Thing brake light problems
Panheadguy
Panheadguy is offline
PostPosted: Sat Feb 27, 2021 9:49 am    Post subject: Thing brake light problems Reply with quote
Hello, I am in FL Keys and a police officer was kind enough to notice my brake lights aren't working. All I have is a test light and a wife to pump the brakes if I ask nicely. I opened the dash and found I had power to both the black and red wires on the system warning light. When the pedal is depressed The red wire goes dead. Can anyone steer me to a fix? Sad
The police never think it's as funny as I do...
mondshine
mondshine is offline
PostPosted: Sat Feb 27, 2021 11:03 am    Post subject: Re: Thing brake light problems Reply with quote
This thorough explanation of the Thing brake electrics might help.
Good luck, Mondshine
https://www.thesamba.com/vw/archives/info/wiring/D...0Light.pdf
Panheadguy
PostPosted: Sat Feb 27, 2021 11:35 am    Post subject: Re: Thing brake light problems Reply with quote
Thanks Mondshine. I reviewed the info. My light is not working at all never has. The tiny indicator bulb may be burned out. Regardless, the brakes are fine but my brake lights don't come on..
Panheadguy
PostPosted: Sat Feb 27, 2021 12:59 pm    Post subject: Re: Thing brake light problems Reply with quote
Even if the warning light is inoperative, the stop lights should still work? Correct?
kenj06
kenj06 is offline
PostPosted: Sat Feb 27, 2021 8:01 pm    Post subject: Re: Thing brake light problems Reply with quote
Correct. The warning light will not affect the brake light operation.
I'll assume you have checked fuses and bulbs. There is a connector by the brake fluid reservoir that I have had separate and cause the brake lights to go out.
Its a pain to get to and even more difficult to work on.
Sorry, that's the best picture I have but should give you a general idea where its at.
Panheadguy
PostPosted: Wed Mar 03, 2021 7:33 am    Post subject: Re: Thing brake light problems Reply with quote
Thanks Kenj,
I have determined that there is power at the connection you show. I assume that power is going to the two brake light switches but not to the lights. Next I will remove the gas tank and check the switches and connections there.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Wed Mar 03, 2021 7:51 am    Post subject: Re: Thing brake light problems Reply with quote
Clean all connections & coat with dielectric grease & clean ground connections to taillights. A disappearing voltage issue is usually traced back to a poor connection at the fuse panel, either the fuse or spade terminals.
The plug connections at the brake switches were the culprit on my Ghia.
wbailey2112
wbailey2112 is offline
PostPosted: Thu Mar 04, 2021 5:43 am    Post subject: Re: Thing brake light problems Reply with quote
Panheadguy wrote:
Thanks Kenj,
You do not need to remove the gas tank to get to the switches on the master cylinder. Just remove the left front wheel (assuming your Thing is LHD) and you can access it through the opening in the back of the wheel well.
I had to replace my switches two years ago. Was able to buy them at NAPA but had to go to the local NAPA distribution center to pick them up if I wanted them the same day (my local store did not stock them).
'74 Thing
'83 Westfalia
Ian Epperson
Ian Epperson is offline
PostPosted: Thu Mar 04, 2021 1:07 pm    Post subject: Re: Thing brake light problems Reply with quote
Have you tried spinning your fuses? Sometimes corrosion in the fuse box can allow a small amount of current enough to show 12v on a meter, but not enough to light the bulbs.
It's a quick check - just pop open the fuse box and spin each fuse in place and see if your problem goes away. If it does, pop each fuse out and clean up the terminals and brush off the end of each fuse. A light coating of dielectric grease can help out too.
VW-181 shirts and stickers.
http://ian.epperson.com/vw
JBall8019
JBall8019 is offline
PostPosted: Tue Apr 20, 2021 3:39 am    Post subject: Re: Thing brake light problems Reply with quote
I recently had brake light issues that frustrated me. After you check your fuses, grounds and brake light switches, take a very close look at your tail light housings. Make sure the plastic sockets in the tail light housings are positioned correctly or aren't damaged.
John
Madkel
Madkel is offline
PostPosted: Tue Apr 20, 2021 11:34 am    Post subject: Re: Thing brake light problems Reply with quote
I had some issues with my tail lights that JBall described.
the backing plate for the tail light bulb sockets had broken and were not making contact with the bulb. pulled them off the car and used some epoxy to fix the broken area around the socket. then a careful insertion of the bulb to make sure. everything works fine now.
1973 Type 181 - 2016cc - 091 trans
ITS A FUN RIDE!
Joe 20
Joe 20 is offline
PostPosted: Tue Apr 20, 2021 7:48 pm    Post subject: Re: Thing brake light problems Reply with quote
I usually have no helper either. I use a board to press on the pedal with nail driven into it so I can snug it up on the drivers seat front. I also have a mirror I can set up to see the lights when I'm checking wires, fuses etc. Works fine. Just FYI.
"Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy
