Vanuber Samba Member
Joined: February 16, 2020 Posts: 411 Location: Virginia
Posted: Mon Mar 08, 2021 8:04 am Post subject: New Propane Tank Options |
I am looking into either refurbishing our existing tank with new shut-off valve and two-stage regulator or buying a new propane tank.
Looks like the Manchester tanks from Go Westy and Van Cafe are the same unit - $650 with regulator:
https://www.vancafe.com/253070601D-p/253070601d.htm
https://www.gowesty.com/product/lp-tank/2447/lpg-tank-with-regulator-
Bus Depot has a tank from Westfalia that runs $110 cheaper with a different style regulator (is that two-stage?):
https://www.busdepot.com/253070601d
I don't know much about LP tanks and am not sure about the differences here. If I rule out refurbishing, are there any pros and cons between these options? Thanks. _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
'02 Subaru Forester 2.5L |
a2wolfsburggli Samba Member
Posted: Mon Mar 08, 2021 9:10 am Post subject: Re: New Propane Tank Options |
Don't waste your money on a new one unless yours is beyond hope. Refirb is simple and cheap
https://www.thesamba.com/vw/forum/viewtopic.php?t=711958 _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Past: '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Mon Mar 08, 2021 9:28 am Post subject: Re: New Propane Tank Options |
You can refurb with new hardware for about half if you are willing to follow simple directions and have time to remove old paint and rust then repaint the tank.
First step is to remove the valves and inspect the interior of the tank, with a camera, no (as in zero) rust/corrosion is allowable. Next strip the tank (after lightly reinstalling the valves),. Inspect for rust and corrosion especially at the welds. These tanks were made of very high quality steel and most are still in excellent condition.
Order all new hardware ie valves (Rego) and regulator (Westyventures). Follow the instructions on the REGO website.
Mask off and prime, repaint. Wait until fully dried/cured, reinstall.
Systematically check for leaks with soapy water.
Enjoy
Note The brass fitting are most likely in good condition but very closely inspect after cleaning (no powered wire brush). _________________ Schau in das Buch |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon Mar 08, 2021 9:49 am Post subject: Re: New Propane Tank Options |
The BD regulator is the correct one for your vanagon. I refurbed our tank too. There is some appeal to having a new tank show up and you just bolt it in. I'm very cheap. _________________ ☮️ |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Mon Mar 08, 2021 10:19 am Post subject: Re: New Propane Tank Options |
All 3 are Manchester tanks.
Manchester was the original supplier for Vanagon Westys.
Yes, Westfalia bought USA made tanks for campers sold to the USA/CA market.
Mark
Posted: Mon Mar 08, 2021 10:28 am Post subject: Re: New Propane Tank Options |
My tank is very good cosmetically with minimal corrosion. I would like to pursue the refurb route as I am not eager to spend $600 on a new tank. But safety is the primary concern.
Any thoughts on this GW tech article? https://www.gowesty.com/tech-article-details.php?id=62 They site that age and lack of a modern auto-stop filling port are reason to replace. _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
MarkWard wrote: |
The BD regulator is the correct one for your vanagon. |
^This is good to know.
Does anyone have a good source for the shut-off valve? Mine is certainly leaking in between fully open and fully closed. Bleeder valve as well? _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
Posted: Mon Mar 08, 2021 10:39 am Post subject: Re: New Propane Tank Options |
crazyvwvanman wrote: |
Manchester was the original supplier for Vanagon Westys. |
Thanks for the info. _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
Nimbus'87 Samba Member
Joined: January 03, 2013 Posts: 125 Location: Murrieta, Ca.
Posted: Tue Mar 09, 2021 1:53 am Post subject: Re: New Propane Tank Options |
Depending upon model of valve, some can be rebuilt.
_________________ '87 Wolfram Grey Westy. '92 2.2 Subie, KEP/Calif. Reg. |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Tue Mar 09, 2021 2:12 am Post subject: Re: New Propane Tank Options |
You dont have expire date on propane tanks in the states?
Here we have a 10 year date and you can have it inspected and recertified for an additional 10 years. After that you need to replace it. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Abscate Samba Member
Posted: Tue Mar 09, 2021 5:23 am Post subject: Re: New Propane Tank Options |
State by state here, like most things.
Short version, if it can be removed , it needs DOT cert every 10 years
If it is permanent, it’s an ASME cert
...but enforcement varies widely by region. _________________ .ssS! |
ZsZ Samba Member
Posted: Tue Mar 09, 2021 5:55 am Post subject: Re: New Propane Tank Options |
Abscate wrote: |
...but enforcement varies widely by region. |
Thanks for the info! _________________ Zoltan
Posted: Tue Mar 09, 2021 6:42 am Post subject: Re: New Propane Tank Options |
Nimbus'87 wrote: |
Depending upon model of valve, some can be rebuilt. |
Thanks for the tip! _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
danfromsyr Samba Member
Posted: Tue Mar 09, 2021 7:52 am Post subject: Re: New Propane Tank Options |
Vanuber wrote: |
Does anyone have a good source for the shut-off valve? Mine is certainly leaking in between fully open and fully closed. Bleeder valve as well? |
Did you not read my post in the 1st reply? EVERYTHING you need to know is there. Scroll down _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Posted: Tue Mar 09, 2021 10:11 am Post subject: Re: New Propane Tank Options |
a2wolfsburggli wrote: |
Did you not read my post in the 1st reply? EVERYTHING you need to know is there. Scroll down |
I did read your post. Very helpful, thank you. _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
Posted: Tue Mar 09, 2021 10:15 am Post subject: Re: New Propane Tank Options |
All the parts in one purchase - nice! That's a pretty good price too after looking at a2wolfsburggli's part list. _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
Posted: Tue Mar 09, 2021 10:51 am Post subject: Re: New Propane Tank Options |
Nice. Thank you. _________________ ☮️ |
Posted: Tue Apr 20, 2021 7:50 pm Post subject: Re: New Propane Tank Options |
Was checking this price again tonight and Bus Depot raised their price by $110!
Also does not include the regulator, so make that $155. Now more than GW or Vancafe. _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
