djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sat Mar 06, 2021 5:33 am Post subject: Emission testing in Pennsylvania |
I'm rebuilding my 90 in Pennsylvania.
It will stay here and be plated in Pennsylvania.
I'm an ex Licensed State Vehicle Inspector for Pennsylvania, though it has been a while. My license expired and standards have changed.
I was concerned about getting the exhaust sniffed and if this old unit would pass muster.
My PO licensed the unit as an antique, Antique plates require a safety check but no emission testing, my 86 was licensed as an antique in NJ for the use was extremely limited and it exempted emission testing..... no inspection of any kind actually in NJ.
I'll be driving this 90 daily and the Pa antique plate guidelines suggest allowed use of about 1 day a week.
That option is out for me!
I did some searching and found that Pennsylvania, as many States now do, rely heavily on OBDII readings for emissions.
The actual testing requirements vary by County through the State. It is broken into regions. Some regions are still sniffing tail pipes (such as Pittsburgh)
Happily for me, my County (Berks) requires a safety inspection for older vehicles, (no problem, I plan to roll safe), a gas cap test, (new gas cap, bring it on!) and a visual compliance check.
The visual check is for emission related items. Catalytic Convertor, EGR valves, vapor recovery, etc.
Whew!
My worry was for naught!
Life IS Good! _________________ Stop Dead Photo Links how to post photos
Ghia
Vanagon
Beetle
revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Sat Mar 06, 2021 6:27 am Post subject: Re: Emission testing in Pennsylvania |
Quote: |
My PO licensed the unit as an antique, Antique plates require a safety check but no emission testing, my 86 was licensed as an antique in NJ for the use was extremely limited and it exempted emission testing..... no inspection of any kind actually in NJ. |
Actually, in PA, antique plates do not require a safety or emissions test. Classic plates require a safety inspection, but no emissions.
http://www.dot.state.pa.us/public/dvspubsforms/BMV/BMV%20Fact%20Sheets/fs-ant.pdf
And yes, in your county (Berks) an OBD test would be required if the vehicle is 1996 or newer. You are correct that your 90 van would receive a gas cap test and visual anti-tampering for emissions equipment.
http://www.drivecleanpa.state.pa.us/changes/fs_sc.pdf _________________ 1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark |
tjet Samba Member
Posted: Sat Mar 06, 2021 4:13 pm Post subject: Re: Emission testing in Pennsylvania |
I just bought a new gas cap for my 85 for emissions testing purposes. I've failed smog tests enough for leaking caps that I always keep a fresh one in the glove box.
It was $11. I think it's German made too.
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Sat Mar 06, 2021 4:22 pm Post subject: Re: Emission testing in Pennsylvania |
tjet wrote: |
It was $11
How are they doing the pressure test with your own cap on? My local SMOG station has an adapter they fit instead of the cap, and then they pressurise to a few PSI. It has to not lose a certain amount within five minutes. _________________ Jim Crowther
Vespa GTS 300 |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Sat Mar 06, 2021 4:47 pm Post subject: Re: Emission testing in Pennsylvania |
you can't retain the antique plate if you plan to daily or mostly drive it. it's for "occasional" use only - one day a week. unless you are me and live in Philly.
if you do retain the antique registration, that plate is your's, it stays with the vehicle. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
kamzcab86 Samba Moderator
Posted: Sat Mar 06, 2021 4:53 pm Post subject: Re: Emission testing in Pennsylvania |
fxr wrote: |
How are they doing the pressure test with your own cap on? My local SMOG station has an adapter they fit instead of the cap, and then they pressurise to a few PSI. It has to not lose a certain amount within five minutes. |
Here in AZ, the pre-OBD cap itself is tested off the vehicle. _________________ ~Kamz
2016 Golf GTI S
jimf909 Samba Member
Posted: Sat Mar 06, 2021 5:51 pm Post subject: Re: Emission testing in Pennsylvania |
WA state has terminated all emissions testing. 25 year old cars were previously exempt but I was surprised to hear my newer cars don't need a test either. _________________ - Jim
Abscate wrote: |
Abscate Samba Member
Posted: Sun Mar 07, 2021 3:57 am Post subject: Re: Emission testing in Pennsylvania |
We used to sniff in urban counties in NY but now most just do an OBD check engine light both ready and off. Much easier and equally effective _________________ .ssS! |
Posted: Sun Mar 07, 2021 4:50 am Post subject: Re: Emission testing in Pennsylvania |
Back in the late 60’s we may have mumbled and grumbled about emission testing being implemented.
The new cars had an air pump bolted to the engine and air injection tubes into each cylinder. They were in the way and sapped power!
Throughout the 70’s and 80’s engines became almost undriveable with the emission controls.
Then the late 80’s and 90’s came along and engine management technology took off!
The engines began to run better, fuel mileage got better, more power from smaller displacements, they ran so clean that oil lasted longer longer and engine life expectancy soared!
On my Dad's 56 Chevy he was THRILLED that he rolled over 100;000 miles without a rebuild!
Today?
We're pissed if an engine gives up before 200,000 miles!
Automobile engine technology and fuel management is one thing that actually improved as the years ticked by.
Today, you are hard pressed to commit suicide with a modern automobile in a closed garage. They just don't emit enough poisons to effectively kill you.
Ghia
Vanagon
Beetle
4Gears4Tires Samba Member
Posted: Sun Mar 07, 2021 7:22 am Post subject: Re: Emission testing in Pennsylvania |
Today? Even 30-40 years ago. 100k miles is the break in period for an M20 or M30! _________________ '87 Syncro
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
whafalia Samba Member
Joined: January 28, 2009 Posts: 685 Location: San Francisco
Posted: Sun Mar 07, 2021 7:21 pm Post subject: Re: Emission testing in Pennsylvania |
California here, smog test tomorrow, dyno with a sniffer. His dyno woudn't calibrate last week but he says it's ready now. Did fine the last couple of times since rebuild, fingers crossed!
I was driving my kid and her band to a gig last year, wait no gigs last year, so before that. On the road next to a late 70's car that was belching and I got to tell them 'when I was a kid that's what all cars smelled like!' _________________ 84 westie 2.2 w/ digijet, AT |
