LiveFreeOrDie Samba Member
Posted: Sun Feb 07, 2021 9:42 pm Post subject: Transmission blown or bad linkage |
Hey family-
While I was cruising the land of the brave and free, my reverse seemed to get binded up out of nowhere. Was working fine then all of a sudden it started to bind up and took a lot of jostling to get it out of reverse and into first.
I thought maybe a spacer tab got knocked loose and was the reason. That was not the case. Tabs are in place and fine. I changed the box and shifter lever that goes into the van to shift but now it’s even worse and will NOT come out of reverse no matter how much jostling.
Now I need to verify if it’s gear box or the linkage. Is there a technique to shift at the transmission with out shafts and linkage in the equation? Has this happened to you?
Thanks for reading! |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Sun Feb 07, 2021 9:51 pm Post subject: Re: Transmission blown or bad linkage |
Probably not the transmission. The linkage is very long and fraught with potential problems.
Chock the wheels and get underneath the van on the right side of the transmission in front of the right rear wheel. While someone is shifting in the cabin, look at the linkage where it goes into the transmission.
If there is any lost motion or looseness, that is most likely your problem.
These vans are very old now. |
Posted: Sun Feb 07, 2021 9:56 pm Post subject: Re: Transmission blown or bad linkage |
I’ll try that. However it’s newer linkage with a lot of updated bushings and new nylon ball arm thingy with the aluminum receiver.
But just to easy my anxiety is there a way to verify transmission by hand shifting or something.
Also it’s literally stuck in reverse so I can’t budge it from there to even find any looseness |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3094 Location: ABQ NM USA.... Except when not
Posted: Mon Feb 08, 2021 4:08 am Post subject: Re: Transmission blown or bad linkage |
yes, unbolt the last linkage mounting point (2 bolts to the transmission) drop the aluminum thingy and move the ball by hand in various forward/back/in/out directions. make sure at least one wheel is free to rotate to remove any binding force fixed wheels could be causing in the transmission/differential. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Mon Feb 08, 2021 7:06 am Post subject: Re: Transmission blown or bad linkage |
What year? Air Cooled or water cooled? There are external differences that the above directions may not be exactly correct. If you have the early trans, there is a pin at the end of the shift rods that supports it at the trans. Unbolt the pin and the rod should drop out of the way to manually shift it. You might be able to shift either version without disassembly. An adjustable wrench will give you some leverage to pop it out of reverse. The external linkage shouldn’t be holding it in gear. _________________ ☮️ |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
danfromsyr Samba Member
Posted: Mon Feb 08, 2021 7:27 am Post subject: Re: Transmission blown or bad linkage |
the linkage is ridiculously sensitive to adjustments.. like 1/32" at a time..
so if you've had it apart and back together. you'll have to set it at a baseline per the Bentley manual and start over with adjustments.. scribe a line and adjust the splined part in very small increments. _________________
Abscate wrote: |
Posted: Mon Feb 08, 2021 8:00 am Post subject: Re: Transmission blown or bad linkage |
It needs to be in neutral before you start adjusting. If it's physically stuck in reverse, you need to get it unstuck before you start looking at adjusting. Either transmission, the transmission arm must be pointed straight down in neutral. Also, the nut that holds the arm can come loose. The arm is indexed so it should only fit one way. Make sure the nut is tight. _________________ ☮️ |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Feb 08, 2021 8:38 am Post subject: Re: Transmission blown or bad linkage |
MarkWard wrote: |
... the nut that holds the arm can come loose... |
This...a common surprise after shifter work, and an easy fix.
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
The Carrot Samba Member
Joined: November 18, 2013 Posts: 173 Location: Ontario, Canada
Posted: Mon Feb 08, 2021 8:51 am Post subject: Re: Transmission blown or bad linkage |
Achtung!
Be careful not to strip the threads on the end of the shifter shaft in the transaxle. 18 ft. Lbs. Max. You really should have a new Lock nut for attaching the lever to the shaft. _________________ 1990 Orly Blue Carat |
ThinkingD Samba Member
Joined: January 21, 2020 Posts: 130 Location: Ottawa Ontario Canada
Posted: Mon Feb 08, 2021 11:05 am Post subject: Re: Transmission blown or bad linkage |
If you detach the linkage at the transmission and you cannot get it out of reverse by shifting it at the transmission with the clutch in, your transmission may be toast unfortunately… |
