TRS63 Samba Member
Joined: December 17, 2017 Posts: 999 Location: Stuttgart - Germany
Braukuche Samba Member
Posted: Sat Sep 04, 2021 8:34 pm Post subject: Re: 1962 Golde metal sunroof Ghia project |
Going through my stash of Porsche engine stuff and rounded up everything I need to build a C spec engine for the Golde car, which was rated at 75 HP. I will use big bore pistons and cylinders so should eek out a little more HP.
Will send modified tins off to the powder coated, 62 industrial case, 912 heads, B non counter weighted crank, lifters, flywheel, to the machinist.
Tomorrow I’ll sort through the chrome and get that going.
My experience restoring cars is that I always think most of the time investment is over once I complete the bodywork and paint, but in reality I always end up getting delayed waiting on machine work or parts, so I figure I’d get ahead of the game by sending out everything now.
_________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
tri356 Samba Member
Posted: Sat Sep 04, 2021 11:03 pm Post subject: Re: 1962 Golde metal sunroof Ghia project |
Are you planning on running any oil filter with that engine? I had a lot of problems with engine temps when I first installed a 356 engine in my 62, until I went with a remote filter.
Mike |
Posted: Sun Sep 05, 2021 7:40 am Post subject: Re: 1962 Golde metal sunroof Ghia project |
tri356 wrote: |
Mike |
Hey Mike, I think I’ll get type that bolts to the oil pump since I won’t be running the stock tach drive. I’m also going to buy a new aluminum oil cooler, those are supposed to lower temps.
If you could tell me everything you had to do to fit the 356 engine into you Ghia including how you trimmed the tins and hooked up the accelerator assembly and fit the muffler I’d be most grateful. Otherwise I’m sort of winging it here.
Thanks,
Dan _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Mon Sep 06, 2021 2:35 pm Post subject: Re: 1962 Golde metal sunroof Ghia project |
Finished up the lower rust damage repair with the front lower fender piece and moved on to the upper fender headlight area that had horrible brazed patch repair.
I cut the patch out to reveal that someone had simply beat the roached original metal down and brasses the patch over it. Of course the rusty metal underneath would have eventually eaten away at the new metal and bubbled up the bodywork in a short time, so it all had to go.
The headlight surround was solid so I opted not to go down that hole, but the top of the bucket was roached so I have to patch that as well.
Next up is the other side, pretty much the same crap but with the addition of some rear outer fender well brazed patches that will have to go.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Mon Sep 06, 2021 6:37 pm Post subject: Re: 1962 Golde metal sunroof Ghia project |
Thanks Ian, I’ve seen those. I talked to Mike today and he said there’s no enough clearness after shortening the 2/4 muffler manifolds so I have to use the remote one which also replaces the tach face on the oil pump. So that’s the plan… _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
TRS63 Samba Member
tri356 Samba Member
Posted: Thu Sep 09, 2021 8:11 am Post subject: Re: 1962 Golde metal sunroof Ghia project |
It's a little late, but here's the write-up of what we spoke about Dan:
1) I had a heck of time bringing down oil temps with my engine - a slightly hopped up (1720cc) 356SC engine. Not knowing any better, I even went down the route of installing a later ghia deck lid, with the rain tray removed. That didn’t help. It wasn’t until I installed a remote oil filter that temps came down. Nowadays, I have no overheating issues whatsoever. I used this assembly:
https://precisionmatters.biz/remote-oil-adapter-pressure-relief.php
It allows you to pipe the oil away, and install a remote oil filter:
I just don't see how that other full flow oil filter, the one that attaches directly to that rear cover, would fit.
2) Muffler
Depending on what you are willing to accept, your biggest source of frustration could be fitting a muffler to that engine. If you are ok with an extractor type of exhaust, 4 pipes merging into 1, with a muffler hanging off to the side, then this is not such a big problem. If you want more of a stock look, then some of your choices are:
a) taking 356 exhaust flanges and welding them to a VW muffler
b) cutting 356 mufflers to make them fit within the space you have. The current reproduction of the 356A muffler is just about the correct width to fit within the ghia's body. There is just a slight cut that needs to be done to the right-side ghia body support bracket - the one that goes from the ghia apron to the underside of the engine surround metal. See the pic below to get an idea of what I mean. Even with that, the muffler pipes attaching to the #2 and #4 exhaust ports still need to be cut, to bring the muffler 'in' towards the engine.
An original 356A muffler will not work - it's way too wide by several inches.
~ 30 inches width or less is needed to make it work (tucked in within the body, hanging lower of course the muffler can be wider). Converting inches to mm, that'd be 762. So, the Vintage Speed muffler should work. That would leave the exhaust flange change, and fore-aft location.
3) throttle linkage:
Take a look at the back of that fan shroud you have and you’ll see a bell crank at the bottom.
At the top of the fan shroud you’ll have a cross shaft like this one:
https://www.thesamba.com/vw/classifieds/detail.php?id=2344537
A rod connects the two. Regardless, your accelerator cable will need to be mated to the end of a similar rod (if you have an extra carburetor downlink, , so that this rod can attach to the bell crank, and move things accordingly. I’ll look through my stash of parts - I still may have this piece lying around, as these days, I went with the Synclink system:
https://www.thesamba.com/vw/classifieds/detail.php?id=2169636
4) I don’t have much to say about the tin. That recent 912 powered ghia on BAT has a picture of a cardboard template being used, which I think is a good idea. I think the side tins have to be cut by a lot because the engine opening is just barely wide enough. I remember spending a lot of time with tin snips. You wind up losing the carburetor pre-heat openings in that rear tray tin, because there just isn’t enough room.
