PatterBon Samba Engine Connoisseur
Joined: September 27, 2008 Posts: 3446 Location: Copperas Cove, TX
Posted: Thu Apr 15, 2021 8:02 pm Post subject: Re: My single owner 1959 Ghia |
Rerouted the original battery cable today
_________________ PNW Dub Folk & Kitsap dub Folk (KdF)
Austin Aircoolers VW Gang
2020 Ford F-150
1973 Standard Beetle
1969 Cessna 172K Airplane
1959 Karmann Ghia
US Army CH-47 Chinook Helicopter Repairer |
Posted: Tue Apr 20, 2021 7:03 pm Post subject: Re: My single owner 1959 Ghia |
Alrighty ladies and gentlemen! Today was the day! After waiting a little over a week for my gaskets and my vacuum line to show, they did!
A bit of trial and error came with it today. First being I accidentally roasted a battery wire by putting on the wrong terminal. Then once that was rectified, I installed everything and my carburetor started leaking like a civ. After removing it (and in pictures) it was missing a casting plug on the back side. Good thing I had a sacrificial carb to pop the plug out of and then everything was right as rain! She runs like an absolute top! I couldn't be more pleased that all the work I've put into it turned out proper and she runs well! That and Everett will be pleased the vacuum line situation has been rectified
This bottom picture is a before with all the strangle lines it had going to it for a little comparison.
2020 Ford F-150
1959 Karmann Ghia
Posted: Tue Apr 20, 2021 7:54 pm Post subject: Re: My single owner 1959 Ghia |
Took her for a quick cruise about 5 minutes down the road. Got the brakes working again too. Everything works as advertised. She still has a few small kinks to work out, hesitates a little on acceleration. But then again I've never driven a 36er for any distance before. A HUGE shout out to Morris Race Engines for helping me get all the parts I needed over the past week. Having the ultimate VW shop backing me up has been second to none and I couldn't be more lucky! Enjoy!
2020 Ford F-150
1959 Karmann Ghia
Marcdeb Samba Member
Posted: Wed Apr 21, 2021 3:30 am Post subject: Re: My single owner 1959 Ghia |
I love the sound of the engine when you first start it. What a time capsule! Lovely car. Looks like you had a perfect day for a nice drive. After almost 2 years of owning my car, I still have not had that experience. But I'm getting close.
I can feel your enthusiasm. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Braukuche Samba Member
Posted: Wed Apr 21, 2021 7:36 am Post subject: Re: My single owner 1959 Ghia |
Engine sounds great. You might want to relocate that ground cable to the case. I’m pretty sure that’s how it was done, I just don’t recall which case stud. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Wed Apr 21, 2021 7:59 am Post subject: Re: My single owner 1959 Ghia |
Braukuche wrote: |
Engine sounds great. You might want to relocate that ground cable to the case. I’m pretty sure that’s how it was done, I just don’t recall which case stud. |
Thank you guys! I'm truly loving it!
Everett posted a picture from the 1959 manual and it shows it hooked up to the generator strap. I believe the picture is on page 2. _________________ PNW Dub Folk & Kitsap dub Folk (KdF)
2020 Ford F-150
1959 Karmann Ghia
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8206 Location: San Dimas
Posted: Wed Apr 21, 2021 8:59 pm Post subject: Re: My single owner 1959 Ghia |
Thank you guys for the info! Here's today's pic collage. Got it registered and insured and enjoyed this beautiful PNW day.
2020 Ford F-150
1959 Karmann Ghia
Posted: Mon Apr 26, 2021 1:26 pm Post subject: Re: My single owner 1959 Ghia |
I'd forgotten to mention that last week I did a quick oil change on her and put some seafoam in the tank since it had sat for awhile and the gas was noticeably skunky.
