Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Posted: Thu Feb 18, 2021 7:34 am Post subject: Removing snapper bleeder valves |
Hello, did a search but could not find a clear answer... but did anyone had any luck with removing a snapped off bleeder valve?
if so, any tips?
was thinking of taking the wheel cilinder apart so I could heat it a bit and let it cool off (potentially few times) to break it a bot loose and then trying with an extractor tool? But looking at the size of the bleeder not even sure if there exists and extractor for those tiny screws?
Or better to drill but how far can I drill and what would be the max size?
Thanks!
Peter _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Starbucket Samba Member
Posted: Thu Feb 18, 2021 2:13 pm Post subject: Re: Removing snapper bleeder valves |
Take the cyl. apart and soak it in a container of 50/50 mix of Acetone and ATF over night then tap it with a flat blade screw driver that will fit between the threads while twisting the screw driver counter clockwise. The threads are a loose fit as it uses the tapered seat at the bottom of the hole to seal so do not drill. Clean well with alcohol or brake cleaner and reassemble. |
RolandD Samba Member
Joined: January 15, 2017 Posts: 247 Location: Menomonee Falls, Wis
Posted: Thu Feb 18, 2021 5:53 pm Post subject: Re: Removing snapper bleeder valves |
If you have the product "Evaporust" there, it is even better. Yes, disassemble and soak. You might try an easy-out, or other left-handed tapered extractor.
Roland |
