Crankey Samba Member
Posted: Sun May 16, 2021 6:13 pm Post subject: Re: bulletproofing the cooling system |
Few years back I found a Ford heater valve that when the heat was shut off the coolant was cut off from the core and routed back to the block.
At the time it seemed like a good idea because it stopped most of the coolant volume fluctuations from turning on or off the heat.
Seems to me that the heater circuit is also plumbed to involve the coolant bottle and was, for me causing the dash light to flash from coolant level in the bottle.
Flashing coolant light in a swapped van is a mandatory stop and look event.
Nothing bad ever happened to me but there's no way I could just keep driving.
I bought one but never had a chance to install it and around that time my project got parked into storage for reasons totally unrelated.
Anyone remember that or try it out ? The valve was vacuum or lever actuated. Would also require a little fab work to tie in to the control cable. |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Sun May 16, 2021 5:45 pm Post subject: Re: bulletproofing the cooling system |
according to Gates it's a very popular hose, doubt it will go anywhere. used on lots of classic stuff as well as RV's
Gates actually offers an amazing assortment of hoses if you can stomach searching for them. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
jlrftype7 Samba Member
Posted: Sun May 16, 2021 4:32 pm Post subject: Re: bulletproofing the cooling system |
skills@eurocarsplus wrote: |
wanted to update this.
i wanted to replace my front heater core hoses. they are available but of questionable quality.
everything in my cooling system is new...down to a NOS vw/audi radiator, the only exception is the front heater core, as it seems to be just fine (here's to hoping)
anyway i got down to business trying to figure out the front heater hose situation. 37 year old coolant hoses are nothing i personally want to trust. and Taiwanese hoses i'd trust even less
so after hours of digging i came up with Gates 28472 hose
it's a 90º Molded Heater Hose that is 5/8" x 52" or a 4" leg and 48" length after the 90
it's claim to fame is being SUPER flexible, which it is.... it's not stiff ass hose like normal 5/8 heater hose. you can tell by it's weave....much like a chinese finger or fishnet stockings.
you can literally almost tie it in a knot without kinking
you can see it here on the top
now both
if you do the Ferd heater valve it's almost like it was meant to be. it will work with the sucky VW valve as well.
photo here makes it look like it's close to the fan, but it's about 3/4" away...plenty of room and i haven't zip tied anything off yet
basically i trimmed the leg down to the length of the OE hose and went to town. they do sell this hose a bit shorter....i forget the p/n but wanted as long as i could get for wiggle room and honestly, it wasn't much of a price swing.
so for 20 bux you can get your ancient hoses the fuck out of the cab and not blow 25 bux a piece for taiwan junk |
Thanks for the info- hopefully it stays available and doesn’t disappear like so many other parts... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Sat May 15, 2021 10:55 pm Post subject: Re: bulletproofing the cooling system |
now both
so for 20 bux you can get your ancient hoses the fuck out of the cab and not blow 25 bux a piece for taiwan junk _________________
Jake Raby wrote: |
Brian wrote: |
4Gears4Tires Samba Member
Posted: Sat Feb 13, 2021 3:53 pm Post subject: Re: bulletproofing the cooling system |
Whoa whoa whoa.. Nine dollars and 25 cents?
Slow your roll big spender! _________________ '87 Syncro
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Sat Feb 13, 2021 10:09 am Post subject: Re: bulletproofing the cooling system |
Don’t forget that there are at least 2 plastic couplers in line if the heater hoses that join the long lengths to the molded hoses. Those always seem to be fairly heat cycled by the time you replace them. It’s a small part but you’re looking for reliability. _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Sat Feb 13, 2021 8:40 am Post subject: Re: bulletproofing the cooling system |
my hang up with the current self bleed deal is that clear tubing. pounding the internetz it doesn't have a very high temp rating or psi rating. most are good for 5psi @ 70*
granted, you can get plain old coolant hose in 1/4" but it's not clear.
i'm not bagging on the inventor, in fact i think it's a great idea. i'm just not a fan of adding a potential failure point with the clear tubing not rated at a minimum of 20psi @220* |
1. Would the banjo bolt, with it's little tiny hole through it, act like a turbo oil feed restriction and reduce pressure?
2. If the coolant at the top of the radiator is 220F, the coolant at the motor has to be something like 320F. RIP.
3. If you want a clear observation tube, you could use 1/4" extruded acrylic tubing. It wouldn't be difficult to flame the ends and squash them for a ferrule. Just like people did for show cars in the early 2000s F&F era.
4. I remember going over this last time and the clear hose is well inside tolerance specs for its use. I don't think it's an issue. If it is in the future, you can be sure I will post about it.
4a. https://www.ebay.com/itm/1-Foot-HPS-1-4-ID-6mm-Hig...1195.m1851 Clear silicone hose that states it meets SAEJ20 standards for ethylene cooling systems
4b. https://www.amazon.com/Silicone-Tubing-Foot-Piece-...4&th=1 Clear silicone tubing that states it is safe to 500F. _________________ '87 Syncro
Posted: Fri Feb 12, 2021 10:00 pm Post subject: Re: bulletproofing the cooling system |
i'm not bagging on the inventor, in fact i think it's a great idea. i'm just not a fan of adding a potential failure point with the clear tubing not rated at a minimum of 20psi @220* _________________
Jake Raby wrote: |
Brian wrote: |
valvecovergasket Samba Member
Posted: Fri Feb 12, 2021 4:02 pm Post subject: Re: bulletproofing the cooling system |
how is the ford valve? i'm not opposed to using it. |
it works fine. as i recall theres two numbers that work opposite eachother so just watch which one you order.
