ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Tue Feb 16, 2021 6:32 pm Post subject: Rod side clearance |
Working on collecting parts for a 2332. There’s not a “real” vw machinist in town and I’m on a remote island in Alaska so everything gets shipped out. Trying to decrease the chance of having to send parts out to be machined. Looks like I’ll go with a DPR crank, seems to be less of a chance of something being wrong with them. I have access to a machine shop so I can use all sorts of precision measuring tools and will check everything..
So I realize nothing is known until you measure what you have. However I have noticed trends, the CB rod side clearance is typically on the loose side. Scats seem to be tight. I’ve seen this on a couple motors I’ve built, the CB side clearance is around .020” on my last motor. I wanted to notch the rods but didn’t because I don’t think with that much clearance it would do anything..
Any idea what other brands seem to be? Like AA H-beams or even empi? I do like that the scats have a 3/8” bolts though.. I’ll seek out a rod with ARP bolts and have seen there’s fakes out there..
I agree with having the side clearance on the loose end is better than too tight... the scats I have are super tight, almost scary. I’d have to remeasure as it’s been years since I built the motor (was a 2007cc with scat Ibeams, I just dug the rotating assembly out of storage). |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Tue Feb 16, 2021 6:39 pm Post subject: Re: Rod side clearance |
I'd like to have about .015" on a high powered engine, but .020 is a lot better than too tight.
On the one hand I don't LIKE how CB is making the rods too narrow, (I can do that myself perfectly well) but then again I know it's not something worth being overly concerned about.
Putting the oil groove in the rods is still a good idea, IF the cheeks of the crank actually cover the rod. A lot of older welded cranks they don't.
Have a look at that, maybe you did a lot of overthinking over nothing. |
Posted: Tue Feb 16, 2021 6:43 pm Post subject: Re: Rod side clearance |
modok wrote: |
Oh didn’t know that about the welded cranks. My CB rods were on a CB crank where the side clearance was excessive.
I don’t know how much oil flows out of the side of the rods. Just figured with such a gap the notch wouldn’t do a whole lot. I guess if it’s just pooring oil out of there a notch might direct a little oil. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
I can't help much here.
But the AA "H" beams are on the rather loose side of things too. Like you found, 0.020"
Have you considered the newer EMPI "I": beams? They appear to pretty stout! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Feb 16, 2021 6:45 pm Post subject: Re: Rod side clearance |
67rustavenger wrote: |
Have you considered the newer EMPI "I": beams? They appear to pretty stout! |
They do look pretty tough (pro series). I was considering them as well. I haven’t looked hard enough but would want to make sure they’re made for a 2” journal. I don’t mind clearancing a cam and the case is already clearanced (but I’ll check of course) so I don’t see why a I beam would be too tough. |
modok Samba Member
Posted: Tue Feb 16, 2021 7:35 pm Post subject: Re: Rod side clearance |
Nobody really knows what postition the rod will actually assume under what conditions.
You can't really go wrong with putting some grooves in the sides.
If it is rod is thrust against one side then the groove will help, if it isn't then the groove will not hurt. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Tue Feb 16, 2021 7:55 pm Post subject: Re: Rod side clearance |
I have scat h beams on a DPR crank, and it’s not loose.
If you don’t have a machine shop, have dpr fit everything and balance it...
One stop shopping, he can get you the bearings too, and check your rod clearances _________________ modok wrote:
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Wed Feb 17, 2021 7:00 am Post subject: Re: Rod side clearance |
Side clearance is really a Non-issue. It just allows the rod to float to wherever it wants to live. Has zero effect on oil flow or oil pressure.
As for notching: You can do it, but it doesn't really do anything.
The oil is squirting from the rod bearings 360deg all around and getting flung everywhere by centrifugal forces (mighty strong ones too).
