AustinA_43 Samba Member
Joined: January 22, 2019 Posts: 20 Location: Maryville Tennessee
Posted: Fri Mar 05, 2021 10:11 pm Post subject: Wagon west 2.5” lift spindles and spring plate questions |
Is anyone on here running wagon west 2.5” lift spindles and plates? I’m wanting to buy a set to put onto my 68 bay window bus and I was wondering what’s needed to be done to make them work properly. I know I’ll need longer axles but will I be able to use stock length shocks too? The bus currently is raised with beam adjusters up front and reindexed torsion bars in the rear but I’d like to have a bit more clearance as I am going to be doing a lot of off-pavement driving when I’ll be going through South America on the pan American Highway. Plan on calling wagon west Monday to ask directly but was just wondering if anyone on here have used there stuff
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Mar 05, 2021 11:20 pm Post subject: Re: Wagon west 2.5” lift spindles and spring plate questions |
I have no idea because I neither raise or lower buses. I will suggest that this has been done before so what you need to do is learn from other people who have already made expensive mistakes. As Busdaddy said this past week somewhere, every time you make a change it affects other things as well. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Sat Mar 06, 2021 10:38 am Post subject: Re: Wagon west 2.5” lift spindles and spring plate questions |
I don’t see why you wouldn’t use it with its stock height. My bus was sagging in the rear when I got it (it was sitting for 10+ years), I raised it up like 6* (I think) installed new bushings, KYB gas-a-just shocks and it sits nice and lever now.
I live in southwest Colorado and drive in the mountains everyday. Often we are on forest service and 4x4 roads and I never have a problem with clearance even with my deep sump hanging down. Now I’m not trying to go 4wheeling on the Amasa Back trail in Moab, but for everything else I find a well sorted stock suspension works nicely.
I’d be spending my money on a nicely built stroker with a rebuilt transaxle and a Kennedy clutch. But everyone is different. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Sat Mar 06, 2021 11:08 am Post subject: Re: Wagon west 2.5” lift spindles and spring plate questions |
This guy would be a good source
https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=8901
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Sat Mar 06, 2021 7:39 pm Post subject: Re: Wagon west 2.5” lift spindles and spring plate questions |
AustinA_43 wrote: |
Is anyone on here running wagon west 2.5” lift spindles and plates? I’m wanting to buy a set to put onto my 68 bay window bus and I was wondering what’s needed to be done to make them work properly. I know I’ll need longer axles but will I be able to use stock length shocks too? The bus currently is raised with beam adjusters up front and reindexed torsion bars in the rear but I’d like to have a bit more clearance as I am going to be doing a lot of off-pavement driving when I’ll be going through South America on the pan American Highway. Plan on calling wagon west Monday to ask directly but was just wondering if anyone on here have used there stuff |
I took my stock height 77 Westfalia platform and added the WW lift kit. I also have 15" 215 off road tires on ET 37, stock is 38. I did need to get longer rear shocks. The rear lift plate changes the distance from mounting points for the shock. I ended up with KYB 344079. You don't need fronts as the mounting point for the shock is on the arm not the spindle assembly.
About a 3" net in center hub to bottom of dog leg under the door. Overall lift is like 6".
The drive shafts are EMPI floating ones that have no C lip pin holding them.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
honkadori Samba Member
Joined: September 02, 2020 Posts: 23 Location: los angeles
Posted: Thu Oct 21, 2021 8:18 am Post subject: Re: Wagon west 2.5” lift spindles and spring plate questions |
i also just ordered the lift kit from wagenswest. raised spindles and plates.
@notchboy read your entire thread about how you met your bus. very nice read!
any chance you can send me a link to the cv joints and drive shafts you are using? also. before you switched to longer shocks you said you used shock extensions in the back. where did you get those from?
thanks! |
Posted: Thu Oct 21, 2021 11:37 am Post subject: Re: Wagon west 2.5” lift spindles and spring plate questions |
honkadori wrote: |
thanks! |
I got the CV's and shafts from WagensWest. They are offroad EMPI brand. Not sure what the specs were.
The shock exstensions were a fail. Didnt work. I ended up buying some longer throw shocks. I also bought four - only need two for the rear as in the front the spindle has all the lift in it. _________________
t3kg wrote: |
1964 1500 S
Posted: Thu Oct 21, 2021 2:14 pm Post subject: Re: Wagon west 2.5” lift spindles and spring plate questions |
thanks jason! ill ask nate from wagenswest if he can get the cv joints for me. |
VOLTWAGEN Samba Member
Joined: May 24, 2014 Posts: 118 Location: Perth, Australia
Posted: Thu Oct 21, 2021 6:20 pm Post subject: Re: Wagon west 2.5” lift spindles and spring plate questions |
Will keep an eye on this thread as I'm looking to raise mine as well
Currently standard suspension with 215/75/15 BFG AT's but looking for a little more lift, the back end is sagging a little, even lifting that back to normal would help a little
I was just going to index the rear, but I'm guessing the plates would be better for it |
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1196 Location: Vancouver, BC
Posted: Tue Jul 18, 2023 5:54 pm Post subject: Re: Wagon west 2.5” lift spindles and spring plate questions |
With the raised spindles, did you have to buy longer brake lines or upgrade anything else? Or does everything just bolt on to the new spindles as is?
I'm running 225/75/16 Load E Goodyear Wranglers on the back and need more clearance to add them on the front too. The WW spindles are pricey but I like the raised look and with the belly rad set up on my swap, the extra clearance will be nice as we get a lot of wash out areas along the FSRs that we frequent. _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
