Chupa7hingy Samba Member
Posted: Thu Feb 25, 2021 8:54 pm Post subject: Re: 65 left side axle nuts |
ataraxia wrote: |
Chupa7hingy wrote: |
No-go on the bug nuts... too big. Looks like the hunt continues. |
How many do you need? I might still have a set or two. |
Thanks a bunch, but I think I found some at a local hardware shop. Those old hardware stores have lots of stuff hidden away. They ended up being M16 1.5 left hand jam nuts. Local place had 3 of them after blowing the dust off the drawer. Victory, after the self inflicted near disaster... |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Feb 25, 2021 7:19 pm Post subject: Re: 65 left side axle nuts |
Posted: Wed Feb 24, 2021 10:24 pm Post subject: Re: 65 left side axle nuts |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Mon Feb 22, 2021 9:48 pm Post subject: Re: 65 left side axle nuts |
Thanks. I think they are the same as the early bugs. Based on a listing by CIP1, they show the early bug part being for 61-5 Type-3, but this was the only listing I found. It might be right, as the early T3s had the smaller spindles.
I was able to clean the threads up pretty good, after about an hour with the chaser and a small triangle file. Might not be perfect, but even if the new nuts drag a little, it shouldn't be a problem. Lesson learned: driver's side is righty loosey Why couldn't the Germans have used a castle nut and cotter pin like everyone else? |
As far as I know, that part of the spindle didn't change thru the years. My own 65 has the later style clamp nut with a lock bolt. The problem you run into with the later style is you need the larger grease cup (for clearance). In my case, I'm running discs up front, but when I converted my 64 T-34 to discs, I ran the later style nut on it too (with the larger later cap).
I think it's the size of the nuts, washer, and grease cap as to why they didn't go with a right hand thread on the left spindle. At least they didn't do a Chrysler and use LH threaded lug bolts. Could you imagine how many drums would have been wasted by the threads being pulled out. I know a lot of Chrysler guys replaced a lot of LH threaded lug studs. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Feb 22, 2021 9:09 pm Post subject: Re: 65 left side axle nuts |
Posted: Sun Feb 21, 2021 2:23 pm Post subject: Re: 65 left side axle nuts |
You could always try contacting Joel (Boo_Koo_Z) in Washington state. He might have a couple he could throw in a bubble pack envelope. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Feb 21, 2021 8:58 am Post subject: Re: 65 left side axle nuts |
Your local Fastener Store should be able to order them out of their Dorman Catalog? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Feb 20, 2021 6:27 pm Post subject: 65 left side axle nuts |
Well, I was changing my bearings and didn't realize the drivers side is left hand thread... Didn't come loose, so I put my weight into the wrench and it got very loose, in a bad way. Had to cut it off. That's when I realized my mistake
So the inner nut sort of survived, but was galled pretty bad because it chased the galled threads of the spindle. I think I can salvage the spindle with a universal chaser my father in law has, but I am at a loss on the nuts. ISP shows them in their diagram of the spindles, but no part number listed. I think they are M16, bit I don't know the pitch (1.5 maybe?) Anyone know where these might be available in left-hand pitch? |
