1980 911 Turbo Cabriolet?
marktodo
marktodo is offline
PostPosted: Sun Feb 07, 2021 4:35 pm    Post subject: 1980 911 Turbo Cabriolet? Reply with quote
A friend told me he was going to look in to buying this car. Hagerty and Excellance pricing donít mention . Did they make 80 Turbo Cabs ? Could this car be grey market. Itís halfway across the country a great color combination and a big price.
He asked for my help , but I know a lot more about 356 than SCís
Mark
Cornerlot
Cornerlot is offline
PostPosted: Fri Feb 19, 2021 1:00 pm    Post subject: Re: 1980 911 Turbo Cabriolet? Reply with quote
Not until 1985 for the 930 cabriolet. The VIN will tell the truth, if it contains a "93" then it started as a 930 coupe. But most likely it is a base 911SC targa cut down into a cabriolet and given the turbo widebody look, a once popular conversion.
unclebilly
unclebilly is offline
PostPosted: Sat Feb 20, 2021 5:36 am    Post subject: Re: 1980 911 Turbo Cabriolet? Reply with quote
Itís worse than that...
The first cabs came out in 83. If it is an earlier cab, it is likely a modified Targa. If itís a Targa, then it isnít a turbo.
1980 Turbos had the Turbo brakes and these still had floating rotors up front. Look at the position of the rear calipers. Are they in front of or behind the hub? A 78 on Turbo will have 4 piston 917 calipers mounted behind the hub, a 911 and 75-77 turbos had the same 911 calipers and trailing arms with the calipers mounted in front of the hub.