i ended up with that as i was wrapping up our tdi swap just before the intrepid valves were available
if i were to do it again or had the system empty for some reason, id definitely go with the intrepid valve as the self bleeding is nice. id probably still move it indoors though _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Fri Feb 12, 2021 3:40 pm Post subject: Re: bulletproofing the cooling system |
The heater core getting airblocked is not going to overheat my motor, unlike the radiator.
bobbyblack wrote: |
Oh the joys of the non-heated garage... |
How big is your garage? Is 12k BTUs enough? $725 and you can install it yourself. The lines come precharged. Generally speaking, mini splits work down to about 20F.
https://www.amazon.com/Classic-America-Ductless-In...NrPXRydWU=
I am running a 24k DIY MRCOOL in my garage. It looks like it's no longer offered, only 12k, 18k, and 36k. They are a bit pricier, with their 12k @ $1400 https://www.amazon.com/MrCool-Ductless-Split-Syste...3&th=1 _________________ '87 Syncro
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Fri Feb 12, 2021 3:13 pm Post subject: Re: bulletproofing the cooling system |
I didn't install my fancy bleed and valve kit yet. In fact, I don't have much trouble bleeding. I have a nice area in my "driveway" siding that I back up on, and it puts the pressure tank at least 3 inches above the bleed on the radiator.
I see the advantage, of course, with it bleeding on the fly. I have been mulling it over for a while, but I see it more practical for transplants that are HARD to bleed. I offered to put in in my daughter's EJ22 powered '86, if she gets going on the final bits this Spring. I am looking forward to seeing how the EJ22 powers her tintop.
Having looked over the kit though, it seems like a no brainer. If I were in actual need of a new valve, I certainly would put it in. I have yet to check if the banjo will fit the replacement radiator I also have sitting on the shelf.
Oh the joys of the non-heated garage... _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Fri Feb 12, 2021 3:01 pm Post subject: Re: bulletproofing the cooling system |
I disagree. If you get it bled and you run for years without touching it, I can see why you'd think it's a waste.
However, as someone who is constantly pulling things apart and subsequently constantly having to bleed the system, this thing is a blessing. I can't tell you how many times I have had to bleed air out of the top of the radiator. It might work well enough to not overheat and to run fine because the amount of coolant and the size of radiator is massive for this little engine, but it is not what I consider "self bleeding". Air gets trapped at the radiator.
The ability to confirm the fluid level at the front of the van where it actually matters? Icing on the cake.
I'm not saying don't home brew the set up with napa/mcmaster carr parts or what not. That's neither here nor there imo. I'm saying the set up is an improvement. _________________ '87 Syncro
Posted: Fri Feb 12, 2021 2:23 pm Post subject: Re: bulletproofing the cooling system |
so, my trial hoses came in for the front heater core. seem very promising and made by Gates. advertised as kink resistant and just fooling with them seem like they will work just fine. i will post the # when i can confirm they will work.
feel much better about it and honestly feel better NOT to use the taiwan ones available
thinking the auto bleed valve i don't see why you couldn't use a stock valve (or a facsimile thereof) and just used this
https://www.napaonline.com/en/p/BK_6601595?cid=pai...D_BwE&
of course you'd need the banjo arrangement but those can be had cheap enough.
anyway, not liking my choices for radiators at the moment _________________
Jake Raby wrote: |
Brian wrote: |
Last edited by skills@eurocarsplus on Fri Feb 12, 2021 9:39 pm; edited 1 time in total |
Posted: Wed Feb 10, 2021 9:48 am Post subject: Re: bulletproofing the cooling system |
good input, thanks
djkeev~ yea, the front heater core hoses that are available (after much digging) are made in Taiwan. no thank you...
i may have found a workaround for those hoses. i ordered a ton of different options from Gates. they have a whole bunch of molded 5/8 hoses so i am going to see what i come up with.
no need to post any p/n yet as i'm not sure what will work, but will keep this updated or post another thread.
i literally have totes upon totes of hoses from cars i parted out. call me a swamp yankee but saving that stuff is great for conversions/custom installs so you can cut up stuff and not feel bad, then match up a hose a your local FLAPS.
anyway...my concern for the front hoses is real....upon doing a 1.8T swap (thank God it was my personal car) i re-used a good looking hose from my bin-o-shit and after about 3k miles, it failed in an epic way on a hot summer day when i was grabbing 2nd gear at 5k and 22lbs of boost. the side of the hose ripped like a zipper was there.
that was a OE vw hose dated 10/88 and was pulled from a low mileage example. my concern for the radiator is it came in a plie of parts when i went shopping at a friends place. it's original and although it seems ok i'd rather not push my luck.
how is the ford valve? i'm not opposed to using it. in the mk1 rabbit world there is a porsche valve that is very similar to the one used on our vans that is still available from por$che so i will dig into that as well _________________
Jake Raby wrote: |
Brian wrote: |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Wed Feb 10, 2021 8:34 am Post subject: Re: bulletproofing the cooling system |
My 82 diesel had the heater valve inside the cab. I guess it was too easy to access, so the engineers figured out the most difficult place to access the valve in later models. _________________ ☮️ |
Posted: Wed Feb 10, 2021 8:26 am Post subject: Re: bulletproofing the cooling system |
djkeev wrote: |
Do install the Jeep blower fan resistor also.
Dave |
If a person was to be getting into the front blower area to the extent where changing out to a Jeep resistor was 'doable' I would completely reconsider the options at hand in the modern epoch.
Resistors waste power.
I remember member ItalJohn did a youtube on it. I can't put my finger on it just now, but here is yet another youtube of how/why to do the PWM for the front blower.
https://www.youtube.com/watch?v=3GzJ8N1Rqp8
https://www.youtube.com/watch?v=3S24Hty4_bs
SyncroJael did a topic on doing PWM for the upper rear blower(s)
https://www.thesamba.com/vw/forum/viewtopic.php?t=738697 _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
