Westified Samba Member
Posted: Sat Mar 13, 2021 11:49 am Post subject: 1.9 ltr Catalytic converter, Muffler and Tail Pipe |
I just installed a new Catalytic converter (48 state from Van-Cafe), Muffler (from BusDepot) and Tail Pipe (from Van-Cafe). I noticed my tail pipe is angled down. My previous one was parallel with the ground. Also the new tail pipe is longer than my old one, 9" vs 7 1/4" measured from the outside of the flange. Is this normal? Did I do something wrong. Below are some photos.
_________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Sat Mar 13, 2021 12:00 pm Post subject: Re: 1.9 ltr Catalytic converter, Muffler and Tail Pipe |
Tailpipe looks fine to me. The GW one is the weirdest tailpipe I've seen. Without out a donut type flange, your sort of stuck with the angle you have. Or, you could cut the flange off and reweld to your aesthetic. I wouldn't go to the trouble. _________________ ☮️ |
Posted: Sat Mar 13, 2021 2:38 pm Post subject: Re: 1.9 ltr Catalytic converter, Muffler and Tail Pipe |
Thanks Mark for the response. Yes, I guess I will just live with it pointed down a little. The muffler I used is a Bosal. Maybe its bracket was off a little.
Brad _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
Posted: Sat Mar 13, 2021 2:43 pm Post subject: Re: 1.9 ltr Catalytic converter, Muffler and Tail Pipe |
Actually down will keep moisture from collecting and rusting out. And you can dry your socks. _________________ ☮️ |
jlrftype7 Samba Member
Posted: Sat Mar 13, 2021 3:08 pm Post subject: Re: 1.9 ltr Catalytic converter, Muffler and Tail Pipe |
Westified wrote: |
Brad |
Pretty much matches my experience with installing the VC exhaust kit as well on my ‘84.
Here’s a picture of the then new Vintage Speed tailpipe that I bought some months later, still at a downward angle.
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sat Mar 13, 2021 3:22 pm Post subject: Re: 1.9 ltr Catalytic converter, Muffler and Tail Pipe |
Are some of the holes slightly oval to allow some rotational adjustment? Possibly the ones on the muffler at the cat end? It has been years but my recollection is that mine could be adjusted a little that way. |
DMacIndy Samba Member
Posted: Sat Mar 13, 2021 4:02 pm Post subject: Re: 1.9 ltr Catalytic converter, Muffler and Tail Pipe |
Westified wrote: |
Awesome! I was just thinking that I need to replace all this on my 83.5. Looks pretty good to me. _________________ 1983.5 Vanagon Westfalia “Wanda” |
Posted: Sat Mar 13, 2021 5:19 pm Post subject: Re: 1.9 ltr Catalytic converter, Muffler and Tail Pipe |
Ahwahnee wrote: |
You may be onto to something there. My tail pipe gained a bit of ‘horizontal’ attitude after removing my cat and muffler to lower my engine bar and motor mounts. While new motor mounts definitely changed the engine position, I’m also thinking that the exhaust tweaked a bit more in rotation while reinstalling it.
I should post a picture of before and after tomorrow once it’s daylight again. I think I have 1 stored pic from the tail pipe install , but looking from the side.
However, the VS tail pipe doesn’t have that S curve on it like the one that the OP is showing, just a gentle curve to it. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
