glutamodo The Android
Joined: July 13, 2004 Posts: 26315 Location: Douglas, WY
Posted: Wed Feb 24, 2021 3:01 pm Post subject: Re: 1963 doors |
_________________ Andy T.
Busabill Samba Member
Joined: June 21, 2020 Posts: 51 Location: Rocklin California
Posted: Wed Feb 24, 2021 11:29 am Post subject: Re: 1963 doors |
mukluk wrote: |
For direct bolt on, doors from 1960 through 1966 will fit though '65/'66 will not have the "correct" size windows for a 1963 model car. You can fit 1956 through 1959 doors if you swap out the door latch mechanism to match your striker plate, or swap the striker plate to match the earlier door latch.
Door hinges are dimensionally the same regardless of whether they're attached with three or four screws, in fact the hinges continued at least for a while with four screw holes despite the body being changed so that there were only three. |
Thanks for the info!!!!!! |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Fri Feb 19, 2021 12:15 pm Post subject: Re: 1963 doors |
Door hinges are dimensionally the same regardless of whether they're attached with three or four screws, in fact the hinges continued at least for a while with four screw holes despite the body being changed so that there were only three. _________________ 1960 Ragtop w/Semaphores "Inga" |
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Fri Feb 19, 2021 10:06 am Post subject: Re: 1963 doors |
I’ve had a 64 and a 63 bug and thought the hinges were the same. 3 holes one side, 4 the other side of hinge. You can always remove pins and install outer hinge plates if you had to. Some of the big companies sell aftermarket hinge plates and parts. I’d get the 64 doors but would say post 61 (ice pick handles) to late 64 before windows got bigger etc. would work. |
Posted: Thu Feb 18, 2021 10:51 pm Post subject: 1963 doors |
Hello all! So I am working on a father-son project and the beetle is a 1963 and it's on a 1969 pan. I am searching for doors, which would be for a 1963. What year am I looking for for doors that will fit a 63? I found doors for a 64 but it looks like it has 4 bolts instead of 3 on the top hinge. Is that correct? Does anyone know which doors will fit a 63? Thanks ahead of time. |
