kevincoupnj Samba Member
Joined: December 22, 2019 Posts: 4 Location: South Carolina
Posted: Mon Feb 01, 2021 4:50 pm Post subject: carb. & fuel pump rebuild |
I'm new to this...so be patient. I just purchased a 1967 beetle. It has the original numbered correct engine. A few parts I'm replacing, are correct but not original. They are the carburetor, fuel pump, distributor & generator. I've located and purchased correct, re-buildable replacements, that I'm going to re-condition and rebuild. What I need is advice on where to buy the best available rebuild kits for these parts. I've been told that Wolfsburg West has good kits for the carb & fuel pump...please advise. Also any advise on the distributor and generator would be appreciated. |
Dan2973 Samba Member
Posted: Mon Feb 01, 2021 5:42 pm Post subject: Re: carb. & fuel pump rebuild |
Look for Bill at Sparx werkz |
Posted: Mon Feb 01, 2021 6:53 pm Post subject: Re: carb. & fuel pump rebuild |
Thanks...but I don't need a rebuilder. I need to know where to buy the best parts for myself to rebuild.
Where are you from in NJ ? |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Feb 02, 2021 5:16 am Post subject: Re: carb. & fuel pump rebuild |
A 67 originally had a 205K which is the simplest model. You only need 2 fiber washers and metal shims. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Feb 02, 2021 8:46 am Post subject: Re: carb. & fuel pump rebuild |
Thank you Glenn. I looked at your site. You do beautiful work. Can you recommend where I can buy all the parts necessary to rebuild my 205K ?...shims, points, rotor, cap, condenser, etc ? Very much appreciate any help. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Tue Feb 02, 2021 8:52 am Post subject: Re: carb. & fuel pump rebuild |
WolfsBurg West has the correct fuel pump rebuild kits.
I have recently bought 4 maybe five and they come with the correct Efbbi main diaphragm. Some say to use the original springs instead of the ones that come with the kits.
I used the springs that came with the rebuild kit and didn't notice any degradation in the pump performance. YMMV!
I cannot vouch ton the quality o the WW carb rebuild kits. Most of them these days seem to be the same generic kit. No matter where you purchase them from.
A suggestion. On the carb, fill the float bowl with IPA and operate the throttle lever. I have a 30 PICT 1 that leaks around the throttle plate shaft. It needs a rebush of the shaft.
https://www.volkzbitz.com/
Tim can and will make the carb good as new! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
KTPhil Samba Member
Posted: Tue Feb 02, 2021 9:35 am Post subject: Re: carb. & fuel pump rebuild |
It's been years since I bought one, but for forever the float valves in rebuild kits were junk, and you want to clean and re-use your old one if possible.
Also, my favorite obscure carb tip: When you assemble the accel pump, fit the diaphragm, then fit the cover loosely. Then open the throttle all the way (which actuates the pump fully), and while holding it there, tighten the four screws of the pump cover. This will prevent stretching/tearing of the diaphragm, especially as it ages.
Here are some tips, including this one and access pump nozzle aiming, from repair manuals:
KTPhil wrote: |
The VW Owner Service Manual (Verlag Delius+ Klasing & Co):
It does show a misleading diagram that implies a spray or shower, instead of a jet:
But the text makes clear it is a jet, and that it should be aimed to avoid any part of the carburetor. It also says to tighten the pump cover screws with the throttle open.
Elfrink's VW Technical Manual:
This mentions the proper aim to avoid hitting the throttle plate:
Haynes VW Beetle Owners Workshop Manual:
This mentions both the aim, and also the need tighten the cover screws with the throttle opened:
Glenn Mr. 010
Posted: Tue Feb 02, 2021 9:39 am Post subject: Re: carb. & fuel pump rebuild |
kevincoupnj wrote: |
Talk to Marcel at www.vwnos.com
Some of the stuff he sells are genuine Bosch and some are reproduction.
Everything you need should be about $10. _________________ Glenn
Member #1009
#BlueSquare |
Russ1967 Samba Member
Posted: Tue May 04, 2021 3:16 pm Post subject: Re: carb. & fuel pump rebuild |
Any recommendation on a rebuild kit for a Solex 30 pict1? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Tue May 04, 2021 4:02 pm Post subject: Re: carb. & fuel pump rebuild |
Russ1967 wrote: |
I got my rebuild kit from RockAuto, covers several models. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
KTPhil Samba Member
Posted: Tue May 04, 2021 4:09 pm Post subject: Re: carb. & fuel pump rebuild |
Regardless of where you buy the kit, keep and maybe re-use your old float valve. New ones have historically been junk. |
