knewknew Samba Member
Joined: July 06, 2007 Posts: 217 Location: Alexandria, VA
Posted: Fri Feb 19, 2021 8:11 am Post subject: Dealer License Plate/Tag Frame Restoration - Tutorial |
Hi all,
Just thought Id share the steps I took to restore a dealer tag that I came across. This was the original dealer for my car, so I am excited to have it. It was in pretty ratty shape and took a crack at a 'period correct' restoration. Since they were originally never painted that precisely, I figured that it was something I could handle.
I borrowed some supplies from the printmaking department at the college I work at: rubber roller and oil inks that typically used with the etching plates.
Before:
With Supplies:
Blue Background. For this step I used a small paint brush and thinned the ink (mineral spirits?), the ink is very thick so thinning is important in order to retain the textured background on the metal frame:
After the blue ink dried (took a few days), I applied the white ink on the lettering. I did not thin the ink during this step because I was afraid it would run off the surface of the letters:
Final Result. ...I should note that this ink is typically used on paper and is absorbed during the drying process, but when applied to metal it takes forever to dry, like a few weeks (not kidding). I even placed it in front of a space heater to accelerate the process, but it sure took its sweet time. In the future I would experiment with thinning the ink or using a different paint/ink:
_________________ 1970 Squareback |
Zundfolge1432 Samba Member
Posted: Fri Feb 19, 2021 8:42 am Post subject: Re: Dealer License Plate/Tag Frame Restoration - Tutorial |
Wow that turned out very nice. I’ve got a few of those that need attention |
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Fri Feb 19, 2021 11:35 am Post subject: Re: Dealer License Plate/Tag Frame Restoration - Tutorial |
Can you give up the pantone numbers on the blue and white used? _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Fri Feb 19, 2021 11:56 am Post subject: Re: Dealer License Plate/Tag Frame Restoration - Tutorial |
my59 wrote: |
Can you give up the pantone numbers on the blue and white used? |
Im guessing reflex blue or 2188 and the white might be just Opaque White.
If i was going to use an ink i would use a UV ink, it would dry right away if you had a UV lamp and hold up better in the long run. Just my two cents.
Great job knewknew looks' good. I have a couple i need to restore/fix _________________ F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
Patiently Impatient Samba Member
Joined: September 28, 2020 Posts: 128 Location: Tri-State
Posted: Fri Feb 19, 2021 12:01 pm Post subject: Re: Dealer License Plate/Tag Frame Restoration - Tutorial |
That's a cool plate frame, good job with it.
There's a show coming up soon in Asheville, isn't there? I was just down in NC for the Winter Volksfest in Raleigh, but I've been meaning to check out that Asheville show as well. |
Posted: Sat Feb 20, 2021 7:28 pm Post subject: Re: Dealer License Plate/Tag Frame Restoration - Tutorial |
Patiently Impatient wrote: |
Thanks! I would love to go to a show, however I am now 7 hrs north in Virginia. Asheville is such cool town though. _________________ 1970 Squareback |
