Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Braukuche Samba Member
Posted: Fri Feb 12, 2021 9:24 am Post subject: Re: Anyone in the Buena Park CA? |
Curious, why do you need it? I believe it’s too early for your car. I’m pretty sure 59 had the imprint for the air cleaner. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Trylon Samba Member
Posted: Fri Feb 12, 2021 9:28 am Post subject: Re: Anyone in the Buena Park CA? |
Braukuche wrote: |
Curious, why do you need it? I believe it’s too early for your car. I’m pretty sure 59 had the imprint for the air cleaner. |
As you know I’m looking to put the engine back into manual-like appearance. The current shroud has clips for spark plug wires, so trying to get rid of the holes that will be left when I put in the wire tube. Thought that the 36hp for sale was the ticket. Perhaps you are saving me from yet another error.
So there are different 36hp shrouds? If you are referring to the indentation in the middle of the shroud, it’s doesn’t appear to be in the manual:
https://www.thesamba.com/vw/archives/manuals/4_59ghia/50.jpg _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Fri Feb 12, 2021 10:37 am Post subject: Re: Anyone in the Buena Park CA? |
The spark plug wire tube stopped in May, 1959so it depends on when your Ghia was built.
Of course I'm assuming Ghias changed at the same time, which may not be true but probably likely.
Not sure about the fan shroud indent.
On Beetles the air cleaner got larger, which required the indent.
Ghias use a Bus-style off set air cleaner so maybe not needed or used?
Bug 36hp with indent
_________________ How to Post Photos
Posted: Fri Feb 12, 2021 10:55 am Post subject: Re: Anyone in the Buena Park CA? |
EverettB wrote: |
Someone posted a pic of a 36hp shroud with an indent but no holes for the rubber spark plug wire holders. Maybe early 59? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
EverettB wrote: |
Birth Certificate gives date of December ‘58. So looks like the tube is going on.
I can see why the Beetles air cleaner required the indent; doesn’t seem to be needed on the Ghia though.
I’d be happy with “manual picture correct” _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Fri Feb 12, 2021 10:58 am Post subject: Re: Anyone in the Buena Park CA? |
Trylon wrote: |
EverettB wrote: |
I can see why the Beetles air cleaner required the indent; doesn’t seem to be needed on the Ghia though. |
VW didn’t make different engine components for Ghia except for the air cleaner set up which they shared with buses. Whatever bugs were using Ghia was using when it came to shrouds.. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
Posted: Fri Feb 12, 2021 11:01 am Post subject: Re: Anyone in the Buena Park CA? |
I was pretty sure that was the case. But it’s good that our car doesn’t need it.
Anyway... anyone in Buena Park with nothing better to do? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Fri Feb 12, 2021 11:04 am Post subject: Re: Anyone in the Buena Park CA? |
Trylon wrote: |
Anyway... anyone in Buena Park with nothing better to do? |
And the plot thickens and I have too much time on my hands...
This is from Ghia Girls gallery, a pic of her 59 convertible engine compartment. Notice indent and rubber plug wire holders.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
Posted: Fri Feb 12, 2021 11:06 am Post subject: Re: Anyone in the Buena Park CA? |
Braukuche wrote: |
Trylon wrote: |
A later ‘59? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Fri Feb 12, 2021 11:09 am Post subject: Re: Anyone in the Buena Park CA? |
Trylon wrote: |
Braukuche wrote: |
Trylon wrote: |
A later ‘59? |
Don’t know.
I’m not even sure when they made the transition to the newer style shroud. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
Posted: Fri Feb 12, 2021 11:11 am Post subject: Re: Anyone in the Buena Park CA? |
Well, since we are on the topic, can the shroud be replaced without dropping the engine? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Fri Feb 12, 2021 11:15 am Post subject: Re: Anyone in the Buena Park CA? |
Trylon wrote: |
Well, since we are on the topic, can the shroud be replaced without dropping the engine? |
What makes you think you have the wrong shroud?
If you go to the gallery and search Ghia coupe 1959 engine, there are plenty of examples with the same shroud you have.
Did someone tell you it was a 40hp shroud because it has rubber plug wire holders? If it has a hole for the choke cable it’s not a 40hp shroud. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
Posted: Fri Feb 12, 2021 11:18 am Post subject: Re: Anyone in the Buena Park CA? |
Braukuche wrote: |
Trylon wrote: |
Did someone tell you it was a 40hp shroud because it has rubber plug wire holders? If it has a hole for the choke cable it’s not a 40hp shroud. |
Someone pointed out that I needed the wire tube. Hard to say if the hole for the choke was there originally or not as it is ragged. Let me look... _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Fri Feb 12, 2021 11:25 am Post subject: Re: Anyone in the Buena Park CA? |
I know, throttle spring still wonky. Replaced it and don’t know why. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Fri Feb 12, 2021 11:35 am Post subject: Re: Anyone in the Buena Park CA? |
Pretty buggered up so who knows if it was original or not? 40hp shrouds also have an indented area for the top case bolt at the bottom of the shroud.
So it’s rainy out and I’ve got time to burn so I looked at a bunch of fotos in the gallery of 59 beetle and Ghia engine compartments as well as 58.
All the 58s had shrouds with no indent and metal tube.
It was a mix with 59s indicating that there was a mid year change. When the change was made would require delving into the KG parts book which is on this site and doing the research. I’m currently not that bored.
As for removing the shroud, yes you can do it without pulling the engine. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
Posted: Fri Feb 12, 2021 11:38 am Post subject: Re: Anyone in the Buena Park CA? |
Braukuche wrote: |
As for removing the shroud, yes you can do it without pulling the engine. |
Thanks for playing Brau!
So, as our car is currently advertised as December ‘58, let’s call it early.
Anyone in Buena Park CA? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
theghiagirl Samba Member
Joined: February 15, 2004 Posts: 537 Location: Near Portland, OR
Posted: Fri Feb 12, 2021 1:32 pm Post subject: Re: Anyone in the Buena Park CA? |
Braukuche wrote: |
Trylon wrote: |
Braukuche wrote: |
Trylon wrote: |
A later ‘59? |
Don’t know.
I’m not even sure when they made the transition to the newer style shroud. |
I thought that picture looked familiar. My old 1959 Pearl white cabriolet was built June 1959 and that was the original engine to the car. Also, at this point of production the doors, door glass, check straps and hinges had already changed to the newer style. |
Trylon Samba Member
Posted: Fri Feb 12, 2021 2:57 pm Post subject: Re: Anyone in the Buena Park CA? |
theghiagirl wrote: |
I think I know about the check straps— got the older metal springs.
But doors, door glass, and hinges? It would be interesting to see if I have those as well. Can someone elaborate? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Loren Samba Member
Posted: Fri Feb 12, 2021 3:45 pm Post subject: Re: Anyone in the Buena Park CA? |
Your December build Ghia has the early style glass, etc. My May 12th 59 build Ghia has the "newer" door glass, aluminum hinges, etc. I'm not sure when the transition started. |
