rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
owokie Samba Member
Posted: Sat Apr 17, 2021 1:12 pm Post subject: Re: Lieutenant Van a VWLT build |
So, are you running/driving this thing around yet or is it still at Delong's shop? What do you have planned for the interior? |
rmcd Samba Member
Posted: Sat Apr 17, 2021 2:23 pm Post subject: Re: Lieutenant Van a VWLT build |
I put about 1000 miles on it. Chris’s shop did radiator and some other R&R stuff in preparation for driving it down to Mexico to get bodywork paint and mechanical stuff.
In what can only be described as a tribute to the D 24 engine it made it to Mexico without any problems 2000 miles even with a lot of motor issues.
We are working with a diesel mechanic formerly from Long Beach who know the motor well. Going to r&r the d24tic volvo motor, hot rod the IP in the US then suspension fixes, body and paint. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
owokie Samba Member
Posted: Sat Apr 17, 2021 3:23 pm Post subject: Re: Lieutenant Van a VWLT build |
WTF is IP in this context? When will you be cruising again? Was through Long Beach not too long ago. Met some corporate people doing a cross country documentary along the way...
Zeitgeist 13 Samba Member
Posted: Sat Apr 17, 2021 3:27 pm Post subject: Re: Lieutenant Van a VWLT build |
IP = Injection Pump _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
owokie Samba Member
Posted: Sat Apr 17, 2021 3:30 pm Post subject: Re: Lieutenant Van a VWLT build |
Zeitgeist 13 wrote: |
IP = Injection Pump |
Gotcha, thanks.
You doing something beyond the usual fuel, preload/spacer LDA mods? |
rmcd Samba Member
Posted: Sat Apr 17, 2021 4:07 pm Post subject: Re: Lieutenant Van a VWLT build |
owokie wrote: |
Gotcha, thanks.
I have volvo IP and injectors. Some argue they provide more “power”. Chris said it was the strongest and quietest LT he has driven. Given his stable and the number of LT he sees as customers- I’m inclined to believe him. So I’m sure I’m going to f it up. I have a full cab partition so I can see why quiet.
The IP shop said they could tune more out of the IP and injectors. Im going for 20psi and or whatever they suggest. Bigger head? Don’t know.
I would like better hill climbing power and higher highway speed. If I have to I will paint a chicken blood pentagram on the dog house. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
owokie Samba Member
Posted: Sat Apr 17, 2021 4:21 pm Post subject: Re: Lieutenant Van a VWLT build |
rmcd wrote: |
owokie wrote: |
Gotcha, thanks.
I would like better hill climbing power and higher highway speed. If I have to I will paint a chicken blood pentagram on the dog house. |
Unless you change ratios, that thing will be screaming at "higher" highway speed. You could put larger tires than stock, but then your hill-climbing goal suffers. |
rmcd Samba Member
Posted: Sat Apr 17, 2021 9:43 pm Post subject: Re: Lieutenant Van a VWLT build |
IIRC I’m mostly topped out at the high end of the green area as designated in the tachometer at 4200rpms and on the flat, in a vacuum, I’m doing almost 110kpm.
The screaming is actually coming from the part of your brain that controls “common sense” and not the motor. The motor Seems under utilized at 4200 rpms. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
owokie Samba Member
Posted: Sun Apr 18, 2021 7:02 am Post subject: Re: Lieutenant Van a VWLT build |
There is no mod that makes that old diesel lump happy above 4200rpm. I'd suggest you're gonna want a different ratio or bigger tires. You can adjust your pump so you get less defuel at high rpm, but then you'll need to watch your EGTs etc. carefully. Oil temps don't like all that thrashing around either. The easiest route is to be happy with a ~60mph cruise speed. |
stuzbot Samba Member
Joined: March 30, 2018 Posts: 377 Location: Pining for the Puddles of Yesterday
Posted: Sat Apr 24, 2021 3:37 am Post subject: Re: Lieutenant Van a VWLT build |
Wow! --an LT Love-In on The Samba. Who'd'a thunk it!
But why settle for one LT when you can have two?...
My 1st LT, Herman in front. More rust than van. Bought for £500 and his replacement, my second LT, the imaginatively named Herman2 behind. Cost me £3000. Had belonged to an old people's home in Wales and had a genuine [every journey recorded in a diary] mileage of 17000. No. there isn't a missing zero. The old people's home had owned him from 200 miles on the clock and he'd only been used to ferry the old ones into the village a couple of times a week, or on the occasional outing to the seaside.
Pleasant memories: Herman basking in the sunset at St. John's Point, Co. Donegal, Ireland.
Not so pleasant memories: Went to have a nosey at an old abandoned cottage in Co. Sligo, Ireland. and returned to find that Herman2 was slowly sinking into a path which turned out to be just a layer of gravel on top of bogland. All weight on the front and sinking. All drive on the rear and rising!
