Just did the walk of shame.
liquidrush
liquidrush is offline
PostPosted: Sat Jun 19, 2021 11:39 am    Post subject: Just did the walk of shame. Reply with quote
You know, when you're adjusting valves and go to start the engine up forgetting that the ratchet is still on the alternator nut. Yea, that one. I can't be the only one who's checked that box.
mark tucker
mark tucker is offline
PostPosted: Sat Jun 19, 2021 11:44 am    Post subject: Re: Just did the walk of shame. Reply with quote
well I can honnestly say no I have never done that!!! it was a aluminum AN rench.... Laughing
67rustavenger
67rustavenger is offline
PostPosted: Sat Jun 19, 2021 12:20 pm    Post subject: Re: Just did the walk of shame. Reply with quote
I left a 30mm wrench on the crank pulley bolt a few years ago. Started the engine and unthreaded the pulley bolt in 1 second. Shocked
It's not a shame to admit when you made an error that doesn't hurt anything or anyone.
The shame comes. If you don't learn from your error!
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
mukluk
mukluk is offline
PostPosted: Sat Jun 19, 2021 12:32 pm    Post subject: Re: Just did the walk of shame. Reply with quote
Loud, isn't it? Very Happy
Shane Tuttle
Shane Tuttle is offline
PostPosted: Sat Jun 19, 2021 1:02 pm    Post subject: Re: Just did the walk of shame. Reply with quote
Admitting you have will likely help prevent someone else from doing it.
IMO, that's one reason why this board exists.
Cusser
Cusser is offline
PostPosted: Sat Jun 19, 2021 1:12 pm    Post subject: Re: Just did the walk of shame. Reply with quote
Heck, even Mrs. Cusser got over that !!!!
I've NEVER done that, ABSOLUTELY. Because my VWs have generators.
MrWhoopee
MrWhoopee is offline
PostPosted: Sat Jun 19, 2021 1:15 pm    Post subject: Re: Just did the walk of shame. Reply with quote
Yes, but have you ever attempted to break the axle nut loose by pulling the bus forward with the cheater wedged against the ground, only to realize, as the back end rises off the ground, that you should have backed up?
Never happened to me, but someone told me......
Craig ('51 WASP)
Rosie ('63 Double Cab)
KTPhil Premium Member
KTPhil is offline
PostPosted: Sat Jun 19, 2021 1:59 pm    Post subject: Re: Just did the walk of shame. Reply with quote
Yep, it's been done before.
https://www.thesamba.com/vw/forum/viewtopic.php?t=740788
NJ John
NJ John is offline
PostPosted: Sat Jun 19, 2021 3:25 pm    Post subject: Re: Just did the walk of shame. Reply with quote
I turn at the crank and never just leave the wrench on between adjustments.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
earthquake
earthquake is offline
PostPosted: Sat Jun 19, 2021 3:28 pm    Post subject: Re: Just did the walk of shame. Reply with quote
I left the wrench on the draw bar of my mill once, never done it again.
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
Matthew
Matthew is offline
PostPosted: Sat Jun 19, 2021 3:40 pm    Post subject: Re: Just did the walk of shame. Reply with quote
eQ
For me that was lesson #1 on day 1 in the machine shop - NEVER under any circumstances leave the key in the chuck of the lathe. Your example is basically the same thing. That’ll wake you up really quick.
1965 Beetle sedan
Click to view image
KTPhil is offline
PostPosted: Sat Jun 19, 2021 3:52 pm    Post subject: Re: Just did the walk of shame. Reply with quote
Matthew wrote:
eQ
From the link I posted above... true story:
I had a jr. high metal shop teacher who terrorized students mercilessly. One of his diatribes was about poor Johnny who left the chuck key on the lathe and hit the power. He said it tore through his hand on its way to the far concrete wall. His last words were, "Please tell the students to never leave a chuck key in the chuck!" and then died from blood loss. Shop teacher had dark red paint on the floor for realism. I smugly thought the story was BS.
That is, until a few days later I noticed a real chuck key embedded into the top of the 20 ft high concrete wall in line with the radial direction of the chuck... for real!
evanfrucht
evanfrucht is offline
PostPosted: Sat Jun 19, 2021 4:35 pm    Post subject: Re: Just did the walk of shame. Reply with quote
The walk of shame is the actual act of walking and getting whatever just got flung across the shop...
That's how we got that expression
1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
FarmerBill Premium Member
FarmerBill is offline
PostPosted: Sat Jun 19, 2021 5:29 pm    Post subject: Re: Just did the walk of shame. Reply with quote
I knew a Saab mechanic that told me the factory procedure for breaking the crank pully loose on the 900 was to put a breaker bar and socket on the bolt, brace it against the body, and crank the starter, with the coil disconnected. He then described why that last bit was so important.
nextgen
nextgen is offline
PostPosted: Sat Jun 19, 2021 5:47 pm    Post subject: Re: Just did the walk of shame. Reply with quote
I had 78 non-turbo diesel rabbit that needed a head gasket. At 22 to 1 compression I knew there was no combustion chamber, the thickness of the gasket changed the compression.
Put in the new gasket, turn the key and KLUNK!!! I was one tooth off on the timing belt.
Destroyed a lifter and egg shaped the lifter bore.
I learned after that - don't start the engine until you hand turn the engine and make sure you have full rotation.
Actually I fixed that head and with another 100k miles.
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
nextgen
nextgen is offline
PostPosted: Sat Jun 19, 2021 5:49 pm    Post subject: Re: Just did the walk of shame. Reply with quote
Oh how about after draining your oil, you get distracted talking to a friend, and pure in 4 quarts, you look under the car and see a flood of oil. I forgot to put the drain plug back in.
PostPosted: Sat Jun 19, 2021 6:00 pm    Post subject: Re: Just did the walk of shame. Reply with quote
Yep, full revolution by hand should also be done on any engine that has been upside-down for a period of time to avoid hydrolocking. Don't ask me how I know this.
bsairhead
bsairhead is offline
PostPosted: Sun Jun 20, 2021 5:17 pm    Post subject: Re: Just did the walk of shame. Reply with quote
Adjusting valves on 1 and 3 then 2 and 4, fired up and oil is pouring on the floor mostly, some is landing in the 1-3 valve cover on the garage floor where I left it.
txoval
txoval is offline
PostPosted: Sun Jun 20, 2021 7:26 pm    Post subject: Re: Just did the walk of shame. Reply with quote
I thought that was when you girl friend walked out of your dorm in the early morning to avoid being seen...lol
FreeBug
FreeBug is offline
PostPosted: Mon Jun 21, 2021 5:07 am    Post subject: Re: Just did the walk of shame. Reply with quote
Bringing a '66 bus to the state inspection. The "expert" (that's what they call themselves) call me down into the pit... "It happens to all of us", he says, as he points out the 17mm wrench sitting on the steering box adjustment nut. Embarassed
And you haven't really felt the full painful depth of complete automotive shame...until you drive off from the gas station, with the nozzle still in the filler neck. It's not as bad as you would imagine, But the shame, the horrible realization that this will forever be part of my life story, the unspeakable level of embarrassment, the blank look on my face it's all something I will never manage to forget...
Hmmm...there is catharsis in confession;...i feel much better after getting that off my chest. Laughing
