front brakes
oprn
oprn is offline
PostPosted: Tue Mar 02, 2021 2:03 pm    Post subject: Re: front brakes Reply with quote
Parts are here, old drums cleaned up nice but... I need 6 bolts to put the backing plate on the spindles. 9mm x 1.25. Apparent none available, got a guy searching but he thinks no such thing available in Canada.
Don’t see them on the site I got the brake parts either.
We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
liquidrush
liquidrush is offline
PostPosted: Tue Mar 02, 2021 4:12 pm    Post subject: Re: front brakes Reply with quote
I was lucky, mine came with the bolts and they even have holes for safety wire as well. A quick google search finds some on ebay, titanium ones on amazon and others at fastenal. If push comes to worse and you can't find them you can always install thread inserts and go to a more conventional size. The spindles are cast iron and will drill ands tap easily. I suspect the bolts are out there though, look at porsche too, I think they used the same ones. As an example, you could use something like these, you'd enlarge and tap the hole, thread these in and you'd use a very common 3/8x24 bolt. You'd need six inserts, a tap and the correct size drill bit. To me this would be a last resort though.
https://www.mcmaster.com/90248A082/
oprn
oprn is offline
PostPosted: Tue Mar 02, 2021 7:20 pm    Post subject: Re: front brakes Reply with quote
Looks like I won't find any. I already have a tap and die in that size so i could try making them. Or like you say just drill out the spindle and tap it to a common size.
If I can't find a bolt in that size good luck finding an insert!
Scruffy Buggy
Scruffy Buggy is offline
PostPosted: Thu Mar 04, 2021 9:48 am    Post subject: Re: front brakes Reply with quote
My rail has rear discs and no fronts. I mentioned wanting to add fronts and it was pointed out to me that they had a tendency to lock up and take the steering away in the dirt. I guess that is why you see so many with rear brakes only. I decided to live with it since mine will most likely never see the highway.
I have never heard of or experienced discs locking up before drums. I think that analogy is reversed.
jimmyhoffa
jimmyhoffa is offline
PostPosted: Thu Mar 04, 2021 10:18 am    Post subject: Re: front brakes Reply with quote
I have front and rear brakes with an adjustable bias dual brake master cylinder. This has allowed me to play with the balance and also evaluate if I "need" front brakes. I determined that I do.
It is common that I am doing 80-85 MPH wide open and then the trail tightens and to dive into the trees. I am threshold braking as late as I am able. I find that a little bit of front brakes contributes massively to how fast I can stop, but I agree that I do like a heavy rear bias for the same reason of steering loss. I also like the feeling of the rears locking first coming in super hot to a corner in loose dirt, both so I can feel the back get loose and flick the wheel to "rotate" into the corner. The rears locking also serves as a warning that I am nearing front brake lockup as the rear starts to step out and chatter on the braking bumps into a corner.
1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
oprn
oprn is offline
PostPosted: Thu Mar 04, 2021 4:53 pm    Post subject: Re: front brakes Reply with quote
Ya that's fine in the dirt but you definitely don't want that kind of action on the street. Set up like that is ok for you because you are expecting it but put someone new behind the wheel and that kind of handling will spank them right quick. You rear brake only guys have obviously never tried going down a steep hill and stopping either. With the weight all shifted forward the rears do diddly squat in that situation!
The fronts on a normal car do the biggest part of the work because of weight transfer. Our rails with the rear engines and light fronts not so much but still it's a very significant amount. I am expecting my stopping distance to be cut close to 1/2. Much more than that on the down hills.
I think the no front brake fad started in the sand and there the drag of the sand stops you fast enough on it's own.
PhillipM
PhillipM is offline
PostPosted: Thu Mar 04, 2021 11:08 pm    Post subject: Re: front brakes Reply with quote
Yeah, our rail runs 50:50 static braking power, and has the valving set to shift that forward to 60:40 under heavy braking/high grip conditions. There's a lot of weight shift even on a rear heavy rail just from the high CoG.
oprn
oprn is offline
PostPosted: Fri Mar 05, 2021 5:03 am    Post subject: Re: front brakes Reply with quote
I like it! I would be very interested in knowing what bits you used to achieve this!
jimmyhoffa
PostPosted: Fri Mar 05, 2021 9:03 am    Post subject: Re: front brakes Reply with quote
For what it's worth I actually think my discs are a little more "locky" than my Type III rear drums were. I do have Carbotech 1521 pads in my Wilwood rear calipers which have known good cold bite. They're probably not as progressive as their higher heat pads though so that could be my issue there.