I don't think I'd ever have an LT again, unless I could find a turbo engined one [both mine were normally aspirated and completely gutless --even the one with the barely run in engine]. But I did enjoy both of them. Loads of room inside and they just chug along [albeit slowly!] forever.
I always got the feeling with my old LTs that they were like a big clumsy kid who tries hard, but is a bit useless. Whereas my T3 I reckon has ideas above its station and thinks it's automotive royalty or something. _________________ *****************************
Click to view image
1992 VW LT35 2,4D [SOLD]
1993 VW LT35 2,4D [SOLD]
1992 VW T3 1,6TD Syncro [SOLD]
owokie Samba Member
Posted: Sat Apr 24, 2021 6:58 am Post subject: Re: Lieutenant Van a VWLT build |
stuzbot wrote: |
I always got the feeling with my old LTs that they were like a big clumsy kid who tries hard, but is a bit useless. Whereas my T3 I reckon has ideas above its station and thinks it's automotive royalty or something. |
Haha! Did you get it out of the bog without assistance?
Westfalia did the makeover the clumsy kid needed. Turbo makes a fair difference, particularly with a tune. Couple of swaps in the works if that isn't enough, 2.5tdi audi adapters currently slated for production if you don't want to DIY the x5 diesel or don't have 10k for Greg. I'll run what VW brung until it conks, likely longer than I'll own it given ~55k miles. Come drive it and buy another... |
Posted: Sat Apr 24, 2021 7:20 am Post subject: Re: Lieutenant Van a VWLT build |
owokie wrote: |
I had assistance... eventually.
Spent a couple of hours of trying to jack the front up to get something under the wheels, which mostly involved the front of the van not moving but the jack pushing whatever rock I had it placed on down into the bog. I must have tried about half a dozen boulders and each one just jacked itself down into the mire and pressed the ones underneath it even deeper.
Centuries from now some archaeologist will excavate that area and find a tower of boulders embedded in the bog and publish a learned treatise on how the ancient Celts built stone pillars to commemorate famous battles.
Eventually, as darkness was falling and after traipsing round various local farmhouses and finding no-one in, I jumped out in front of a shepherd going home in his rusty van, who said he'd drop the dogs off at home and come back in his 4x4 in about an hour and pull us out.
Long story, slightly less long: He was good to his word and did eventually come back. But even his Isuzu Trooper couldn't pull Herman2 out of his sticky predicament. Yer man then went off again and, this time, came back with a neighbour in a huge tractor which pulled us out, easy as shelling peas.
Our rescuers wouldn't even accept the €40 or the unopened bottle of whisky I offered them as thanks. Just said "That's what neighbours are for!" and went off.
I don't know if that incident was what led me to buying a T3 Syncro next. Engine weight over the driving wheels and a drivetrain which turns 'em all. Much more sensible! _________________ *****************************
Click to view image
rmcd Samba Member
Posted: Sun Apr 25, 2021 10:04 am Post subject: Re: Lieutenant Van a VWLT build |
Thanks for sharing the pictures and the adventures.
I also got stuck in my backyard by accident. In a fury of lever pulling probably not seen since the Evergiven started drifting I managed to turn on all the lockers and put it in four-wheel-drive low. And I just chugged right through the wet grass and mud without hesitation. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
rmcd Samba Member
rmcd Samba Member
Posted: Mon May 10, 2021 9:59 pm Post subject: Re: Lieutenant Van a VWLT build |
LT Van has been in Mexico for a couple months. Most of the time has been spent trying to figure out how to get parts to Mexico. It is NOT easy.
Shipping direct involves some kind of outrageous import taxes that are TBD. Allegedly it isn't super reliable either.
Carrying parts over the border is also subject to said import taxes that seem to be mood ring based and possible cavity search. So that leaves freight forwarders. Fortunately the fixer - Shane of LivetheVanLife.com has this figured out.
First up. Refreshen the motor. What happened to bodywork and paint. Bangkok got the van.
There are several options to upgrade the OEM 6 cylinder turbo diesel motor whether your LT still has the VW variant D24 ACL or the Volvo re-branded VW variant the D24TIC. Turns out - I have both. My factory installed ACL was replaced with a volvo D24TIC, a Volvo supplied Bosch VE IP and Volvo supplied injectors.
Why care? Parts are somewhat different between the motor variants, injector pumps and injectors. Try ordering rings and you will see what I mean. Several LT folks have said they THOUGHT the Volvo injectors had a better spray pattern and they felt the Volvo motor was stronger. No way to prove any of this internet lore.
Below are pictures and part numbers for the VW/Volvo D24TIC turbo intercooled motor that is currently in my van. Or is sitting on the ground in pieces in Bankok. Also found in a 91-96 Volvo 940 and 960. And shares some VW Caddy parts of the same time frame. Post 93 I've heard stated that the D24TIC motor plumbing and internals are different. Heads between D24t and D24TIC are not compatible without work. I can't verify that. I do have a D24TIC motor data sheet 700-900DataSheet91_94-Sec2c.pdf that I'll upload here.
