Slammed notckback front beam bracket modification
Albertoprop17
Albertoprop17 is offline
PostPosted: Wed Feb 17, 2021 6:50 am    Post subject: Slammed notckback front beam bracket modification Reply with quote
Hi guys, I have a 68 notchback quite slammed and the front beam brackets rub quite a bit.
Is there any mod that solves this problem by relocating the lower bolt and making the bracket flat on the bottom?
Thanks
'54 vintage speed beetle slow project
Visit my workshop site and leave a like:
https://www.facebook.com/talleresalacreu/
Jason37
Jason37 is offline
PostPosted: Wed Feb 17, 2021 2:47 pm    Post subject: Re: Slammed notckback front beam bracket modification Reply with quote
Here is how I did mine.
Started with a new set of brackets that were already shaved, cut the bottoms off, attached 1/8" thick steel using a spot welder. Cut the tabs off the frame head, using the stock bolts to secure these pieces tot he original mounts if I ever want to return to stock, or if the next owner ever wants to.
Then I made a bung for the new lower mount, before drilling I marked the location on the frame head and then adjusted the hole somewhat to give more tension. The bung was then welded into place. The bolt was a little tricky to get started, but it helped that I had countersunk the bung opening.
Bobnotch
Bobnotch is offline
PostPosted: Wed Feb 17, 2021 5:00 pm    Post subject: Re: Slammed notckback front beam bracket modification Reply with quote
Nice mod and solution.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
