DaveVHS Samba Member
Joined: September 27, 2020 Posts: 31 Location: Brisbane QLD
Posted: Sun Feb 21, 2021 8:55 pm Post subject: '73 rear spring plate bush sizes? |
Does anyone know the rear bush sizes for a '73 coupe
I have the 26 9/16" torsion bar
I purchased lowered spring plates but need to purchase bushes and most websites have 1 7/8" or 1 3/8" bushes (smooth and knobbly) I'm not 100% sure what bushes I need to order.
I think it is the 1 7/8" (47mm) but appreciate any input |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 4796 Location: 37.5N 77.1W
Posted: Tue Feb 23, 2021 7:03 am Post subject: Re: '73 rear spring plate bush sizes? |
you will need 2 of the knobby and 2 of the smooth. The bushings do not fit the torsion bars. They fit the spring plate. Knobby on the inside, smooth on the outside, then cover plate. Measure the diameter of the spring plate that goes into the car and get that size. _________________ Daily driver: '69 Baja owned 41 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
In garage for rehab: '71 Beetle
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Tue Feb 23, 2021 6:26 pm Post subject: Re: '73 rear spring plate bush sizes? |
runamoc wrote: |
you will need 2 of the knobby and 2 of the smooth. The bushings do not fit the torsion bars. They fit the spring plate. Knobby on the inside, smooth on the outside, then cover plate. Measure the diameter of the spring plate that goes into the car and get that size. |
thanks, yeah I knew I needed both but turns out I was looking at racing urethane bushes not standard bushes which only come in one size anyway...I'm not racing so went with std |
