desertwrx Samba Member
Joined: January 18, 2007 Posts: 351 Location: Borrego Springs, CA
Posted: Fri Jan 29, 2021 12:47 pm Post subject: How do I tell what year front end I have? |
Rebuilt the king/link pin spindles. It’s time to put them on and I have no idea what year beam I have. Of course the link pins were apart, so I have no idea if they were 8 or 10 shims.
Is there a way to tell if it is a 59 and earlier or 60 and later? _________________ 2 fiberglass buggies, 2 non-running Corvair Sandrails!
SCCA |
jsturtlebuggy Samba Member
Posted: Fri Jan 29, 2021 1:02 pm Post subject: Re: How do I tell what year front end I have? |
If the face of the trailing arm is flat , you use 10 shim. If face of trailing arm has a recess in it around hole where link pin goes, you use 8 shims, steel spacer with recess that matches trailing arm, and the o-ring that goes between shim and spacer. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Fri Jan 29, 2021 2:17 pm Post subject: Re: How do I tell what year front end I have? |
My trailing arms are countersunk. I’ll use o-rings and the spacers along with 8 shims.
Thanks for the info! _________________ 2 fiberglass buggies, 2 non-running Corvair Sandrails!
SCCA |
Posted: Fri Jan 29, 2021 5:20 pm Post subject: Re: How do I tell what year front end I have? |
FYI, The change from 10 shims to the 8 shims,dust seal and o-ring happen with chassis #2921552.
This change was made in mid year 1960.
The tang on the dust shield goes between split/pinch part of trailing arm. _________________ Joseph
Elrod Motorsports
