JMCFAN Samba Member
Joined: May 10, 2020 Posts: 46 Location: Corrales, NM
Posted: Fri Mar 19, 2021 9:16 am Post subject: Throttle cable carb attachment |
Have roller pedal. New cable with Z type connector at pedal. cut other connector off new cable and through tub etc. How does it attach to the carb? See "barrel connector" like this but how does it attach...??
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Fri Mar 19, 2021 10:12 am Post subject: Re: Throttle cable carb attachment |
There are cable shortener kits, but I've seen a lot of people just clamp the cable into the barrel clamp. Or swap for a larger cable altogether. The shortener kits can be a hassle, and let go of the cable when you're driving, is what I've experienced. _________________ 1972 Standard Beetle
1969 Baja Beetle |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Mar 19, 2021 10:47 am Post subject: Re: Throttle cable carb attachment |
How does it attach may be issue with what carburetor system you may have....
I just put "barrel" on cable just as if it were standard throttle cable, but learned auto crossing to put second barrel on cable behind proper barrel to prevent cable from slipping out of primary barrel and gives you a limp home mode... And wire nut keeps end of cable from fraying (in case you needed to know)
Yes its for dual carburetor linkage...
JMCFAN Samba Member
Posted: Fri Mar 19, 2021 12:40 pm Post subject: Re: Throttle cable carb attachment |
Thanks! Got it! |
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Fri Mar 19, 2021 2:04 pm Post subject: Re: Throttle cable carb attachment |
I use a pc of shrink tubing over the cable where it goes through the barrel, an extra level of protection from fraying. If you hunt around there are aluminium sleeves that you can crimp on before the cable goes through the barrel.
Paul _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Fri Mar 19, 2021 6:28 pm Post subject: Re: Throttle cable carb attachment |
Dale M. wrote: |
Dale |
Thats an awesome idea! |
jspbtown Samba Member
Posted: Sat Mar 20, 2021 7:32 am Post subject: Re: Throttle cable carb attachment |
Recently I have been playing with some vintage minibikes and cable fraying has been a constant pain.
My solution has been to cut the plastic sheathing away from a blue electrical butt connector. I use a razor blade to peel it off and you are left with a nice little metal "tube" that the cable easily slips into and can be lightly crimped on.
Its a pretty clean look. |
Posted: Sat Mar 20, 2021 10:51 am Post subject: Re: Throttle cable carb attachment |
As a option you can tin an solder end of cable to stop fraying also...
Ogre3239 Samba Member
Joined: February 20, 2021 Posts: 11 Location: Central Florida
Posted: Sat Mar 20, 2021 5:36 pm Post subject: Re: Throttle cable carb attachment |
jspbtown wrote: |
That's a cool idea, may have to use that on a couple of motorcycles as well |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Sat Mar 20, 2021 6:18 pm Post subject: Re: Throttle cable carb attachment |
I solder the cable from the cut end up to the point where the barrel clamp screw grabs the cable. Prevents the screw from breaking the cable.
I have also soldered the end then attached a cable shortener. It gives the screw something to grab on to. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sat Mar 20, 2021 8:05 pm Post subject: Re: Throttle cable carb attachment |
I went to the Local "Ace is the Place" store and picked up a couple of small roll pins that would just slide over the cable.
Install the new cable and set the roll pin where you need it to fit where the barrel clamp will go in the throttle linkage.
I use two and overlap a bit for adjustment if needed. I then mark where it needs to go....remove cable and solder the two roll pins on the cable. Then cut excess off and you have a hardened area to clamp the cable clamp to without destroying the cable.
Cutting it to length after soldering on the roll pins makes fraying a non issue.
https://www.bing.com/images/search?view=detailV2&a...amp;sim=11
Just make sure it fits the cable and also fits the cable clamp. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Sat Mar 20, 2021 10:33 pm Post subject: Re: Throttle cable carb attachment |
You can also pick up the aluminum caps for bicycle cables at your local bike shop, they crimp on and come in various sizes.
I soldered mine and then use a rubber end from a bungee cord hook-I run an extra large diameter cable. _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
