Volt-a-drop West Coast Metric
Jeler
Jeler is offline
PostPosted: Sat Jan 30, 2021 3:44 pm    Post subject: Re: Volt-a-drop West Coast Metric Reply with quote
Got it, thank you!
Have a great weekend
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Jan 30, 2021 3:37 pm    Post subject: Re: Volt-a-drop West Coast Metric Reply with quote
Jeler wrote:
It does matter? Or does not matter?
Thanks jeff
Sorry, does not matter.
In Stereo, Where Available!
Jeler
Jeler is offline
PostPosted: Sat Jan 30, 2021 3:13 pm    Post subject: Re: Volt-a-drop West Coast Metric Reply with quote
Eric&Barb wrote:
Jeler wrote:
Thanks for the info.
Jeff
Glad to help. The wire spiraled around inside that resistor has resistance to electrical flow, causing the wire to heat up. Electrical flow direction does matter to that resistant wire.
Eric Barb
Eric Barb
Thanks jeff
Eric&Barb
PostPosted: Sat Jan 30, 2021 2:49 pm    Post subject: Re: Volt-a-drop West Coast Metric Reply with quote
Jeler wrote:
Eric & Barb
Jeff
Glad to help. The wire spiraled around inside that resistor has resistance to electrical flow, causing the wire to heat up. Electrical flow direction does (edit) not matter to that resistant wire.
Jeler
Jeler is offline
PostPosted: Sat Jan 30, 2021 2:30 pm    Post subject: Re: Volt-a-drop West Coast Metric Reply with quote
Eric & Barb
Jeff
Jeler
Jeler is offline
PostPosted: Sat Jan 30, 2021 2:29 pm    Post subject: Re: Volt-a-drop West Coast Metric Reply with quote
telford dorr wrote:
I just volt a drop from West Coast Metric and there are no instructions.
Well, it's just an adjustable resistor. The sliding middle contact can be moved.
I'd move the slider to the far end of the resistor, then power up the wipers. Move the slider towards the other connection until you get 6 volts (or half of whatever the battery voltage is) across the motor. Once you get it adjusted, tighten the slider down so that it can't move.
Mount the resistor somewhere that it can get good air flow around it, as it will get hot.
Telford
That's exactly what I was looking for. Does it matter which wire goes where? In and out on the circuit.
I was thinking of mounting it on the crossbeam right above the fuse box and far to the left to keep it away from other wires or flammables.
Thanks again
Jeff
telford dorr
telford dorr is offline
PostPosted: Sat Jan 30, 2021 2:12 pm    Post subject: Re: Volt-a-drop West Coast Metric Reply with quote
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Eric&Barb
PostPosted: Sat Jan 30, 2021 12:21 pm    Post subject: Re: Volt-a-drop West Coast Metric Reply with quote
Voltage goes into the voltage drop and from the voltage drop to the wiper switch. Voltage drop is just a resistor, and gets VERY HOT when you run the wipers. So you need to mount it in such a way as to not let your fingers accidentally touch it or something flammable like paper not to come in contact with it that will cause a fire. Other problem with using a resistor is it reduces voltage more when it is first turned on, when hot it will allow more voltage thru later. This means you will probably need to set voltage output a bit low when the resistor is cold and when warmed up a bit high. Resulting in wipers a bit slow at first and a bit too fast later. The clamp in the center is how the voltage can be adjusted.
Personally have switched to a adjustable buck module. Figure about 8 Amps to run the wiper motor and double that at start up. So the 15 Amp units with 20 Amp momentary ability works. Nice to be able to have it set to 7 volts output all the time.
https://www.ebay.com/sch/i.html?_from=R40&_trk...p;_sacat=0
Also added a PWM to allow adjustment of the wiper motor speed from really slow to as fast as it will go with voltage available. Again really need 15 Amps or more.
https://www.ebay.com/sch/i.html?_from=R40&_trk...15+amp+PWM
Had to reroute the ground wire in the motor out to the PWM module to get it to work. Plus since it is an open circuit board with no casing, I made a bracket to mount the PWM module to the front of the package tray. This keeps the module from shorting out and allow air to pass over the heat sink to keep the electronics cool.
Jeler
Jeler is offline
PostPosted: Sat Jan 30, 2021 11:03 am    Post subject: Volt-a-drop West Coast Metric Reply with quote
Hello everyone
I have a 66 bus wired for 12 Volt now, with a 6 volt wiper motor.
Has anyone every installed/used one of these?
https://www.westcoastmetric.com/i-22967761-w-2612.html
I all ready know I can get a 12V motor but want to keep the 6V motor.
Thanks
Jeff
