Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Apr 02, 2022 10:38 am Post subject: Re: The Green-Go, 65 Beetle build thread |
.035 would be near the edge. Most agree .040 is about the safe limit. Sure some people have definitely gone tighter and had no issues. I'm sure they were using good quality accurate parts, and employing good measuring skills. |
danhay Samba Member
Joined: January 13, 2006 Posts: 98 Location: Fort Worth, TX
Posted: Sat Apr 16, 2022 8:52 am Post subject: Re: The Green-Go, 65 Beetle build thread |
I've got the compression ratio, deck height issue sorted:
Installed CB 5.5 Rods, (it had 5.394s) Heads are getting fly cut to 58cc. With a .030 barrel shim, and a .040 copper head gasket, that will give me a .046 deck height, and 8.7:1 compression.
The machine shop is busy so I'll be waiting on the heads a while. So, I wired up the tach, oil temp and pressure gauges and ran wire to the engine bay for them.
I installed the Kennedy stage 1 clutch and pressure plate to keep things moving forward.
Anything else I can do to this engine while waiting on the heads?
danhay Samba Member
Posted: Mon Jun 06, 2022 7:58 pm Post subject: Re: The Green-Go, 65 Beetle build thread |
I got my heads back! He did a great job dialing in the chamber CC's, even unshrouded the valves for me.
If I remember correctly, static CR is 9.5:1 but the effective CR is in the neighborhood of 7.5:1. Should be a good pump gas motor.
Got the heads mocked up for rocker arm geometry, measured for pushrods and ordered Chrome Moly Rods from Smith Bros. pushrods. Yes, I could have cut them myself. But I don't trust myself.
I had to mock up the tins and exhaust.. not sure what to do next, fit up the tins I guess, they need a lot of clearancing around the Big Beef manifolds.
Posted: Mon Jun 06, 2022 9:41 pm Post subject: Re: The Green-Go, 65 Beetle build thread |
Looking good. Did you end up going with the copper head gaskets? I've never used them, but I believe they need to be annealed before use or they will leak. |
danhay Samba Member
Posted: Tue Jun 07, 2022 1:14 pm Post subject: Re: The Green-Go, 65 Beetle build thread |
Pruneman99 wrote: |
I did use them to get the deck height dialed in. With a .030 barrell shim I was at .006 deck height. The .040 copper gasket put me at .046 deck height.
I hadn't heard anything about annealing them... hmmm. I'll look into that. |
danhay Samba Member
Posted: Mon Jun 20, 2022 9:10 am Post subject: Re: The Green-Go, 65 Beetle build thread |
About ready to stab this thing in there, waiting on a few odds and ends to finish it up.
danhay Samba Member
Posted: Thu Jul 21, 2022 10:48 am Post subject: Re: The Green-Go, 65 Beetle build thread |
Anybody still reading this?
Got the motor stabbed in there, and even the decklid fits and closes! I thought sure with the big beef manifolds I'd have to run stan-offs. The passenger side air cleaner does hit the lid and bump it out a slight bit, but not enough to worry about.
What's left:
Make AN oil lines to external filter
Sort engine wiring and new gauges
Wire/mount electric fuel pump, relay and aux switch so I can shut it off separate from the ignition,
Spin the motor over without the rockers and plugs to get oil pressure,
Install rockers and plugs, first fire up with cam break in..
Decklid fits!
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2006 Location: Texas
Posted: Fri Jul 22, 2022 9:05 am Post subject: Re: The Green-Go, 65 Beetle build thread |
danhay wrote: |
Anybody still reading this? |
Still following along, admiring the progress _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
danhay Samba Member
Posted: Mon Aug 01, 2022 8:24 am Post subject: Re: The Green-Go, 65 Beetle build thread |
Well, It's almost time to spin this thing over and get oil pressure. I put in a battery and have been sussing out some wiring problems. In fact, I almost burnt the car down with a shorted out parking light wire. LOTS of smoke. I had to replace all the wires going to the LF headlight bucket. Turns out after much investigation that I had the wires reversed on the parking light bulb. When they are reversed, the headlight shorts to ground on the body.
I've got the fuel pump relay mounted, I need to wire that and then mount/plumb the fuel pump. Don't have any pics of all that, but I did push it outside so I could stand back and see the stance with the weight of the engine. Even though it could be lower in the front, I'm happy with it.
danhay Samba Member
Posted: Fri Aug 05, 2022 1:30 pm Post subject: Re: The Green-Go, 65 Beetle build thread |
I'm not proud of this fuel pump mounting situation, but I'm in "Just get it done" mode. I didn't want to bury it under the tank so at least it's serviceable in this location. Also, don't tell any thieves but I put a simple pull switch on the dash to cutoff the fuel pump relay. Anti-theft, as well as it's nice to be able to work on something with the key on, and not have the pump running.
I used a Painless fuel pump relay kit. I love Painless products, I've wired entire cars using their stuff and I highly recommend it.
slayer61 Samba Member
Posted: Fri Aug 05, 2022 1:55 pm Post subject: Re: The Green-Go, 65 Beetle build thread |
Dood, your car is badass. Keep up the good work! _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
danhay Samba Member
Posted: Fri Aug 05, 2022 2:54 pm Post subject: Re: The Green-Go, 65 Beetle build thread |
slayer61 wrote: |
Dood, your car is badass. Keep up the good work! |
Thanks man! |
danhay Samba Member
Posted: Wed Aug 10, 2022 6:56 pm Post subject: Re: The Green-Go, 65 Beetle build thread |
Cool! Sounds good. Don't let the kids scratch up that beautiful car with their handlebars! |
danhay Samba Member
Posted: Thu Aug 11, 2022 12:47 pm Post subject: Re: The Green-Go, 65 Beetle build thread |
Pruneman99 wrote: |
They won't hurt it, this car is not nearly as nice as it looks.
Maiden voyage video!
https://youtu.be/n8Ig9FfpGRM |
Posted: Thu Aug 11, 2022 12:57 pm Post subject: Re: The Green-Go, 65 Beetle build thread |
Little issues like the linkage always needs a bit of adjustment. I'm sure you will have a few shakedown runs before you get everything dialed in. |
danhay Samba Member
Posted: Mon Aug 15, 2022 11:55 am Post subject: Re: The Green-Go, 65 Beetle build thread |
This thing is a rocket! I haven't driven any other high-performance VWs... my 66 I had 17 years ago was a 1600 dual port so I don't have much to compare it to but dang...
I stood on it in first, bang shifted 2nd and 3rd and pretty sure broke the tires loose on the shifts.. was up to 70 before I could blink!
This thing really likes high RPMS!
One problem: It has 2 different front fenders on it, as evidenced by the different placement of the turn signal. The other problem is the driver's wheel opening is smaller than the passenger..
So when I braked hard to slow it down the driver front tire was rubbing the outer lip of the fender. I realized the little bit of fender gap get's smaller when my fat butt gets in, and I haven't driven it with a passenger yet.
I wanted to avoid this, but it looks like a narrowed beam is in my future.... |
Posted: Mon Aug 15, 2022 1:25 pm Post subject: Re: The Green-Go, 65 Beetle build thread |
We await the in-car video of you ripping through the gears! |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3328 Location: 802 The Pointless Forrest
Posted: Tue Aug 16, 2022 9:26 am Post subject: Re: The Green-Go, 65 Beetle build thread |
Try rolling the fenders with a baseball bat. _________________ "Albatross"! |