Volvo block. ** NR 072 103 021S
Volvo head. 075 103 373R
Volvo IP. Bosch p/n L 116-7 and 072 130 108M and Volvo injectors 068 130 201B
Here is the VW D24 ACL turbo intercooled spare motor that came in parts with my van.
OEM head.
OEM block.
OEM IP. 075 130 107L Injectors 068 130 202E
Motor options.
Rebuild your OEM motor. Hotrod the IP to add whatever. Match the injectors to flow. Otherwise follow Chris's advice here. http://www.brick-yard.co.uk/forum/how-to-make-your-2-4-lt1-faster_topic83910.html
and here Tune your LT turbo diesel. https://vwlt.co.uk/2021/01/02/tuning-the-turbo-charged-lt-a-not-so-short-guide/
Replace your motor with the Volvo variant and build from there.
Small block Chevy. There is at least one of these running installs somewhere in America.
Dodge 5.7L Cummins diesel replacement. One internet site talks about someone starting this but doesn't have a finish. Hmmmm.
R2.8 Cummins RePower diesel crate motor. I was all excited about this. Internet lore says it won't fit without significant modifications. https://www.cummins.com/engines/repower
Chris DeLong (LT master mind) https://www.finetuningperformance.com/ is working on a kit to put in a 2.5 5 cylinder TDI.
And Greg at Boxeer has a BMW M57 kit. https://www.boxeer.com/collections/all/products/volkswagen-lt-to-bmw-3-0-conversion-kit
Fortune has driven my choice.
Shane (livethevanlife.com fixer) had been using a diesel mechanic to do work on his diesel truck. Lt Van was kind of falling apart after his 2000 mile drive to Baja. How much he was limping along is a testament to bad mechanical work and VW engineering. You'll see.
Shane's diesel shop mechanic is familiar with the D24 as he was formerly a shop owner in Long Beach CA. We took Lt Van to Marcos to look at the leaking injector, leaking everything else and seized cold start circuit in the IP. I thought a little R&R would keep the D24TIC going until I could manage the full swap.
This is still fresh so I will simply list where we are at.
Turbo shaft wobbles like a Weable. Waste gate frozen. Turbo rebuilt.
Head shows signs of over heating which is a known issue. Cracks between valves. Head welded and being rebuilt.
Coolant oil cooler blocked.
IP need of full rebuild. We knew that. Injector Pump and Volvo Injectors have been rebuilt.
Every seal shot. Broken piston ring but no damage to the cylinder. And all the bearings looked good. So we are refreshing the bottom end as well.
I'm in the process of smuggling the rebuilt IP and obscure motor bits sourced by Chris DeLong. Thanks again Chris!
Beauty shots thus far.
Before.
After. Still waiting on parts.
My fav. I wanted to touch this inappropriately when it came back from Pacific Fuel Injection diesel service. https://seideldieselgroup.com/contact/locations/portland-or/
It looks and smells new.
And some more VWLT goodness.
Vintage.
The tail swing on this would make a school bus driver blush.
Posted: Mon May 10, 2021 11:49 pm Post subject: Re: Lieutenant Van a VWLT build |
I think Chris DeLong's approach makes the most sense. _________________ Casey--
y u rune klassik? |
Buss Marius Samba Member
Joined: February 29, 2012 Posts: 98 Location: Oslo, Norway
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Thu May 20, 2021 12:13 pm Post subject: Re: Lieutenant Van a VWLT build |
I prefer to keep things that work and modify for more efficiency and power. Fully mechanical systems rule when doing extended travel in faraway places. My Karmann LT31, 2.4 TD, stock 92 hp: adding more boost and fuel (via 'GTD' injector nozzles) made a significant increase. After a 51-day roadtrip fully loaded through AZ and Baja, it became apparent 'more' would really be nice. So plans were made, parts bought, many hours of labor spent - and a few days ago drove the beast - huge increase in power from where it was. 'Seat-of-the-pants' dyno puts it in the 150 hp range. EGT is completely within safe limits, it can run 20+ psi safely, and the engine itself is still completely stock, making parts a cinch. The little six has a sweet sound too.
https://photos.app.goo.gl/gf2pZASjQQjaMm9H6 |
owokie Samba Member
Posted: Tue May 25, 2021 6:26 pm Post subject: Re: Lieutenant Van a VWLT build |
westyventures wrote: |
I prefer to keep things that work and modify for more efficiency and power. |
Which is exactly how you got into the business of ripping out absorption fridges and replacing them with compressor-driven units?
Dig the changes. By far the best addition you've made is the variable turbo. Haven't seen that done before. I'm plenty happy with power up high, but the lag is killer without significant boost under 2400. The progress you made there I'll be attempting to reproduce once I source the ancillaries and the spare syncro arrives. |
