desertwrx Samba Member
Joined: January 18, 2007 Posts: 351 Location: Borrego Springs, CA
Posted: Fri Feb 12, 2021 4:57 pm Post subject: King Pin Wheel Bearing Spacer |
Putting in new front wheel bearings. Got 2 new wheel bearing spacers and they slide on. The ones I took off had an interference fit, which had to be knocked off. I have a feeling that the spacers will end up spinning with the seal. Any ideas? _________________ 2 fiberglass buggies, 2 non-running Corvair Sandrails!
SCCA |
mukluk Samba Member
Posted: Fri Feb 12, 2021 5:47 pm Post subject: Re: King Pin Wheel Bearing Spacer |
Lightly peen the edge near the inner bore to tighten the spacer's fit on the spindle, or install the spacer on the spindle with a liberal amount of medium strength thread locker. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Fri Feb 12, 2021 10:19 pm Post subject: Re: King Pin Wheel Bearing Spacer |
I’m thinking of good ol’ JB Weld. _________________ 2 fiberglass buggies, 2 non-running Corvair Sandrails!
SCCA |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Fri Feb 12, 2021 10:53 pm Post subject: Re: King Pin Wheel Bearing Spacer |
In my opinion, striking the spindle with a few sharp blows with a hammer/chisel, or blunt impacts with a ball peen hammer, to give something real for the bearing seat to bear against will be more substantial than a bit of glue. Once glue (both threadlocker and JBWeld) loses its grip, it's rather game over. _________________ Andy T.
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Feb 13, 2021 7:13 am Post subject: Re: King Pin Wheel Bearing Spacer |
I've been taught it's best to modify the part to fit the car rather than modify the car to fit the part. Someday you or the next custodian may come across the proper fitting spacers.
I would also say use Loctite rather than JB Weld but think Red or Green is better suited to the loads. Green is actually labeled as "Sleeve Retainer". _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
stevebaz Samba Member
Joined: March 14, 2008 Posts: 189 Location: El Monte CA
Posted: Wed Feb 17, 2021 11:43 am Post subject: Re: King Pin Wheel Bearing Spacer |
look up loctite 620 |