5) Flywheel. With your original tranny, the 180 mm flywheel would be the way to go. You'll need to match the throw-out bearing. Also, I believe the flywheel will need to be machined to a particular depth. But for that point, someone like Jay at Jay's Precision Machine would know for certain. |
Posted: Thu Oct 14, 2021 2:49 pm Post subject: Re: 1962 Golde metal sunroof Ghia project |
Mike thanks for the information and pictures, most helpful.
I sent everything off to the machinist a couple weeks ago. Decided to go with B normal heads as I’m using a B normal crank and Zeniths.
I’ve also been chipping away at the rust repair. I finished up all the welding to the body today, leaving me the pans to deal with. I ordered the ones out of Thailand which are still in the box. My plan is to pull the body off and take it to my friends shop where I can do the body work and paint. I’ll deal with the pan here at home. When they are both done I’ll drop the body on the pan and do the final assembly at the house.
I’ll spare you all the gross pictures of the trash I had to cut out, but suffice to say it was mostly brasses in scrap metal directly over rotted original metal. The guy of course didn’t deal with the rotted inner structure at all, so I had to cut all that out first, weld in patches or repair panels, then deal with the outer metal. Since the aftermarket stuff is garbage and doesn’t conform to the original lines at all, I saved what I could and cut and spliced to keep the original contours. It was a real PITA to be honest, especially the rear lower fender…
When the car was brought to Texas they had the dealer install AC, which has since disappeared. Since I’m planning on returning it to its German delivery specs other than the engine and brakes, I decided to weld up the holes in the trunk and will remove the hoses and pipes.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Fri Oct 15, 2021 8:38 pm Post subject: Re: 1962 Golde metal sunroof Ghia project |
Doesn't clean metal make you feel so good.
I'm using dual Zeniths on a T1 motor made to look old school. Motor is fairly large so it has been an adventure. Waiting for new butterflys and main shaft and some air correction jets. Machined out the venturies today. It sure looks cool and the real deal will be even better. |
Posted: Sat Oct 16, 2021 8:26 am Post subject: Re: 1962 Golde metal sunroof Ghia project |
djway3474 wrote: |
Who are you buying Zenith parts from? I thought the venturii just drop out after you back out a set screw? Can you elaborate? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Rome Samba Member
Joined: June 02, 2004 Posts: 9651 Location: Pearl River, NY
Posted: Sat Oct 16, 2021 5:13 pm Post subject: Re: 1962 Golde metal sunroof Ghia project |
356 engine into your Ghia: tri356's experience and tips will certainly be valuable for you.
In the first few years of my starting to build my own VW engines, I bought the book "Secrets of the Inner Circle" by the now-legendary late Harry Pellow, who was meticulous as to documenting details on the parts and assembly of Porsche 356 engines which are covered in that book. My intent was to learn about his techniques to possibly apply on and improve my engine building on VWs, not to buy and build up a 356 engine. I remember a section on fitting a 356 engine into a VW, written by Jack Magrane. If you have this book, Jack's chapter starts on p. 270 thru p. 282. He explains details on modifications needed on the 356 engine to make it fit into the VW. I knew Jack personally, since he was based in my adjacent state Connecticut and was a regular at VW meets in the late '80's and early to mid '90's when I was getting active and already had my own '64 Ghia. He had a street-driven pale yellow '64 or '65 Ghia Coupe into which he fitted an SCCA class "D-Production" either 356 or 912 engine. He had a small side business named "Vorsche". |
Posted: Sat Oct 16, 2021 10:07 pm Post subject: Re: 1962 Golde metal sunroof Ghia project |
Braukuche wrote: |
djway3474 wrote: |
Who are you buying Zenith parts from? I thought the venturii just drop out after you back out a set screw? Can you elaborate? |
Alpha1750 on Ebay has the best selection of Zenith parts I have found. He is in Italy I believe but parts get here just as quick as the most expensive parts seller in the states and Alpha is cheaper and better selection.
I was not clear about the venturies. I pulled them out and machined them to around 28mm opening. I could have gone larger but I am not looking for every little HP possible. Just for kicks I also removed the float bowl vent bar and added small brass L tubes to keep fuel from sloshing out of the bowls. Probably wont do a thing but it looks cool. |
Posted: Thu Nov 11, 2021 7:59 am Post subject: Re: 1962 Golde metal sunroof Ghia project |
Had the Ghia hauled to the shop and spent two days separating body from pan and tearing the pan down. The transmission is original but I want install a later with taller gearing so it’s going. I’m sending the spindles out to be rebuilt and the beams will get all new components. I’ve got the new pans and just need to some measuring and cutting so I can weld them in.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Thu Nov 11, 2021 9:04 am Post subject: Re: 1962 Golde metal sunroof Ghia project |
Braukuche wrote: |
Brings out the animal in the Ghia doesn’t it.
_________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
TRS63 Samba Member
Posted: Thu Nov 11, 2021 12:13 pm Post subject: Re: 1962 Golde metal sunroof Ghia project |
TRS63 wrote: |
That is going to be such a nice ghia in your hands
Antoine |
Thanks for the vote of confidenc Antoine.
How’s yours coming along? Looks like you got sidetracked on the 914. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
TRS63 Samba Member
Posted: Tue Nov 30, 2021 7:14 pm Post subject: Re: 1962 Golde metal sunroof Ghia project |
Spent a crazy amount of hours cleaning up the pan, prepping the replacement pans, cutting out and chiseling off spot welds for the seat rails, patching up the crusty rails, wire wheeling the pan and tunnel etc etc, but it’s almost done. Got the top side painted and in a couple days will flip it and do the underside.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
