stevebaz Samba Member
Joined: March 14, 2008 Posts: 189 Location: El Monte CA
Posted: Thu Jan 28, 2021 11:04 am Post subject: tube bender |
My dilemma is I need to buy a set of JD2 model 3 bending dies for 1-1/2" tube. I can only afford 1 set of dies. I don't want to make a mistake and order the wrong set. they are available in 4.5" radius , 5.5"R, 6.5"R, 7.5"R which one should I buy for cage work on my buggy? Its a hydraulic bender so manual force is not an issue wall thickness will be .095 or .120 wall. My initial guess is 5.5"R
Thank you for your time. |
cbeck Samba Member
Posted: Thu Jan 28, 2021 5:20 pm Post subject: Re: tube bender |
I don't remember if it was 3x or 4x the tube od. Speaking of buy once cry once , consider 180*dies instead of something less. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Posted: Thu Jan 28, 2021 6:20 pm Post subject: Re: tube bender |
I was already planning to suck up to the 180 dies. Thank you cbeck for your response. |
no1clyde Samba Member
Joined: August 27, 2013 Posts: 365 Location: Elko Nv.
Posted: Thu Jan 28, 2021 7:27 pm Post subject: Re: tube bender |
This car was built with a JD32 bender with a 4.5"-1 1/2" die
The 5.5 may be a better choice but this is what I had to work with.
Ed |
thesatelliteguy Samba Member
Joined: January 06, 2007 Posts: 1515 Location: Santa Rosa CA
Posted: Thu Jan 28, 2021 8:13 pm Post subject: Re: tube bender |
I have built a few roll cages using a 6.5” clr on my JD2. I’m happy with it, but a little tighter might be nice. _________________ Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Jan 28, 2021 9:13 pm Post subject: Re: tube bender |
Some place I remember it was recommended to use a radius 4.5 times the diameter of the tube.... So a 6.5 is pretty close.... Might have been at "Blind Chicken Racing"... IF radius is to big the bend takes up a lot of space....
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Fri Jan 29, 2021 1:55 am Post subject: Re: tube bender |
SCCA, NASA, & FIA require that diameter of bends are at least 3x the tubing diameter. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jan 29, 2021 8:20 am Post subject: Re: tube bender |
thank you all for the responses. |
jsturtlebuggy Samba Member
Posted: Fri Jan 29, 2021 2:54 pm Post subject: Re: tube bender |
I am using a JD Squared model32 and a 1-1/2in 5.5 radius 180 degree die.
It closely matches the radius of the aluminum windshield frame on a buggy and many buggy chassis’s roll cages. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Mon Feb 01, 2021 9:52 am Post subject: Re: tube bender |
thank you I have pretty much settled on the 5.5 die. thank you for all the help. now to spend that stimulus money. |