Just in case it was misunderstood, my general sentiment is that front brakes are absolutely necessary for any sort of safe driving outside of the dunes, as long as your are thoughtful of how you set the bias in the dirt and on asphalt. I adjust to favor the front more heavily when I drive my Chenowth to work on the street unless it's in the rain, then I got back to dirt settings.
oprn
oprn is offline
PostPosted: Fri Jul 09, 2021 5:23 pm    Post subject: Re: front brakes Reply with quote
I am finally getting back to adding front brakes to my sand rail. I installed all the brake parts a couple months ago, yesterday and today the brake lines got installed. this evening I will attempt to bleed them. The fresh engine is in, waiting on a new timing light as my 35 year old one bought the farm the other day and refuses to flash anymore.
Getting excited to try them out and see what the balance is like.
oprn
oprn is offline
PostPosted: Fri Jul 09, 2021 6:55 pm    Post subject: Re: front brakes Reply with quote
Putting in the brackets to anchor the flex lines was a bit more involved than I anticipated. First off the stock ones are made out of some pretty thin stuff, I am good with a little sturdier anchors and all I really had to work with was much thicker so some mods had to be made. I machined a wider grove in the flex hose ends to account for that.
Then positioning them on the frame took a lot of extra time and thought to get them so that the hoses did not bind or rub as the front wheels went through their full range of motion both vertically and lock to lock.
And finally bend up and install the brake lines to the master cylinder.
oprn
oprn is offline
PostPosted: Mon Jul 12, 2021 2:33 pm    Post subject: Re: front brakes Reply with quote
Well, well! Surprise, it looks like my fears of premature front brake lock up were unfounded. It's the rears that lock up first! Looks like I need to limit the pressure to the rears. The configuration is '64ish stock front drum drakes and '68 Bus rear drums, single piston '65ish Bus master cylinder.
oprn
oprn is offline
PostPosted: Tue Jul 13, 2021 4:45 am    Post subject: Re: front brakes Reply with quote
I am looking for recommendations on an adjustable brake pressure regulator. I see they are priced from $20 to over $120 for what appears on the outside to be the same thing. I don't mind paying good money for good parts as long as I am not paying extra for the same part due to a poor choice of venders. What has been your experiance?
Thanks!
dustymojave
dustymojave is offline
PostPosted: Tue Jul 13, 2021 6:52 pm    Post subject: Re: front brakes Reply with quote
Post up links for what you've shopped. Hard to help if I don't know which you're looking at.
My Chenowth buggy has an adjustable for the 4-lug EMPI disc brakes that were on the front, It was working well, until the spindle broke and took out the brakes with it. So I upgraded the spindles and the brakes don't fit them. I back-dated the front brakes to VW T1 drum brakes. But the car is waiting on new shafts for the front Fox coilover shocks and I can't test the brakes yet. I expect it will need an adjustment to the bias.
I can take a pic and share it in a couple of days.
Richard
SoCalBajas Member
oprn
oprn is offline
PostPosted: Wed Jul 14, 2021 1:15 pm    Post subject: Re: front brakes Reply with quote
I was looking Amazon and it shows this picture 5 times for 5 different prices. No manufacturer stated. Now I know they don't make their own parts...
oprn
oprn is offline
PostPosted: Sat Aug 07, 2021 12:30 pm    Post subject: Re: front brakes Reply with quote
Well the proportioning valve is a bust. Not letting any brake fluid through to the back brakes. I took it apart and here is what I found.
earthquake
earthquake is offline
PostPosted: Sat Aug 07, 2021 1:01 pm    Post subject: Re: front brakes Reply with quote
I was wondering if one of these would work for a proportioning valve...
https://www.surpluscenter.com/Brands/Prince-Mfg/1-...7960-4.axd
make sure to get one of their catalogs too
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
PhillipM
PhillipM is offline
PostPosted: Sat Aug 07, 2021 3:05 pm    Post subject: Re: front brakes Reply with quote
Doubtful, pressure valves work by getting the flow to expand into an area against the spring, not with a restriction orifice.
Buy a tilton one, they're cheap enough and well made.
oprn
oprn is offline
PostPosted: Sat Aug 07, 2021 5:25 pm    Post subject: Re: front brakes Reply with quote
eQ
No all that will give you is a time delay.
oprn
oprn is offline
PostPosted: Sat Aug 07, 2021 5:29 pm    Post subject: Re: front brakes Reply with quote
The annoying part is that I waited 2 weeks for this on and it will be another 2 weeks to get another no matter the brand. There is no local distributors that I am aware of.
Page 2 of 4
