rust first. This also shows the replaced lower A-Pillar sections.
Has anyone located any interior pieces for lower the B pillars? You can see the rotted metal in the photo on the right side above the heater channel.
You can also see how the drivers seat track came a little crooked and will need to be fixed. I paid more to get pans that weren't the lowest quality, but next time I think I'll go German. All the other body panels I got are "top quality" many are from Denmark and I seem to have a lot better luck
Last edited by zwillisgosteli on Thu Jan 28, 2021 10:34 am; edited 2 times in total
zwillisgosteli
PostPosted: Wed Jan 27, 2021 11:52 pm    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
Decided to test out some "stained glass yellow" paint on the inside of some lenses that were laying around.
zwillisgosteli
PostPosted: Wed Jan 27, 2021 11:54 pm    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
Thanks. Lots more to come but it Lotts better on a weekly basis.
zwillisgosteli
PostPosted: Thu Jan 28, 2021 12:03 am    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
We dismantled a few engines and kept all the worthy parts.
This photo shows the valves numbered while were were rebuilding the heads.
Here is another shot of a cleaned up head
And some tin just after it was dry.
Last edited by zwillisgosteli on Thu Jan 28, 2021 12:20 am; edited 1 time in total
zwillisgosteli
PostPosted: Thu Jan 28, 2021 12:17 am    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
The doors turned out to be in decent shape compared to a lot of the metal on the body. a few small rust holes need to be patched towards the bottom.
The doors have paint stripper on them here to remove the cheap white paint job that was only applied to the outside.
zwillisgosteli
PostPosted: Thu Jan 28, 2021 12:26 am    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
The seats that came in the Baja were worn out high backs so we scored some era correct low backs. I also found some nice tweed seat covers on the classifieds here on the samba.
One seat frame will have to be cleaned up. The springs are in pretty goos shape and I'll have a foam kit on order soon.
Dibaltic
Dibaltic is offline
PostPosted: Thu Jan 28, 2021 7:30 am    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
You'll need to make those pieces or find good donor metal. I'm surprised no one is making that area yet since it always rusts there.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Thu Jan 28, 2021 8:42 am    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
It works ok, I used it on the outside of the lens (a set of foglights.) but it faded within a few months. Perhaps it will last longer when on the inside of the lens.
zwillisgosteli
PostPosted: Thu Jan 28, 2021 10:09 am    Post subject: Re: UN-baja-ing a 1960 Type 1: Build Thread Reply with quote
Thats what I figured. I fond them for an early convertible, but those pieces are way different and very expensive. Its just odd they aren't more readily available for a standard considering they make replacements for the metal panel on the opposite side (quarter panel) and below (heater channel) this piece.
Page 2 of 5
