Right rear brake shoe sounds like a goose when stopping!
Mathew Zelezen
Mathew Zelezen is offline
PostPosted: Sun Mar 07, 2021 2:18 pm    Post subject: Right rear brake shoe sounds like a goose when stopping! Reply with quote
When I break after driving around town for a bit the right rear assembly makes this loud honking goose noise (Canadian variety)
Shocked
Before you ask, I did remove the offensive drum and there is no "fowl play" but the shoes do appear to be glazed..
Can I rough them up with some sandpaper?
What causes this to happen?
Right rear brake assembly:
Thanks!
87 Syncro Tintop
~Rocky J Motor
~Steedle Trans
Of all sad words of tongue or pen, the saddest are these: It might have been.
MarkWard
MarkWard is offline
PostPosted: Sun Mar 07, 2021 4:26 pm    Post subject: Re: Right rear brake shoe sounds like a goose when stopping! Reply with quote
You can rough the shoe and the drum with some 80 grit sandpaper. I don’t believe it’s covered in the Bentley, but you need a film of grease on the backing plate pads where the drums ride. A thin film on the shoe pivot points doesn’t hurt any.
Mathew Zelezen
PostPosted: Sun Mar 07, 2021 5:49 pm    Post subject: Re: Right rear brake shoe sounds like a goose when stopping! Reply with quote
Thanks Mark!
I'll give it a roughening up and grease those locations.
What causes this to happen? And to only one side no less.
87 Syncro Tintop
~Rocky J Motor
~Steedle Trans
hardway
hardway is offline
PostPosted: Sun Mar 07, 2021 7:30 pm    Post subject: Re: Right rear brake shoe sounds like a goose when stopping! Reply with quote
Most brake noises, squeaks groans etc. are caused by something moving rapidly, oscillating. The frequency of the sound is the frequency of the oscillation. The fit of the parts, something running untrue perhaps the friction coefficient of the lining and drum. Something frequently overlooked with drum brakes is the rubbing blocks on the backing plates. The shoes must slide freely on them. They may need to be surfaced as well as lubricated. Use a high temperature brake grease. The backing plates may be bent and the drums bell mouthed or screw threaded by a lathe. There are not many people left that are good with drum brakes.
