Ladybus88 Samba Member
Posted: Mon Mar 08, 2021 9:28 am Post subject: Which fuel pump to use |
Hi,
I have a 67 bus. The engine code is AE, so I believe from my research it is a '71 engine. The carb that is on the engine is a solex30pict-1, which is more period correct for the 67 bus.
I have been trying to figure out what is the correct fuel pump that should go with this combination and need help on this. My thought is the fuel pump should match to the 30PICT-1 carb.
I have look up "without guesswork" manuals, the table shows fuel pump with VW3 ID mark for Type2 (1500/1600).
I have seen variation of VW3 fuel pump with round/dome top and square top. Which one is the correct one? Should that be the threaded fitting or tube type connections?
Please help. Thanks! |
galexander Samba Member
Joined: April 17, 2003 Posts: 524 Location: Round Rock, TX
Posted: Tue Mar 09, 2021 10:29 am Post subject: Re: Which fuel pump to use |
Looking at the Owner's Manual from Aug 66 and Dec 66 looks like a round top Pierburg. With push on fuel line inlet and outlets.
I have been having great luck with Bill at Sparkwerks with his rebuilt Pierburg pumps! _________________ enjoy the journey,
Gary
Check out our YouTube Channel, VW Life |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Tue Mar 09, 2021 12:06 pm Post subject: Re: Which fuel pump to use |
Also depends on if youre running a generator or alternator. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Mar 10, 2021 7:18 pm Post subject: Re: Which fuel pump to use |
Don't make your decision based on an owner's manual. You will find that they are notoriously inaccurate. No offense intended to galexander. It's always been my understanding that Buses kept the threaded inlet later than the Beetles, how late I don't recall exactly. _________________ Roads Scholar &
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Wed Mar 10, 2021 7:21 pm Post subject: Re: Which fuel pump to use |
Talk to Bill, he rebuilds fuel pumps and might be able to tell you what's correct. If he doesn't know he'll tell you. If do need a pump he can provide one.
Here's his ID wcfvw69 _________________ Glenn
Member #1009
#BlueSquare |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Thu Mar 11, 2021 6:41 pm Post subject: Re: Which fuel pump to use |
My one owner before me numbers matching '67 Kombi October '66 build had a dome top threaded inlet.
I personally think the next issue fuel pump with the push on inlet is better for vibration and ease of care. |