Little notches cannot overcome the forces slinging it all over. |
c77owen Samba Member
Joined: July 07, 2017 Posts: 454 Location: Kansas City, MO
Posted: Wed Feb 17, 2021 8:09 am Post subject: Re: Rod side clearance |
ekacpuc wrote: |
They are VERY tough. I had a set that held up to the crankcase being completely drained of all oil at highway speeds, (sump drain plug came out after being worked loose from dragging it going in and out of the driveway) the bearing in number 4 pounded almost completely out of it and the rod, nor the bolts, ever let go. The side clearance on them is a little tighter than other Empi rods but not near as tight as the Scats. They make them in VW and Chevy journal depending on the length you need. Mine were 5.4" Chevy journal |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Wed Feb 17, 2021 8:49 am Post subject: Re: Rod side clearance |
Greg, go DPR and VW or Porsche journals. Tom is right, don't bother with notching. I like having the rod ends drilled like in this pic. The drilling is an extra $100. Dan
Posted: Wed Feb 17, 2021 8:58 am Post subject: Re: Rod side clearance |
Here is a mind blower for you. Joel Mohr told me about a engine he built with a 40hp crank and 1600 rods. Had a ton of side clearance, like .090" and he said it made no noise and ran many miles. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Wed Feb 17, 2021 9:09 am Post subject: Re: Rod side clearance |
Dan, out of curiosity, what is the purpose of the hole on the rod end? Weight reduction or oiling? |
Posted: Wed Feb 17, 2021 9:21 am Post subject: Re: Rod side clearance |
txoval wrote: |
Weight reduction, makes the counter weight more effective. Reduces center main pounding.
Dan |
mark tucker Samba Member
Posted: Wed Feb 17, 2021 11:39 am Post subject: Re: Rod side clearance |
I would be happy with .010~.012" and If I wanted more thats a eazy fix. |
txoval Samba Member
Posted: Wed Feb 17, 2021 1:01 pm Post subject: Re: Rod side clearance |
With my Scat 4340 forged crank and CB H-beam rods I have exactly .015” on each rod. Maybe a coincidence
When I used the CB Uni-tech rods they were .016-.018” |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Wed Feb 17, 2021 1:16 pm Post subject: Re: Rod side clearance |
It also depends on how high you wanna rev.
On a 8000 rpm engine I wouldnt assemble anything less than 0,015"
Factory specs on a stock engine is 0,1 mm (0,0039") But I have found (from disassembling loads of especially aftermarket rebuilds and VEGE engines, that that is on the low side. Those ALWAYS have cranks that are blued. So for that reason I do not assemble even a std plus engine with less than 0,008" (020 mm) _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
Posted: Wed Feb 17, 2021 1:53 pm Post subject: Re: Rod side clearance |
Thanks for the answers.
Dan I Honestly was just going Chevy for the better selection of rod bearings. I want to run clevite bi metal rod bearings. They don’t seem to make them for a VW journal. Motor won’t have a huge amount of HP so I doubt overlap will hurt. Porsche stuff is expensive..
Saw VW released a bulletin about notching T4 rods. I don’t see it doing anything with an excessive side clearance though.
The bearing is the restriction so I wouldn’t think side clearance would effect oil pressure. I do think if you wanted “squirters” it would affect that.
Doesn’t seem worth the time..
Thanks again. |
Posted: Wed Feb 17, 2021 2:58 pm Post subject: Re: Rod side clearance |
ekacpuc wrote: |
Thanks again. |
On the brgs I respectfully disagree, crank rigidity is more important. A well thought out oiling system will not need the very best brgs. On a high rpm race engine I would agree with you.
https://www.pelicanparts.com/catalog/SuperCat/14916/POR_14916_ENGMAN_pg2.htm#item6 |
Posted: Wed Feb 17, 2021 3:04 pm Post subject: Re: Rod side clearance |
Dan Ruddock wrote: |
ekacpuc wrote: |
Thanks again. |
The bi metals are nice for if the oil gets dirty. It’ll be full flow though.
I did look when I saw DPR had the Porsche option. Bearings can be found but I haven’t seen much in the way of rods. I’ll peak around again.
Looks like AA makes them. Didn’t know that.. I’ll have to dig up some info to make sure the 2.0 ones listed are correct.
https://www.thesamba.com/vw/classifieds/detail.php?id=1014113 |
Posted: Wed Feb 17, 2021 3:22 pm Post subject: Re: Rod side clearance |
Greg those rods are for T4 engines. Take a look at my ads. |
