Turnswrenches Samba Member
Joined: May 02, 2019 Posts: 552 Location: Dawsonville, GA
Posted: Thu Feb 25, 2021 1:58 pm Post subject: Re: OIL temp sender location |
I'm putting mine in the drain plug hole on my next build.
_________________ 71 Superbeetle, stock 1641DP with Weber progressive
Railbuggy with 2332
Scat 4340 84mm crank
5.5 H-beams
Mahle 94mm pistons
AA jugs
Grant rings
CB2292 cam + straight cut gears
46/37.5 CNC Wedgeports
Pauter 1.5's
Big Beef intakes
44IDF's/38 vents |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Thu Feb 25, 2021 3:19 pm Post subject: Re: OIL temp sender location |
Man that’s a great idea....I can’t now as I already have the mag-x sump plate☹️ _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
Posted: Sun Mar 07, 2021 8:11 am Post subject: Re: OIL temp sender location |
67 Sunroof wrote: |
Man that’s a great idea....I can’t now as I already have the mag-x sump plate☹️ |
Yeah my plans changed when I decided to add a 4qt sump.
I may use the Joe Bence plate... or poke a hole in the filter housing for the temp sender and pressure sender. _________________ 71 Superbeetle, stock 1641DP with Weber progressive
Railbuggy with 2332
5.5 H-beams
Mahle 94mm pistons
AA jugs
Grant rings
Pauter 1.5's
Big Beef intakes
44IDF's/38 vents |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Sun Mar 07, 2021 9:48 am Post subject: Re: OIL temp sender location |
Good stuff in this thread Curious, is there any difference in mounting the sender under the distributor, at the end of the oil galley which carries oil past the stock sender and using the stock sender location? They almost seem like one in the same.
I like the idea of using either the sump plate or on new, universal cases the type 3 dipstock location. On my CB Aluminum case I have the option to use any of these locations except under the distrubutor since my case isn't drilled and tapped at that location. On my TF1 case it has that location as well as many others drilled and tapped so perhaps under the distributor will be an option when I get around to building either a turbo 2276 or NA 2387 around that case in the future.
Right now on my dinky engines (big bore 40hp and WW Okrasa 36hp) I am limited to using the oil relief port, which seems to work okay.
67 Sunroof thanks for this thread and good luck and keep us posted on your build.
Ted |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Sun Mar 07, 2021 7:07 pm Post subject: Re: Fuel temp sender location |
67 Sunroof wrote: |
My cb slim sump has a blank on one end to actually drill into if needed |
I doubt that you could find a worse place to put than this! There is NO oil circulation in the ends of an add on sump. I seriously doubt that the temperature there would reflect actual oil temperature at any time during engine operation. In fact if you drained a bit of oil from that location after a few thousand miles it would not surprise me to see it clean and new having never gone through the engine yet. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sun Mar 07, 2021 7:14 pm Post subject: Re: Fuel temp sender location |
ivkings4 wrote: |
In the filter housing also. |
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Mar 07, 2021 7:30 pm Post subject: Re: Fuel temp sender location |
Glenn wrote: |
ivkings4 wrote: |
I just poked a hole in mine and made 1/8npt threads to do exactly the same thing.
Railbuggy with 2332
5.5 H-beams
Mahle 94mm pistons
AA jugs
Grant rings
Pauter 1.5's
Big Beef intakes
44IDF's/38 vents |
Glenn Mr. 010
Posted: Sun Mar 07, 2021 7:34 pm Post subject: Re: Fuel temp sender location |
Turnswrenches wrote: |
Glenn wrote: |
ivkings4 wrote: |
Correct.
Member #1009
#BlueSquare |
Posted: Sun Mar 07, 2021 8:25 pm Post subject: Re: OIL temp sender location |
Would the top of the oil filter be a better place than where I had first considered?
I’m not sure the thread size and pitch of the initial place I thought about.
What about the oil pressure sender?
I was going to drill and tap the top of my Canton filter to be able to screw in the oil temp sensor...sound good?
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3293 Location: Rapid City, SD
Posted: Mon Mar 08, 2021 10:25 am Post subject: Re: OIL temp sender location |
These are also an easy option. They are meant for mechanical gauges, so you might need to strip and anodizing off, or run a separate ground wire for an electric sender. You just need to make sure the tip of the sending unit doesn't poke way down into the fitting and block the oil flow. These work best with pressure senders, and the temp sender in the filter base.
-8an gauge adapter. Summit has lots of different styles.
Brian _________________ www.type-emotorsports.com |
k@rlos Samba Member
Joined: October 04, 2012 Posts: 485 Location: Suffolk, England
Posted: Mon Mar 08, 2021 11:32 am Post subject: Re: Fuel temp sender location |
ivkings4 wrote: |
Your title says fuel temp. Typo. |
Yup filter housing for me |
vdubrookie Samba Member
Joined: May 12, 2017 Posts: 306 Location: Battle Creek,Mi
Posted: Mon Mar 08, 2021 2:33 pm Post subject: Re: OIL temp sender location |
How about in that plug just to the right of the oil pump. I've read on here that this is an ideal spot. Of course you have to tap the hole & buy an1/2" to 1/8" reducer. |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1597 Location: The South Zone
Posted: Mon Mar 08, 2021 5:56 pm Post subject: Re: Fuel temp sender location |
Glenn wrote: |
Glenn wrote: |
ivkings4 wrote: |
Correct.
Same here. Well, technically, the first oil pressure sensor (for the gauge) is in that spot, and the temperature sensor is on the top, right in front of the second pressure sensor (for the idiot light in the speedometer). This way, the temperature is measured before the filter, and the pressure is measured after the filter.
_________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
cptcrusty1 Samba Member
Posted: Wed May 03, 2023 9:44 am Post subject: Re: OIL temp sender location |
WHERE Do I FIND this!!!! I want one!!! it's PERFECT for what I'm looking for!!! I went to the CSP products web page and I'm not finding it. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
boxer74 Samba Member
Joined: July 03, 2011 Posts: 709 Location: Ontario, Canada
Posted: Wed May 03, 2023 12:27 pm Post subject: Re: OIL temp sender location |
Lingwendil wrote: |
Use a dual-out/in filter mount, and slip a sender in each of the unused ports- easy peasy-
Agreed.
_________________ 74 Super
84 Westy |
