SSC Late Trans - Two Types
bugguy1967
bugguy1967 is offline
PostPosted: Mon Mar 01, 2021 11:40 am    Post subject: SSC Late Trans - Two Types Reply with quote
Asking a lot today.... I know.
I hear there's two single side cover transmission cases: one with a round boss around the drain plug, and one with a rectangular raised area around the drain plug, unlike any other trans. Can anyone confirm this? I haven't been able to find a pic. The rectangular one is supposed to be a sure-fire 3.88 r&p, with the best even gear spread (opinion).
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
pupjoint
pupjoint is offline
PostPosted: Mon Mar 01, 2021 11:54 am    Post subject: Re: SSC Late Trans - Two Types Reply with quote
yes there are 2 types and they both have the same ratios and 3.88, at least the ones i have seen 3.78, 2.06, 1.26, 0.93
b-man
b-man is offline
PostPosted: Mon Mar 01, 2021 12:04 pm    Post subject: Re: SSC Late Trans - Two Types Reply with quote
This one is supposed to be the strongest SSC case.
Internally likely the same as any other but Iím no expert.
1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle
NJ John
NJ John is offline
PostPosted: Mon Mar 01, 2021 12:17 pm    Post subject: Re: SSC Late Trans - Two Types Reply with quote
Iím sure either could be 3.88 or 4.12. The only true shortcut is to count the rotations in 2nd gear.
1973 standard, yellow, lowered, 3Ē narrowed front, 1600 w/ICTís(current combo)
11.41 et buggy. Long gone
http://www.cafepress.com/bugracing "MY OTHER CAR IS A DUNE BUGGY" stickers & more..
bugguy1967
PostPosted: Mon Mar 01, 2021 1:06 pm    Post subject: Re: SSC Late Trans - Two Types Reply with quote
Thanks! Been looking for that pic!
Ohio Tom
Ohio Tom is offline
PostPosted: Mon Mar 01, 2021 2:03 pm    Post subject: Re: SSC Late Trans - Two Types Reply with quote
The "offset rib" trans represents the latest model box.
Same ratios as the regular SSC box (3.78/2.06/1.26/.82).
AT code for 3.88rp.
The one big difference is the use of the Aluminum "dual rib" side cover. It's way stronger than other Magnesium side covers.
While the offset rib box has better strength around the oil hole, and the "rib" is close to the opening, they can still be cracked like any box.
They are supposed to be stronger, but I have not really found that to be true.
Now, if you were to weld a gusset on the offset rib box, that would be very strong.
I blew one up in 10 passes on my 300hp drag car.
Went back to the normal SSC case and she held up for many years.
vwracerdave
vwracerdave is offline
PostPosted: Mon Mar 01, 2021 4:52 pm    Post subject: Re: SSC Late Trans - Two Types Reply with quote
Here is the sticky that explains it. The 75 & later SSC cases are often called Z case. They are what you are asking about. There is nothing different inside then what was used in the earlier 73-74 SSC cases.
Sorry but that is not true. You have to look at the code to see what you got
"AT" SSC Bugs were 3.88 with .93 4th gear.
"AN" SSC Ghia were 3.88 with .89 4th gear. These were the tallest gear ratio.
"AV" SSC Thing were 4.12 with .93 4th gear.
"DC" SSC Type III were 4.12 with .89 4th gear
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
bugguy1967
PostPosted: Mon Mar 01, 2021 10:31 pm    Post subject: Re: SSC Late Trans - Two Types Reply with quote
Score! I had a 50% chance of getting a 3.88! Using it for road racing, so not overly concerned with shock loads.
QRP
QRP is offline
PostPosted: Mon Mar 01, 2021 10:40 pm    Post subject: Re: SSC Late Trans - Two Types Reply with quote
Does all this apply to type 3 as well??
I've got a SSC in my 73 squareback and have been wondering about it.
pupjoint
pupjoint is offline
PostPosted: Mon Mar 01, 2021 11:23 pm    Post subject: Re: SSC Late Trans - Two Types Reply with quote
i am very sure it has the 3.88. being in the US, i would send it to a transmission shop to get it gone thru and "upgraded" or maybe an ATB or LSD
Bruce
Bruce is offline
PostPosted: Sat Mar 06, 2021 1:39 pm    Post subject: Re: SSC Late Trans - Two Types Reply with quote
No, A Type 3 never got the later zig-zag case because Type 3 production ended in 73, 2 years before the late case appeared in mid 75.
madmike
madmike is offline
PostPosted: Sat Mar 06, 2021 2:45 pm    Post subject: Re: SSC Late Trans - Two Types Reply with quote
Thought that big ass funnel looked familiar, that's my trans Laughing thanks for the reminder I have to rebuild that one for my bug Laughing
65 Baja (sold)
68 VolksRod Coupe(sold)
Porsche/Laser 917(sold)
'Black Ice'Drag Buggy 1915 'Turbo'
Mid-Engine Dragster 2332 w/IDA's(gone)
'White Out' 76 Drag/Street bug 2276 'Turbo' 11:85 @113 MPH
70 MicroBus 2110 w/40 IDF's
I build my own Motor's & transmission's
