Kthomas Samba Member
Joined: January 23, 2021 Posts: 254 Location: North Carolina
Posted: Thu Apr 01, 2021 2:25 pm Post subject: Re: Engine decisions for 60 beetle |
After getting different tubes - painted, shimmed and installing
Posted: Thu Apr 01, 2021 2:28 pm Post subject: Re: Engine decisions for 60 beetle |
As per the original post title. Engine is a 1600.Will need complete top end. Will rebuild stock. I’m not sure if the fan shroud is correct.
Posted: Thu Apr 01, 2021 2:30 pm Post subject: Re: Engine decisions for 60 beetle |
Started painting one piece at a time . Indigo blue. I think I’m just going to keep it simple with single color rims
Posted: Thu Apr 01, 2021 2:37 pm Post subject: Re: Engine decisions for 60 beetle |
Went to remove shift rod coupling and the set screw broke off so I cut it off. Once I got the rod out I noticed it was bent in three places. I didn’t realize it was suppose to be bent to clear the e brake . I proceeded to bend it straight before I got around to researching it.
How many bends should it have ? Maybe I should just get another.
Also. there wasn’t even a shift rod bushing left. Just running straight in the bracket.
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Thu Apr 01, 2021 3:24 pm Post subject: Re: Engine decisions for 60 beetle |
Kthomas wrote: |
Also. there wasn’t even a shift rod bushing left. Just running straight in the bracket. |
The plastic shift rod bushing wasn't introduced until VIN 3 140 046 in June of 1960, so unless your car is a late production '60 model it never had a bushing. Previously there was only a metal leaf spring in the shift rod hangar. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Thu Apr 01, 2021 5:04 pm Post subject: Re: Engine decisions for 60 beetle |
I’ll have to look at my body serial again. It has a non split transmission which as far as I can tell by that serial came out in 60. The hanger looks like it is supposed to have a bushing but maybe not. |
Posted: Thu Apr 01, 2021 5:05 pm Post subject: Re: Engine decisions for 60 beetle |
Do you know if there was more than one bend in the shift rod ? |
mukluk Samba Member
Posted: Fri Apr 02, 2021 1:37 pm Post subject: Re: Engine decisions for 60 beetle |
My bug was made between December of 59 and January of 60 |
Posted: Fri Apr 02, 2021 1:47 pm Post subject: Re: Engine decisions for 60 beetle |
Posted: Thu Apr 15, 2021 12:58 pm Post subject: Re: Engine decisions for 60 beetle |
Pan has wheels again
Posted: Sun Apr 18, 2021 8:49 am Post subject: Re: Engine decisions for 60 beetle |
Anyone had any experience with this kit for a stock 1600 ?
Posted: Sun Apr 18, 2021 8:54 am Post subject: Re: Engine decisions for 60 beetle |
Anyone know what this color scheme might have been ? I know it’s faded and dirty but ? It came out of this 60 and I think it’s original. Is this what they call basketweave ? Looks like the backrest is a different pattern fron the seat. Is that the way it would have been.
Someone put high back seats in the front so I’m not sure what they would have been . Would they have been the same as the rear ?
Thanks
Posted: Mon Apr 19, 2021 1:47 pm Post subject: Re: Engine decisions for 60 beetle |
Could this be steel grey with another color or ? |
Posted: Wed Apr 21, 2021 3:53 pm Post subject: Re: Engine decisions for 60 beetle |
Stripping low back seats for sandblasting and paint.
What a mess !
mukluk Samba Member
Posted: Wed Apr 21, 2021 10:05 pm Post subject: Re: Engine decisions for 60 beetle |
Kthomas wrote: |
Thanks |
Basketweave vinyl didn't appear until the 1965 model year, prior to that smooth vinyl or cloth seats were used so what you have there is not original. The striped cloth cord material that can be seen, however, may actually be original. Front and rear seat material matched from the factory, they didn't mix and match material types or colours/patterns.
https://www.thesamba.com/vw/archives/lit/8_59_color_book.php _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Thu Apr 22, 2021 12:04 pm Post subject: Re: Engine decisions for 60 beetle |
Looks like I have two passenger seats ? I hope I can modify one
Posted: Wed Apr 28, 2021 5:16 am Post subject: Re: Engine decisions for 60 beetle |
Painted seat frames and misc with Stone beige spray bombs. A couple observations are : paint hardly covers itself . One coat started acting weird and started getting tiny bubbles which may have been from application in sun or too heavy a coat or ? Not a big deal and didn’t occur everywhere. Just lightly sanded with 1200 and lightly hit it again. Will trey clear coat today as it isn’t very shiny.
Also decided ( since no one gave their opinions on cheap Chinese top end kit . ) to use the stock German heads I have and just rebuild them. I also ordered the 1641 AA piston and cylinder set . I installed several helicoils into heads as there were some broken studs.
Posted: Wed Apr 28, 2021 5:19 am Post subject: Re: Engine decisions for 60 beetle |
One step forward and one back. I got the seat frames painted and one rear bumped my stand while I was moving it and cracked at a joint . I had to weld and repaint. I’m glad it showed up now as opposed to when I installed seat cover. |
Posted: Wed Apr 28, 2021 8:44 am Post subject: Re: Engine decisions for 60 beetle |
Thanks Mukluk for the seat material clarification. I didn’t realize there wasn’t any basketweave in 60. This car had a mix and unmatched set of seats. The fronts were blue high backs. |
