DanHoug Samba Member
Joined: December 05, 2016 Posts: 4799 Location: Bemidji, MN
Posted: Fri Feb 19, 2021 1:20 pm Post subject: VW 3051 ball joint tool dimensions |
if anyone out there that has the VW/Snapon 3051 ball joint tool and would be willing to measure it i'd like the following:
length:
OD:
ID one end:
ID other end:
_________________ -dan
www.thefixitworkshop.com |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Fri Feb 19, 2021 5:56 pm Post subject: Re: VW 3051 ball joint tool dimensions |
seeing i own a van these days i wanted that tool, but seems to be on intergalactic backorder
i made my own if you're interested in dimensions. she ain't pretty because i made it from scrap but it works fine _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Feb 19, 2021 6:03 pm Post subject: Re: VW 3051 ball joint tool dimensions |
aup. please! _________________ -dan
Posted: Fri Feb 19, 2021 7:25 pm Post subject: Re: VW 3051 ball joint tool dimensions |
ID 64mm
height 77 mm
OD 70mm
those are approximate, within +/- a mm
the cut out is about 49mm wide and 45mm tall
note: the ball joint stem will pass thru the hole a bit, but i have other pates with holes in them to make it work.
the ID is like a mm bigger than the OD of the ball joint. seeing i was a bit short on pipe you can see where i ground out the upper part to clear the knuckle. in a perfect world i would have added another 1/2-3/4 of an inch but it works just fine _________________
Jake Raby wrote: |
Brian wrote: |
galencurrington Samba Member
Joined: March 16, 2004 Posts: 426 Location: bowling green, ky
Posted: Fri Feb 19, 2021 7:45 pm Post subject: Re: VW 3051 ball joint tool dimensions |
skills@eurocarsplus wrote: |
i made my own if you're interested in dimensions. she ain't pretty because i made it from scrap but it works fine |
https://vw.snapon.com/SpecialToolsDetail.aspx?itemid=28450108
Shows in stock
I got mine off German eBay it’s still on its way. _________________ "asking and getting are two different things" |
Posted: Fri Feb 19, 2021 8:31 pm Post subject: Re: VW 3051 ball joint tool dimensions |
interesting, i couldn't order one a month or so ago, and tried again only to have it bounce back.
thanks for the tip, i will try again _________________
Jake Raby wrote: |
Brian wrote: |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Sat Feb 20, 2021 2:46 pm Post subject: Re: VW 3051 ball joint tool dimensions |
in April/May i'm going to need this tool. i hope to never need it again, but quality ball joints, even when quality, aren't so quality.
and so it goes. poo-tweet. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Posted: Sat Feb 20, 2021 3:30 pm Post subject: Re: VW 3051 ball joint tool dimensions |
i've ordered two TRW ball joints from those Latvian eBay rascals that have all the good parts. $32 each post paid. we'll see if i was resourceful or not. could NOT find any stateside with the cast bottom aka Lemforder or TRW.
i need a ball joint in hand to do some hardware store cruising... Schedule 40 and 80 2" black iron pipe looks promising. maybe weld a 40 and an 80 together for the different diameters.
they're on the same slow boat that my fuse block connectors traveled over on, but at least THOSE are in San Francisco port of entry now. _________________ -dan
RolandD Samba Member
Joined: January 15, 2017 Posts: 247 Location: Menomonee Falls, Wis
Posted: Sat Feb 20, 2021 4:27 pm Post subject: Re: VW 3051 ball joint tool dimensions |
Don't rule out a short piece of exhaust tubing No nee4d for a cut out, it is thin enough . I use an arbor press.
Roland |
Posted: Sat Feb 20, 2021 4:59 pm Post subject: Re: VW 3051 ball joint tool dimensions |
RolandD wrote: |
Roland |
really?! it didn't crush? i'll check that out. _________________ -dan
GreggK Samba Member
Joined: May 17, 2008 Posts: 898 Location: Colorado/Philidelphia
Posted: Sat Feb 20, 2021 6:16 pm Post subject: Re: VW 3051 ball joint tool dimensions |
Here is my attempt at taking some pictures with splits on almost every finger tip. Not as easy as I thought it would be.
Overall length.
Outer.
Thicker inner.
Thinner inner.
This one might help too.
Do notice I held a few of those measurements at an inch. Hope it helps.
Dabaron, I have the tool and press and I'm not far. Feel free to get in touch when its time. I also posted some pictures on this thread, end of page one. https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 _________________ '86 2wd Poptop transplant
FAS TDi engine swap. Peloquin LSD
https://www.thesamba.com/vw/forum/viewtopic.php?t=692188&highlight=slow+but+steady |
Posted: Sat Feb 20, 2021 7:33 pm Post subject: Re: VW 3051 ball joint tool dimensions |
this is really helpful, Gregg. thanks! i was thinking 2" black pipe was the same but this is way larger. _________________ -dan
GreggK Samba Member
Posted: Sun Feb 21, 2021 8:51 am Post subject: Re: VW 3051 ball joint tool dimensions |
Here are the dimensions using a caliper. I did my best to get it centered.
Here are the thin side.
And I think Skills is correct that the cut out is important too.
Here is the cut out.
I'll double check that I got the pictures under the correct locations. _________________ '86 2wd Poptop transplant
GreggK Samba Member
Posted: Sun Feb 21, 2021 9:39 am Post subject: Re: VW 3051 ball joint tool dimensions |
GreggK wrote: |
The first two pictures are the thick side. |
is this tool in Colorado or Philly... asking for a friend _________________ 1991 Vanagon GL Camper
GreggK Samba Member
Posted: Sat Mar 06, 2021 6:09 am Post subject: Re: VW 3051 ball joint tool dimensions |
this will be my attempt at tool 3051.. exhaust tubing another member had tried and it worked. i'm hopeful it will clear everything it needs to without the cut away.
will exhaust tubing be strong enough to press it in? we'll see! with a straight on push in the press it might.
Posted: Sat Mar 06, 2021 7:48 pm Post subject: Re: VW 3051 ball joint tool dimensions |
Yup, that looks familiar.
Roland |
Posted: Sat Mar 06, 2021 8:46 pm Post subject: Re: VW 3051 ball joint tool dimensions |
Roland! was that you that had used exhaust tubing? if so, thanks for the idea! _________________ -dan
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
