Stockholm VW Samba Member
Posted: Wed Mar 10, 2021 2:22 pm Post subject: Lazy brake lights. Switch not very sensitive. Choices? |
The brake light switch at the master on my ‘66 Sedan works, but only if I apply high force. Not panic stop like, but too much than needed to slow down for a light, for example.
What are the best (most sensitive) switches out there? Bosch?
Suggestions? _________________ 1966 Volkswagen Sedan 1300 (now 1641), 6 volt, L456 Ruby Red, Platinum leatherette. |
toxicavenger70 Samba Member
Scott65Beetle Samba Member
wayne1230cars Samba Member
Posted: Thu Mar 11, 2021 9:59 am Post subject: Re: Lazy brake lights. Switch not very sensitive. Choices? |
x 3 - The pedal actuated switch gives you instant brake lights. It is easily installed. You can actually hear the switch click when you touch the brake pedal.
If you prefer not to go that route then just purchase a good quality brake light switch. I have had good luck with the Wolfsburg West switches. Good quality and no leaks.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113945515CGR _________________ 1960 beetle
1970 beetle convertible
Last edited by wayne1230cars on Thu Mar 11, 2021 10:02 am; edited 1 time in total |
KTPhil Samba Member
Posted: Thu Mar 11, 2021 10:00 am Post subject: Re: Lazy brake lights. Switch not very sensitive. Choices? |
I presume you have throughly bled the system, so compressing air bubbles are not the source of the delay?
Also, try LED bulbs. They are brighter, but also instant-lighting, unlike lazy filament bulbs. That might be enough improvement.
I note that kit says LED bulbs are required for 6V systems anyway, so try that first. |
Posted: Thu Mar 11, 2021 10:18 am Post subject: Re: Lazy brake lights. Switch not very sensitive. Choices? |
KTPhil wrote: |
I have the pedal actuated switches on my ‘70 (12 volt) and my ‘60 (6 volt). On the 12 volt they work fine with the original filament bulbs. On the 6 volt, I already had led bulbs. LED bulbs really are much brighter. _________________ 1960 beetle
1970 beetle convertible |
tcmia Samba Member
Joined: April 30, 2019 Posts: 212 Location: Cleveland TN
Posted: Thu Mar 11, 2021 1:49 pm Post subject: Re: Lazy brake lights. Switch not very sensitive. Choices? |
I use the same type switch setup as mentioned above. Works great. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Thu Mar 11, 2021 5:07 pm Post subject: Re: Lazy brake lights. Switch not very sensitive. Choices? |
When the VW pressure switch takes more and more force to activate the lights, it's usually on the way out.
I have had good luck with a Harley-Davidson rear brake light switch. Threads right in and is very sensitive to pressure - lights up earlier than the VW switches.
Works great for older cars that have just the two-prong switches. You could use it on a 3-prong car but you will lose brake warning light functionality.
_________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Thu Mar 11, 2021 5:48 pm Post subject: Re: Lazy brake lights. Switch not very sensitive. Choices? |
KTPhil wrote: |
X2 on the LED bulbs. Huge improvement in my 6v system. _________________ '65 Sunroof Bug |
