bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sat Apr 03, 2021 6:56 pm Post subject: Re: Why have a generator cover? |
My 71 came from the factory with the band type gen cover. It still has this original cover.
_________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL
mukluk Samba Member
Posted: Sat Apr 03, 2021 7:52 pm Post subject: Re: Why have a generator cover? |
bnam wrote: |
My '72 Super years ago had the same metal band type dust cover, supposedly original according to the original owner. _________________ 1960 Ragtop w/Semaphores "Inga" |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Apr 03, 2021 8:04 pm Post subject: Re: Why have a generator cover? |
Might find them in a Bosch parts catalog if not in a VW manual. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Herrbern Samba Member
Joined: May 04, 2008 Posts: 349 Location: Luxembourg, Europe
Posted: Sun Apr 04, 2021 12:54 am Post subject: Re: Why have a generator cover? |
My 67 vert has only one cover on the top. My 68 came from factory without covers. |
bnam Samba Member
Posted: Sun Apr 04, 2021 10:44 am Post subject: Re: Why have a generator cover? |
Even the strap only covered the upper port. The lower was meant to be left open for cooling. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
bnam Samba Member
Posted: Sun Apr 04, 2021 7:58 pm Post subject: Re: Why have a generator cover? |
Mine’s a 71. But I’d imagine the same as late 60s. Pic of it mounted is ok? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
bnam Samba Member
Posted: Mon Apr 05, 2021 12:57 am Post subject: Re: Why have a generator cover? |
It's pretty simple - just a flat strap with 2 rectangular openings (with rounded corners). One opening goes over the 2 connector studs and the other opening is is over the lower brush opening. The strap is bent 90deg at the ends with a screw/nut to tighten. When properly installed the tightening screw will be at 9 O'clock.
Will post pics later today. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
NavyGeneral Samba Member
Joined: August 01, 2004 Posts: 584 Location: Tennessee
Posted: Thu Apr 08, 2021 8:36 pm Post subject: Re: Why have a generator cover? |
viiking wrote: |
My ‘68 Euro spec came fitted with what is often erroneously called the “67 year only” generator with push on generator terminals. It has been in the family since new and does not have the covers fitted. |
Much has been expended on that subject: For 1967 The Beetle Generator part number is/was 211 903 031 (from VW Parts Book) applicable from Engine Number H 0 204 001 (August 1966) to/through July 1967 Model Year 1967 for Special Options Code 610 (12 Volts) USA/Canada and wherever else 12 Volts may have been used. Beginning in August 1967 for Model Year 1968 the Generator Part Number was 211 903 031 A-a change in the Generator was made!
Prior to 1967 Workshop Bulletin E - 72 August 1965 states that All generators and Regulators are now of the Push-on Type from 2 August 1965 (October 1965 for Type 2). Workshop Bulletin E of 27 March 1968 states that the D+ and DF terminals of Generator and Regulator have been changed from Push-on to Screw type. Additionally that bulletin states that if Generators or Regulators of the Push-on Type are used to Replace the screw on type-additional connecting parts are necessary and lists the needed parts! So, one way the Push-on type could be used outside its birth Year or Engine number sequence! |
Posted: Thu Apr 08, 2021 10:33 pm Post subject: Re: Why have a generator cover? |
Any chance the generator's starting with 211 are actually Garbe Lahmeyer parts and not Bosch? If they only have a VW part # they are indeed GL. _________________ Roads Scholar &
bnam Samba Member
Posted: Fri Apr 09, 2021 12:00 am Post subject: Re: Why have a generator cover? |
Click to view image
Frederik Samba Member
Posted: Fri Apr 09, 2021 7:55 am Post subject: Re: Why have a generator cover? |
From "Bosch spare parts for Volkswagen" (9.61) and the same but for 1500 (2.62)
25Hp (cover)
25-36hp (No cover)
36-40hp (No cover)
VW 1500 type 3 (cover)
Posted: Fri Apr 09, 2021 2:26 pm Post subject: Re: Why have a generator cover? |
tasb wrote: |
Any chance the generator's starting with 211 are actually Garbe Lahmeyer parts and not Bosch? If they only have a VW part # they are indeed GL. |
211 903 031 (Bosch 0 101 303 067). 211 903 031 A (Bosch 0 101 302 075). |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Fri Apr 09, 2021 8:30 pm Post subject: Re: Why have a generator cover? |
NavyGeneral wrote: |
viiking wrote: |
Well here’s my Jan ‘68, H0928xxx 211903031 with push on terminals. Been in the family since new.
_________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Tue Apr 20, 2021 7:59 pm Post subject: Re: Why have a generator cover? |
viiking: Is your 68 an Automatic? |
Posted: Tue Apr 20, 2021 10:57 pm Post subject: Re: Why have a generator cover? |
No it’s a manual. But is a RHD. Imported to Australia and owned since new by the family. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
