Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Posted: Mon Aug 16, 2021 11:33 am Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
does anyone know anyone rebuilding and shipping these older model inline 4 motors? |
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Mon Aug 16, 2021 3:55 pm Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
Longboardluv wrote: |
Gnarlodious wrote: |
NICE VAN! But why does it include a diesel oil pan in the back?
Is that the one from the repair yard you were looking at last week? |
that is the oil pan from the seized audi 2.0 that is in it. thanks! |
BTW - the Tiico conversion did not use an Audi block. If there *is* an Audi bubble block in there, someone swapped it out after the Tiico (Block in the Tiico is a 2LR and that is stamped on the block - not a US motor at all). Are you planning on switching in the Digifant from the Jetta engine? If you're not, and you want to keep the Motronic 9.0 EFI used by the Tiico, I'm pretty sure you'll need to use the Tiico distributor (which is not pinned in place, but is adjustable to set the timing - Tiico has no crankshaft position sensor). Techtonics Tuning has the adapter (https://techtonicstuning.com/main/index.php?main_page=product_info&products_id=1370). The 2LR is actually a 1.8L block and head with 2.0L crank and rods with 2.5L pistons. _________________ '86 Westy FAS GenV Turbo (Marvin) |
Posted: Tue Aug 17, 2021 6:48 am Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
khughes wrote: |
BTW - the Tiico conversion did not use an Audi block. If there *is* an Audi bubble block in there, someone swapped it out after the Tiico (Block in the Tiico is a 2LR and that is stamped on the block - not a US motor at all). Are you planning on switching in the Digifant from the Jetta engine? If you're not, and you want to keep the Motronic 9.0 EFI used by the Tiico, I'm pretty sure you'll need to use the Tiico distributor (which is not pinned in place, but is adjustable to set the timing - Tiico has no crankshaft position sensor). Techtonics Tuning has the adapter (https://techtonicstuning.com/main/index.php?main_page=product_info&products_id=1370). The 2LR is actually a 1.8L block and head with 2.0L crank and rods with 2.5L pistons. |
yes that is the case, the audi block that is in there was a replacement. I don't know what you are talking about in regards to the Digifant stuff. The plan would to keep everything computer/Tiico related and just rebuild the motor. I actually found someone in Houston that knows these quite well and it's heading to him soon. Going to take it out send it to a machine shop and get it going again. |
pjn_wyo Samba Member
Joined: April 22, 2019 Posts: 181 Location: Bellingham, WA
Posted: Tue Aug 17, 2021 9:17 am Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
I hope this one goes better than the last guy that knew these for you. |
Posted: Tue Aug 17, 2021 9:41 am Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
pjn_wyo wrote: |
let us hope! |
82westyrabbit Samba Member
Posted: Tue Aug 17, 2021 9:42 am Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
FAS in Maine will build and ship a engine to you. It’s a easy engine to overhaul any engine shop can Handel it. It’s also a engine you can overhaul yourself. John |
valvecovergasket Samba Member
Posted: Tue Aug 17, 2021 9:54 am Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
82westyrabbit wrote: |
It’s also a engine you can overhaul yourself. |
bears repeating.
super easy to refresh and extremely well documented online. _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Tue Aug 17, 2021 9:59 am Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
valvecovergasket wrote: |
bears repeating.
super easy to refresh and extremely well documented online. |
well that's good, he's got a machine shop in houston. it bears repeating that I have no time to do this myself, between the aircooled projects we work on and filming and editing and two kids, there's just not enough time in the day. |
Posted: Tue Aug 17, 2021 10:20 am Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
thats fair, there should be any number of watercooled shops that should be able to handle refurbing that thing.
theres really no need to ship in a motor from FAS thats fairly generic. _________________ MegaSquirt resource - SpitfireEFI.com
Posted: Tue Aug 17, 2021 10:23 am Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
theres really no need to ship in a motor from FAS thats fairly generic. |
you're probably right, I called around some here and it's surprising not easy to find one. Maybe I don't know what I'm doing. However, my new guy in Houston is really cool, I could tell right away he loves Vanagons and has a bunch of experience with them and even these motors. He also can get the AC going. I might have him do a couple more things and mount new tires on it. So it should be good! |
whobba Samba Member
Posted: Mon Jan 17, 2022 3:53 pm Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
whobba wrote: |
Helga is going to be jealous having to share her space and her guy with younger bus! |
yeah if i ever get it running! |
whobba Samba Member
Posted: Thu Aug 04, 2022 9:04 am Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
whobba wrote: |
How's the Vanagon project coming along Matt? |
Thanks for asking! Still in a holding pattern. |
whobba Samba Member
jlrftype7 Samba Member
Posted: Thu Aug 04, 2022 1:39 pm Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
whobba wrote: |
I thought you sold that Vanagon. Did not realize you still had it... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Thu Aug 04, 2022 3:47 pm Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
Quote: |
s a easy engine to overhaul any engine shop can Handel it. It |
Good thing the engine is in the Bach and isn’t Barochen _________________ .ssS! |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 784 Location: WestWorld Nanaimo BC
Posted: Thu Aug 04, 2022 4:51 pm Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
Abscate wrote: |
Good thing the engine is in the Bach and isn’t Barochen |
_________________ 1991 Double door pop top conversion |
Posted: Thu Aug 04, 2022 4:52 pm Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
ha ha ha you guys |
Posted: Mon Jun 05, 2023 3:34 pm Post subject: Re: OMG I bought a Vanagon what have I done? Build thread - Matt |
Today Ian pulled the motor trans. We are now on the hunt for a good ABA 2.0 to swap out the short bock and reuse the head..
