Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Tue Feb 16, 2021 3:01 pm Post subject: Valve seat resource |
Does anyone know where I can source 33mm and 30mm valve seats ..ive emailed Wolfsburg west if they sold replacements for their ww/okrasa heads and they said nope ..like why do they sell parts but no replacement parts for their parts crazy anyways ..who has these valve seat sizes in stock .... |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Tue Feb 16, 2021 8:41 pm Post subject: Re: Valve seat resource |
maybe contact autolinea ? they make them for Wolfsburg west. interesting w/w could not tell you where to find them? Joe(mr.okrasa)Ruiz should know.
Steve _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Tue Feb 16, 2021 8:52 pm Post subject: Re: Valve seat resource |
Yeah I thought that was weird to about ww because they sell the okrasa 33/30 valves and springs retainers and locks but no valve seats lol you would think they would carry them but nope and like most places they don't wanna get them from their supplier who build their heads for them which again is weird since their buying all the other valve train parts for their head crazy .... |
Robert Chambers Samba Member
Posted: Wed Feb 17, 2021 9:56 am Post subject: Re: Valve seat resource |
I had the same problem last year. So, I found 32 mm seats. I talked to the machinist doing the work about the problem. He said because it was intake not exhaust it may work. As the valve will sit lower in the head it won't be affected as much because cold air and fuel are passing by it, not hot as an exhaust valve. I was concerned about the valve stem height. So I put a straight edge across the tops. It didn't make enough difference to be worried about. I have not put my engine together yet but I can post pictures if needed/wanted.
Stock 36 HP head the on left. 36 HP Head with Okrasa intake valves on the right. As I could not find 33 mm intake seats, 32 mm seats were used. _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117
Last edited by Robert Chambers on Tue Mar 02, 2021 8:41 am; edited 3 times in total |
Posted: Wed Feb 17, 2021 10:19 am Post subject: Re: Valve seat resource |
Robert Chambers wrote: |
I had the same problem last year. So, I found 32 mm seats. I talked to the machinist doing the work about the problem. He said because it was intake not exhaust it may work. As the valve will sit lower in the head it won't be affected as much because cold air and fuel are passing by it, not hot as an exhaust valve. I was concerned about the valve stem height. So I put a straight edge across the tops. It didn't make enough difference to be worried about. I have not put my engine together yet but I can post pictures if needed/wanted. |
Yes..post some pictures when you can ..it will help others if they come to this situation ... |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Feb 17, 2021 6:08 pm Post subject: Re: Valve seat resource |
Are these for Okrasa heads, or are you putting Okrasa size valves in stock heads?
I was told by someone who is no longer around, that you could usually install Okrasa intakes on stock seats. He said you had to port the ID larger, and that there was just enough meat left to cut the valve seat. Not sure what the repercussions of doing it this way is, or if you can do the exhaust the same way..
SD _________________ modok wrote:
FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Thu Feb 18, 2021 11:58 am Post subject: Re: Valve seat resource |
I bought custom valve seats from US Seal for my custom sized stainless Stainless valves on my Single port heads and had them installed at a local machine shop. cheap at couple bucks a piece, but the cost to install them was quite a bit.
https://ussealparts.com/cylinder-head-parts/valve-seats.html _________________ Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller |
