Vanuber Samba Member
Joined: February 16, 2020 Posts: 411 Location: Virginia
Posted: Thu Feb 25, 2021 7:53 am Post subject: Van Cafe Rear Table Swivel Lock Kit |
I was surprised there were not any reviews of this product on Samba. I am considering buying it. Does anyone have experience with it? Thanks.
LINK - https://www.vancafe.com/RMW-TDL-p/rmw-tdl.htm _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
'02 Subaru Forester 2.5L |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Thu Feb 25, 2021 9:02 am Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
Looks like VL is offering one soon as well.
https://www.vanagonlife.com/vanagonshop/westy-table-leg _________________ 1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark |
Posted: Thu Feb 25, 2021 9:10 am Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
dobryan wrote: |
Have you seen the DIY version? There is a topic on the samba somewhere. I did it with a piece of PVC pipe and it works great. It works well if you want to DIY. |
Is this the thread you speak of? https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=60 _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
Posted: Thu Feb 25, 2021 9:14 am Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
That's great to know! Their stuff is very expensive and very impressive. I have their cupholder and love it. _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
Posted: Thu Feb 25, 2021 11:13 am Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
dobryan wrote: |
You can do something like this in a few minutes |
Thanks for the suggestion. So as I understand it, the PVC slides inside the existing table leg to keep it from flopping? Correct me if I am wrong.
I will definitely be considering a DIY solution but I want it to look a lot more polished.
I am still hoping someone can chime in that has experience with the Van Cafe solution. _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Thu Feb 25, 2021 11:50 am Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
Sorry, no VC kit experience.
The PVC inside is one way, and then there is another thread with the PVC outside. Keeps the leg from snagging anything on its way back down.
I'm going for both inside and outside on my future try. Best of both and super overkill. Like most of my DIY mods...
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
deadaheadub Samba Member
Joined: April 18, 2004 Posts: 787 Location: New Mexico
Posted: Thu Feb 25, 2021 8:29 pm Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
Love the PVC fix.
Simple and very effective, always the best way. And cheap, to boot!
On my to do list. _________________ Grateful daily,
Ryan
______________________________________
Past loves: '65 Bug, '70 Westy poptop, '64 Squareback project, '76 Westy tintop "Loose Lucy", '76 Westy tintop "Sharee"
Current:'84 Westy poptop "Ramblin' Rose- Rosie" w/ 2003 Subaru EJ25 conversion |
Posted: Fri Feb 26, 2021 9:34 am Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
dobryan wrote: |
The pvc is totally hidden when the table leg is on it. Totally polished. |
Yeah I am leaning toward the DIY approach the more I think about it and dig through that thread. The electrical conduit pipe looks the best IMO. Though Delrin or something to aid friction would be nice.
I also like the cotter pin with bushing approach shown below. It would be nice to set it at the swing-over-the-stove height and swivel freely without relying on the stock screw clamp to keep it up. I may try to do something along these lines.
'72 BMW R75/5
'71 BMW R75/5
Posted: Fri Feb 26, 2021 9:54 am Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
dobryan wrote: |
No need to use delrin for friction. The pipe is there to keep the table leg vertical, no friction needed. The knob when tightened holds the table leg in place just fine, and yes the cotter pin idea is great if you want to be able to freely swivel at a set height. |
I assume you'd want the OD of the pipe to match the ID of the table leg as closely as possible. Otherwise there would be some slop after raising it up.
Hence the friction issue with metal on metal. Does that make sense? _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
Posted: Sat Feb 27, 2021 2:28 pm Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
Newbie question: how do you remove the rear table leg from where it sits?
Not seeing what's holding it in. It swivels but won't pull up and out at all.
thanks _________________ Grateful daily,
Ryan
Posted: Sat Feb 27, 2021 4:21 pm Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
Vanuber wrote: |
dobryan wrote: |
Hence the friction issue with metal on metal. Does that make sense? |
It really does not have any discernible slop on mine and I am using the outer PVC pipe method. The PVC is not a snug fit to the metal table leg but it seems to work just fine. I'd not sweat it for the first try. You can always tweak it later if you desire. _________________ Dave O
The Western Syncro build
valvecovergasket Samba Member
Posted: Sat Feb 27, 2021 5:48 pm Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
Oh that looks slick... If it would provide good clamping to keep the thing from flopping around when underway it seems like it'd be worth the $$ .. but doesn't seem like that's part of the design intent necessarily
I too have their cupholders and really like them though _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Fri Mar 05, 2021 3:31 pm Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
Thanks to those that went before me I ended up going the DIY route for this.
After a trip to Lowe's, I found out 1" CPVC pipe is the same diameter as the stock plastic base cap that sits in the lower bracket (1" PVC is a different size oddly enough). The 3/4" CPVC pipe fits perfectly inside the existing base cap. CPVC is also a off-white kinda vintage color which is fitting. I sanded the printed lettering off, glued the two together and shimmed it with a bit of tape to create a solid friction fit with the base cap.
I wanted to use a cotter pin to lock the table in the over-the-stove position so I don't need three hands to adjust it. The cotter pin came from Lowes, but I needed a collar for it to ride on. I couldn't find anything in the right size or color, so I ended up having a part machined at a local shop out of brown Delrin.
It works like a champ and looks pretty OEM IMHO. If anyone is interested in the Delrin collar I can get the shop to machine more (not cheap however).
'72 BMW R75/5
'71 BMW R75/5
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Fri Mar 05, 2021 7:18 pm Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
Nice! That delrin collar looks great. |
jimf909 Samba Member
Posted: Fri Mar 05, 2021 8:23 pm Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
You're bringing this to an artform. Nicely done. _________________ - Jim
Abscate wrote: |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6351 Location: Honolulu,Hawaii and France
Posted: Fri Mar 05, 2021 11:10 pm Post subject: Re: Van Cafe Rear Table Swivel Lock Kit |
Vanuber wrote: |
How much would you like for the Delrin brown collar?
I`d love one!
Aloha! _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
