Picture: How to differentiate a Syncro engine bay from a 2WD
sanchius Premium Member
sanchius is offline
PostPosted: Sat Feb 13, 2021 8:29 am    Post subject: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
I like using little clues, like the position of the rear quarter marker lights, to be able to tell at a glance whether a van is a Syncro or a 2WD. Now I know how to tell from an engine bay picture whether it is a Syncro or 2WD.
AFAIK there's no differences between a Syncro and a 2WD engine itself. However, because a Syncro engine sits an inch or two lower (different mustache bars & transmission mounts), the Syncro air intake boot is taller than a 2WD intake boot. I didn't appreciate this until ajdenette pointed it out to me. I had mistakenly used the longer Syncro intake boot in my 2WD that was making my AMM sit higher and ajdenette noticed the waffle pattern imprint on top of my AMM where it was touching the bottom of the engine bay cover.
As I was installing the correct 2WD intake boot, I thought I'd put the two boots roughly next to each other and document the difference since I hadn't seen this here before.
Other Syncro/2WD engine differences I am aware of are that Syncro engine cases have a little bead of caulk where they mate to the trans to keep water out and the forward exhaust header has a different bend coming off cylinder #1.
The Syncro years (2005-16) - The 2WD years (2017-23) - Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Your gold star membership keeps this awesome list going!
4Gears4Tires
4Gears4Tires is offline
PostPosted: Sat Feb 13, 2021 8:52 am    Post subject: Re: How to differentiate a Syncro engine bay picture from a 2WD Reply with quote
Next time I remove either the motor or trans, it will get a bead of RTV. I had no idea about the side markers either, looks like the Syncro is centered in that back panel and the 2wd is a few inches forward. Thanks!
I found out I have my snorkel inside the D pillar, but I am missing the hose that connects it to the intake and the dust/dirt separator. I will keep an eye out on the classifieds.
'87 Syncro
Ferric Oxyhydroxide Superleggera Edition
MarkWard
MarkWard is offline
PostPosted: Sat Feb 13, 2021 9:02 am    Post subject: Re: How to differentiate a Syncro engine bay picture from a 2WD Reply with quote
The thing about using RTV or any sealer is installing the transaxle is difficult enough without adding some goop. Also, today's sealers are also adhesives, making removing the transmission difficult. And if some water gets in there after it is sealed, the sealer may prevent if from draining. So, basically, the bellhousing needs to be completely water tight. Which is not easily accomplished. Certainly it can be sealed along with the engine case, starter etc.
Visual ques. The syncro has 2 metal coolant pipes that cross the engine in front of the intake boot and from behind, the muffler hangs below the valance enough that it looks like the van is wearing a dirty diaper.
D Clymer
D Clymer is offline
PostPosted: Sat Feb 13, 2021 9:06 am    Post subject: Re: How to differentiate a Syncro engine bay picture from a 2WD Reply with quote
A few other differences for you:
1. The connection of the airbox to the snorkel uses a rubber coupler on the Syncro vs a ribbed plastic one in the standard vans.
2. There is a small bellhousing vent installed in the access hole on the back of the engine case with a vent hose attached to it that keeps the bellhousing area from becoming hydro locked.
3. There is a cyclone dust catcher element inline between the snorkel and the airbox.
dhaavers
dhaavers is offline
PostPosted: Sat Feb 13, 2021 9:11 am    Post subject: Re: How to differentiate a Syncro engine bay picture from a 2WD Reply with quote
Not as easy to determine visually, but it's also fun to guess if the thermostat cover
bolts are seized into a plastic or metal housing...
Laughing Rolling Eyes Wink
- Dave
"The WonderVan"
sanchius is offline
PostPosted: Sat Feb 13, 2021 9:40 am    Post subject: Re: How to differentiate a Syncro engine bay picture from a 2WD Reply with quote
Yes, indeed.
Also, the Syncro has a cool pre-filter vortex debris separator, which fits nicely into a 2WD system as shown here.
In this pic you can see the incorrect tall syncro intake boot installed and the resulting waffle pattern on top of my AMM.
