Big Mike Cbad Samba Member
Joined: December 19, 2019 Posts: 73 Location: Carlsbad
Posted: Mon Feb 22, 2021 5:24 pm Post subject: Ghia wire harness rubber question 1963 |
Question about this small rubber boot in the passenger lower front fender area behind the splash guard where the wire harness comes out of the tube in the heater channel and runs up the fender behind the splash guard and into the front trunk area. Didn't see this rubber noted in the Ghia diagrams and have not seen it in any parts list for my car. Any idea where to find it and if there is a part number for it that I can't find? It's for a 63 Ghia vert and I'm running a new wire harness for it. Found all the other grommets, but can't seem to find this small rubber boot. Appreciate any help you can provide. _________________ 1963 ghia convertible project |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Tue Feb 23, 2021 8:51 am Post subject: Re: Ghia wire harness rubber question 1963 |
Thank you so much for the info. It's amazing the level of detail you know about these cars, very impressive. Really appreciate it. _________________ 1963 ghia convertible project |
Posted: Tue Feb 23, 2021 3:22 pm Post subject: Re: Ghia wire harness rubber question 1963 |
Will do, thank you. I did search all over the internet with no luck. You were correct it is hard to find. _________________ 1963 ghia convertible project |
St_Rand Samba Member
Joined: June 30, 2017 Posts: 40 Location: Lafayette Cali
Posted: Thu Sep 15, 2022 9:35 pm Post subject: Re: Ghia wire harness rubber question 1963 |
I am also looking for this part. I have my old one, but it is nearly falling apart. |
I am also looking for this part. I have my old one, but it is nearly falling apart. Any updates if anyone has found a source? |
obus Samba Member
Joined: March 08, 2001 Posts: 11069 Location: just off Garden State Parkway Exit 81
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sun Sep 18, 2022 2:34 pm Post subject: Re: Ghia wire harness rubber question 1963 |
Quote: |
anything here similar |
Forgot the metal hole diameter but these go up to 1" (25mm) just make your own inside hole.
https://www.ebay.com/itm/223617273753?epid=1503903...BMwIuLqOpg _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
