Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 977 Location: Seattle, Wa
Posted: Wed Jan 27, 2021 2:11 pm Post subject: Oddball 73 D-Jet airfilter |
Another hard to find item. Thought id ask for opinions before I do too much research. Anybody found one that can be used on the stock housings? Luckily when time comes to run this engine I can use this one... but to replace down the road. The one pictured is a direct stock replacement that was purchased in the 80s.
Bill
raygreenwood Samba Member
Posted: Wed Jan 27, 2021 4:22 pm Post subject: Re: Oddball 73 D-Jet airfilter |
Not just hard to find. Unobtanium....except for NOS....which is rare. I will post my part number list for about 6-8 brands.
All quit producing them around 1999. One thing i have been threatening to do.....is to make a quick cheap cast/mold for the two rubber end caps.....which are plastisol.....yes....same material as Tee shirt ink.....and just casting caps to use with filter strips. I could cut ip a strip of my golf mk 6 filter and it would work perfectly.
Ray |
Posted: Wed Jan 27, 2021 9:46 pm Post subject: Re: Oddball 73 D-Jet airfilter |
Ray,
Man, you are the wizard! I dont know where you get the time to respond in depth to so many topics... with so many great possibilities.
Thanks again,
Bill |
Posted: Thu Jan 28, 2021 7:54 am Post subject: Re: Oddball 73 D-Jet airfilter |
....70% of that answer I have already given before.....so I went to my cheat sheet witj links to all of my useful thread topics......and copied the copy. Pasted the guts into this thread and then did a new google search on part numbers.
Ray |
Posted: Mon Mar 29, 2021 6:34 pm Post subject: Re: Oddball 73 D-Jet airfilter |
So I just came across a 914 1.7 air filter from AutoAtlanta. If it is the same filter that is used on my 73 1.7 that would be a good thing. The price is very reasonable. Anybody know for sure?
Bill |
