livethevanlife Samba Member
Joined: May 18, 2015 Posts: 204 Location: La Paz, Baja California Sur
Posted: Tue Jun 15, 2021 2:30 pm Post subject: Re: 2.1 to 2.2 WBX rebuild with Marco Mansi High Performance Heads. |
Any updates on the heads? _________________ www.LiveTheVanLife.com
www.VentureLibre.com
https://www.PeaceVans.com/baja
1991 Syncro Triple Knob Westfalia "Miki" 2.2WBX
1992 Syncro Triple Knob Tintop "Schnitzel" 1.9AAZ
1990 Syncro Rear Locker Doka Subi 2.2
1974 VW Thing 1835cc
1989 VW Carat |
Any updates on the heads? Performance gains? Thanks _________________ www.LiveTheVanLife.com
1989 VW Carat |
zx11pilot Samba Member
Posted: Tue Jan 04, 2022 4:20 pm Post subject: Re: 2.1 to 2.2 WBX rebuild with Marco Mansi High Performance Heads. |
Bump! Just reviving this thread. I'm curious too how the 'new' engine is doing after it's rebuild and Mansi upgrades! |
Posted: Tue Jan 04, 2022 4:22 pm Post subject: Re: 2.1 to 2.2 WBX rebuild with Marco Mansi High Performance Heads. |
felixbobcat Samba Member
Joined: December 13, 2017 Posts: 173 Location: Los Angeles
Posted: Wed Jan 05, 2022 8:24 am Post subject: Re: 2.1 to 2.2 WBX rebuild with Marco Mansi High Performance Heads. |
It's doing quite well. Good performance upgrade, not drastic but more power. I have yet to get another dyno-test to see how much it has improved however. One main improvement is his oil pump which does not leak! I've got the transmission out right now and will have a newer one in by the end of the week hopefully. Old automatic trans was having trouble going in reverse and shifting when cold. The only other problem was intermittent cutting out of the ignition which I finally traced to a bad ECU wiring harness. That will be replaced as well during this trans swap.
Once all this is done I will get another Dyno. It's only been what, a year? |
Posted: Wed Jan 05, 2022 8:25 am Post subject: Re: 2.1 to 2.2 WBX rebuild with Marco Mansi High Performance Heads. |
Posted: Thu Aug 25, 2022 7:21 pm Post subject: Re: 2.1 to 2.2 WBX rebuild with Marco Mansi High Performance Heads. |
Bump! Came across this thread and I think there's more to add to the story I'm hoping by now the heads and engine/tranny are back and all is running well. So, how are those heads working out now? Still happy with the investment? |
Posted: Thu Aug 25, 2022 7:22 pm Post subject: Re: 2.1 to 2.2 WBX rebuild with Marco Mansi High Performance Heads. |
