donald.lemay Samba Member
Joined: March 01, 2009 Posts: 484 Location: Rhode Island
Posted: Sat Mar 13, 2021 2:25 am Post subject: Rocker geometry? |
So I’m at the point where I’ve done all my measuring and was getting deck height. I have deck height on three of four cylinders. I am now having to disassemble the engine because of a problem with one of the rods. My question is can I put the barrels on without the Pistons “put some thing on the end of the rods so I don’t mess up the barrel” and start doing my rocker geometry. Or should I wait till the new rods come in and start from scratch. I realize I will have to remeasure my rods and also recheck my deck height. But do you think the deck height will be that much different with the new rods to change the geometry? Thanks for any input.
Don _________________ 66 13 window deluxe
2085cc
9to1compression
ported polished heads 40x36 valves
010 distributor
VS 42mm exhaust
40 IDF carbs |
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Sat Mar 13, 2021 4:06 am Post subject: Re: Rocker geometry? |
donald.lemay wrote: |
Don |
Same length rods and it wouldn’t matter.
Start messing with pistons and it’d likely matter because the wrist pin heights seem to be different between brands.
Valvetrain won’t know there’s no rods or piston in this case I suppose. |
mark tucker Samba Member
Posted: Sat Mar 13, 2021 8:18 am Post subject: Re: Rocker geometry? |
different rods can change it,but not if your going with same length rods.I would just waight till I get that end done and then move on to the geo. |
Posted: Thu Apr 08, 2021 2:35 am Post subject: Re: Rocker geometry? |
Another question about setting rock or geometry. How many turns from bottomed out with elephant feet on CB rockers do you turn them for initial setting. I’m messing around I did one and a half turns from bottomed out. Also I had my rockers back cut. It seems with one turn out it just barely clears when you rock the elephant foot all the way around. So I figure an extra half turn it could never bind.
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs |
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Thu Apr 08, 2021 5:43 am Post subject: Re: Rocker geometry? |
What lift are you at in this picture? Hopefully not 0 |
Posted: Thu Apr 08, 2021 9:44 am Post subject: Re: Rocker geometry? |
Halfway way _________________ 66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs |
Posted: Thu Apr 08, 2021 9:55 am Post subject: Re: Rocker geometry? |
I set my geo& pushrod length/lash at about 1/4 to 1/2 max out from seated. but that can be hard to work up to unless your real used to doing this stuff. |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Thu Apr 08, 2021 10:00 am Post subject: Re: Rocker geometry? |
This might be half lift, but it doesn't look right. The valve stem and the adjuster don't look inline. |
