Solar wiring on a tintop
uther
uther is offline
PostPosted: Thu Mar 04, 2021 11:21 pm    Post subject: Solar wiring on a tintop Reply with quote
I've got an 89 Syncro tintop and I'm adding two solar panels on the roof. This must be a fairly common thing to do and I've looked around but haven't found any info on how to get the wiring from the roof to the controller inside. I'd rather not drill a hole in the roof if I can avoid it. Does anyone have any suggestions?
Thanks,
r
Rowan
89 Syncro - Juniper Mackenzie
09 Honda Fit - Finnie
17 Ram ProMaster - John Hordle
0to60in6min
0to60in6min is offline
PostPosted: Thu Mar 04, 2021 11:30 pm    Post subject: Re: Solar wiring on a timtop Reply with quote
Thru the D-pillar air intake vent into engine bay and toward the battery?
erste
erste is offline
PostPosted: Thu Mar 04, 2021 11:36 pm    Post subject: Re: Solar wiring on a timtop Reply with quote
If your wires are thin enough you should be able to run them through the front door, near the B pillar. Another route is down through the vent in the D pillar, but that can make for a long run depending on where your charge controller is.
I've run mine through the cracked driver's side slider window for a few years now and that's obviously not ideal, but it worked when I was installing them and I haven't fixed it yet.
Timwhy
Timwhy is offline
PostPosted: Fri Mar 05, 2021 12:33 am    Post subject: Re: Solar wiring on a timtop Reply with quote
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
4Gears4Tires
4Gears4Tires is offline
PostPosted: Fri Mar 05, 2021 8:07 am    Post subject: Re: Solar wiring on a tintop Reply with quote
I ran mine through the D pillar vent as well.
'87 Syncro
Ferric Oxyhydroxide Superleggera Edition