MarkWard
MarkWard is offline
PostPosted: Sat Feb 13, 2021 10:01 am    Post subject: Re: How to differentiate a Syncro engine bay picture from a 2WD Reply with quote
The Syncro boot is rare and could help another syncro owner out. Easy to place in the classifieds.
sanchius is offline
PostPosted: Sat Feb 13, 2021 10:18 am    Post subject: Re: How to differentiate a Syncro engine bay picture from a 2WD Reply with quote
Great point.
I've just offered it to ajdenette for free in appreciation for taking the time to originally make the post that called it to my attention.
If he/she declines, I'll put it in the classifieds to help sustain the Sanchius Westy Support Fund.
syncrodoka
syncrodoka is offline
PostPosted: Sat Feb 13, 2021 10:44 am    Post subject: Re: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
On a syncro, the 2 metal cooling lines bolted to the crankcase up high are dead easy to spot.
Deberius
Deberius is offline
PostPosted: Sun Feb 14, 2021 4:50 am    Post subject: Re: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
I don't know if already stated...
-) cooling pipe bridge across the trans mount
-) different thermostat housing and connections
-) different oil (stick) pipe length - stick is the same
-) one of the fuel lines are mounted different in the fire wall
1990 Caravelle GL 2.1 MV syncro -> 1990 Multivan Syncro 2.3 MV
Abscate
Abscate is offline
PostPosted: Sun Feb 14, 2021 5:10 am    Post subject: Re: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
Lim Delta —-> 0
(( syncro engine bay + Delta) -syncro engine bay)/ Delta
But you have to prove it exists , first
.ssS!
djkeev
djkeev is offline
PostPosted: Sun Feb 14, 2021 7:23 am    Post subject: Re: How to differentiate a Syncro engine bay picture from a 2WD Reply with quote
- Dave
Get yourself some ECK....... no worries about stuck bolts because they simply are not stuck!
https://www.aircraftspruce.com/catalog/cspages/eckCorrosion.php
Dave
Ghia
Vanagon
Beetle
Steve M.
Steve M. is offline
PostPosted: Sun Feb 14, 2021 9:30 am    Post subject: Re: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
isn't the Oil Fill Tube longer to make up for the Syncro engine being lower, the plastic part is probably the same, but the metal tube?
davideric9
davideric9 is offline
PostPosted: Sun Feb 14, 2021 10:02 am    Post subject: Re: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
The oil dip sticks are different. Syncro is longer and is identified with green plastic on the top 025115611B. 2WD has red plastic at the top. Which also means the dipstick tubes are different. syncro 025115629A, 2WD 025115609
1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012)
4Gears4Tires
PostPosted: Sun Feb 14, 2021 10:30 am    Post subject: Re: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
And if you don't have the Syncro dipstick and tube checking the oil in your Syncro is a bit irritating. Gotta get your whole hand in there!
'87 Syncro
Deberius
Deberius is offline
PostPosted: Mon Feb 15, 2021 12:57 am    Post subject: Re: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
It could be, that there was a change, but I've here two engines (2.1 95hp) from my syncro and a donor engine from a 2WD.
The tubes of the the oil dip sticks are different. The dip sticks are the same length...
djkeev
djkeev is offline
PostPosted: Mon Feb 15, 2021 5:41 am    Post subject: Re: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
I'd guess somewhere along the way, someone replaced a dipstick.
If the tube enters the case at the same point and the tube is longer...... well.....
Dave
Ghia
Vanagon
Beetle
Sodo
Sodo is offline
PostPosted: Mon Feb 15, 2021 7:43 am    Post subject: Re: How to differentiate a Syncro engine bay picture from a 2WD Reply with quote
[quote="djkeev"]
Thats the business end of HECK. Wink
It’s where it all happens.
....KTMs, GasGas, SPOT mtb
djkeev
djkeev is offline
PostPosted: Wed Feb 17, 2021 10:03 am    Post subject: Re: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
The 2.1 dipstick is 15 1/4” long ........
Here is the part number stamped on the 2WD dipstick.......
Dave
Ghia
Vanagon
Beetle
SyncroHead Premium Member
SyncroHead is offline
PostPosted: Wed Feb 17, 2021 10:22 am    Post subject: Re: Picture: How to differentiate a Syncro engine bay from a 2WD Reply with quote
This is right. The Syncro oil fill tube is longer.
Jim Davis
"A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote:
I have *no* idea what the previous owner carried in his Westy... angry donkeys?
