VeeDubn Samba Member
Joined: May 31, 2019 Posts: 120 Location: Olympia, Washington
Posted: Tue Feb 16, 2021 1:20 am Post subject: Re: Graphics, stripes, paint schemes |
Posted: Tue Feb 16, 2021 8:31 am Post subject: Re: Graphics, stripes, paint schemes |
I really like this.
Again, not a T3, but if the curve of the graphics were slightly straighter, more like a hockey stick, I think they would be spectacular on a T3.
I saw this one on FB the other day.
_________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Californio Samba Member
Posted: Tue Feb 16, 2021 12:49 pm Post subject: Re: Graphics, stripes, paint schemes |
The question I have is where would you get any of these? Maybe something the usual vendors should stock as there's obviously a demand. |
danfromsyr Samba Member
Posted: Tue Feb 16, 2021 1:36 pm Post subject: Re: Graphics, stripes, paint schemes |
with a world full of vinyl graphics shops these days. just about anywhere.
would not be a good economic value for a vendor to stock and sell.
back in the 70s and 80s it was more a dealer specialty arrangement. and a few factory designs. _________________
Abscate wrote: |
Posted: Tue Feb 16, 2021 2:40 pm Post subject: Re: Graphics, stripes, paint schemes |
Not a biggie, I just thought someone out there might have these custom made for a Vanagon |
4Gears4Tires Samba Member
Posted: Tue Feb 16, 2021 2:45 pm Post subject: Re: Graphics, stripes, paint schemes |
It is not hard to make these types of graphics with a bit of practice. You'll need a vector program to make the graphics, a cut program, and a plotter.
Comes with cut software for under $300.
https://www.amazon.com/Cutter-Plotter-Cutting-Sign...amp;sr=8-5 _________________ '87 Syncro
bobhill8 Samba Member
joyfulpursuit Samba Member
Joined: January 23, 2021 Posts: 50 Location: Western Washington
Posted: Wed Feb 17, 2021 2:00 am Post subject: Re: Graphics, stripes, paint schemes |
I don't mean to thread hijack, but this seems to be the best spot to ask.
On the flip side, has anyone ever removed their 30+ year old stripes with success? I'm looking at a 1988 pastel white with an R2D2 looking 6 inch thick stripe going just above the rockers and personally cannot stand the look of it. I'm nervous of how bad it'll look removed, though, especially on pastel white. I hear removing stripes is very noticeable on pastel white, and it can turn slightly yellow when using a 3m wheel. Anyone have any luck? Should I steer clear of it if I can't deal with stripes? _________________ 📖 For God so loved the world that he gave his one and only Son, Jesus,
that whoever believes in him shall not perish but have eternal life - John 3:16
🚐 1987 Westy, EJ22 small car conversion
🚗 1991 e30 325i Sport MTech II coupe
📸 instagram.com/joyfilledpursuit |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5076 Location: denver
Posted: Wed Feb 17, 2021 6:23 am Post subject: Re: Graphics, stripes, paint schemes |
Same. Nice folks. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Wed Feb 17, 2021 7:58 am Post subject: Re: Graphics, stripes, paint schemes |
joyfulpursuit wrote: |
On the flip side, has anyone ever removed their 30+ year old stripes with success? I'm looking at a 1988 pastel white with an R2D2 looking 6 inch thick stripe going just above the rockers and personally cannot stand the look of it. I'm nervous of how bad it'll look removed, though, especially on pastel white. I hear removing stripes is very noticeable on pastel white, and it can turn slightly yellow when using a 3m wheel. Anyone have any luck? Should I steer clear of it if I can't deal with stripes? |
With vinyl that old you need to use a chemical that will rejuvenate the vinyl so that it will come out in larger areas than just chipping it away. I have had good success with CrystalTek Vinyl-Off.
https://www.amazon.com/CrystalTek-Vinyl-Off-Quart-...&psc=1
That said, 30yo vinyl is 30yo vinyl. That is going to be a tough task any way you slice it.
My recommendation (I worked as the designer in a sign shop fresh out of college and did a lot of vinyl removal):
1. Tape the van off, you want to protect the paint.
2. Soak it in Vinyl-Off. Rub/spread it across the vinyl. Maybe do this a few times.
3. Use a heat gun to further soften it.
4. Use a plastic scraper and your fingernails to try to lift larger sections off.
If it's still chipping and not lifting or if it's lifting paint, then use the 3M wheel. Realize that any method has the potential to really damage paint. After a few years, vinyl becomes awfully permanent. And if you have a respray, you can just go ahead and book that paint appointment now. _________________ '87 Syncro
Posted: Wed Feb 17, 2021 4:26 pm Post subject: Re: Graphics, stripes, paint schemes |
4Gears4Tires wrote: |
If it's still chipping and not lifting or if it's lifting paint, then use the 3M wheel. Realize that any method has the potential to really damage paint. After a few years, vinyl becomes awfully permanent. And if you have a respray, you can just go ahead and book that paint appointment now. |
Thanks for the tips. I greatly appreciate you taking the time to respond. The one caveat I'm nervous about is what it'd look like post-op. 30 years of unfaded paint will stand out as a stripe of its own. If it didn't have this darn stripe, I'd be buying this westy right now.
The van for reference: https://www.facebook.com/marketplace/item/27587537...ger_banner _________________ 📖 For God so loved the world that he gave his one and only Son, Jesus,
Posted: Wed Feb 17, 2021 4:30 pm Post subject: Re: Graphics, stripes, paint schemes |
If it is noticeable, a cut and polish on the van will really reduce it. And if its a single stage paint, it'll completely remove the difference between the two colors. I don't know if it is single stage, I'm sure someone else does. I would bet it is though.
I really wouldn't worry about the color difference at this point, I would worry about the vinyl pulling up chunks of paint. _________________ '87 Syncro
Posted: Thu Feb 18, 2021 11:44 am Post subject: Re: Graphics, stripes, paint schemes |
Abscate wrote: |
Posted: Sat Mar 06, 2021 2:36 pm Post subject: Re: Graphics, stripes, paint schemes |
I'll just drop this one in here
Abscate wrote: |
Posted: Sat Mar 06, 2021 2:43 pm Post subject: Re: Graphics, stripes, paint schemes |
Abscate wrote: |
Posted: Fri Mar 19, 2021 9:04 pm Post subject: Re: Graphics, stripes, paint schemes |
CL fresh, almost wall of shame worthy (imo)
Abscate wrote: |
jimf909 Samba Member
Posted: Fri Mar 19, 2021 11:38 pm Post subject: Re: Graphics, stripes, paint schemes |
The interesting thing with this van is that they hit it with the ugly stick everywhere but felt the torn oem upholstery was just fine as-is. I guess it really tied the van together.
_________________ - Jim
Abscate wrote: |
Posted: Mon Mar 29, 2021 8:49 pm Post subject: Re: Graphics, stripes, paint schemes |
Abscate wrote: |
Posted: Mon Mar 29, 2021 10:19 pm Post subject: Re: Graphics, stripes, paint schemes |
Two sweet early air cooled vans. What I like about the blue one is that the white rocker panels are the antithesis of the me-too bedliner trend making it 3x better.
Abscate wrote: |