Today I filled the tank again after putting a little over 100 miles on it and it cruises like a charm. Also turns out I'd been mistaken and Carl''s aunt had gifted him the Ghia so I am technically the 3rd owner of it. But it's story I presented stands. That engine hasn't been on a cruise since the late 80's and it runs remarkably. Enjoy the pictures!
2020 Ford F-150
1959 Karmann Ghia
Rome Samba Member
Joined: June 02, 2004 Posts: 9603 Location: Pearl River, NY
Posted: Sat May 01, 2021 9:09 pm Post subject: Re: My single owner 1959 Ghia |
Ground strap: Not at the generator strap, but as explained, at the fastener beneath the engine oil filler. In the photo below (Loren's gallery) the large hole at the top of the engine and gen stand is for the oil filler pod. Directly below that is a boss with an open hole for the bolt/screw that holds the ground strap. I don't know the thread size, but likely M8 x 1.25 mm. If you try an engine tin screw (thread size M6 x 1.00 mm) and it's way too loose, then it's the M8. Place a lock washer under the fastener head so that it won't vibrate loose.
aaronr25 Samba Member
Joined: September 06, 2009 Posts: 267 Location: NW Arkansas
Posted: Mon May 03, 2021 2:11 pm Post subject: Re: My single owner 1959 Ghia |
Great looking Ghia. _________________ 65 Bug
66 Landcruiser FJ40
Life's too short to drive a stock VW |
Posted: Tue May 04, 2021 11:52 pm Post subject: Re: My single owner 1959 Ghia |
Thank you, everyone! I didn't locate the strap to the proper spot but will be sure to have my dad take care of it now that it's been clarified. The car now resides with my parents up in Washington while I'm down in Texas.
Exciting news, my final evening at home, I went to the brewery with some close friends who happen to also love VW's and after some discussion about what's left to make the Ghia truly correct, I was offered a September 1959 split case transmission, an original fuel cap and potentially a September 1959 radio in exchange for the current transmission installed in it! I also have an original nose badge that needs to be installed too.
Next venture home, I will be doing the swap and the transition will have been completed. There are small cosmetic things I'd like to do such as freshen up the engine bay but that will all come in due time. For now, for the first time in a very long time, its getting a lot of great love and attention. _________________ PNW Dub Folk & Kitsap dub Folk (KdF)
2020 Ford F-150
1959 Karmann Ghia
Posted: Wed May 05, 2021 3:12 am Post subject: Re: My single owner 1959 Ghia |
Great pictures. You have good skills with a camera as well. Excellent choices for settings. I especially like the shots with the Ghia's lights on. Not many pictures on this site like that. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
moogie32 Samba Member
Joined: April 06, 2005 Posts: 663 Location: Connecticut
Posted: Wed May 05, 2021 3:39 am Post subject: Re: My single owner 1959 Ghia |
I especially like these two! _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Doch leider musst du von uns gehn |
SnyderFam67 Samba Member
Joined: March 24, 2021 Posts: 5 Location: Carson City, NV
Posted: Wed May 05, 2021 11:45 am Post subject: Re: My single owner 1959 Ghia |
Beautiful Ghia and a great story. So glad you found the nose badge, it's begging for it. |
Posted: Thu May 06, 2021 7:55 am Post subject: Re: My single owner 1959 Ghia |
Thank you, everyone! I'm not much of a photographer but I'm glad the pictures turned out how they did. Believe it or not, they're all done off of my phone and are un-doctored.
It runs and drives incredibly well and my folks are now enjoying it. I plan to keep it forever and love it like how I love my beetle. The advice and help you guys have provided has been awesome and I truly do appreciate it. I'm a lucky guy to not only have this car but to also be part of the VW community. _________________ PNW Dub Folk & Kitsap dub Folk (KdF)
2020 Ford F-150
1959 Karmann Ghia
Posted: Mon Sep 13, 2021 7:58 pm Post subject: Re: My single owner 1959 Ghia |
Hey guys, little update! Since leaving the Ghia up in WA, I worried it wouldn't be driven and I've been proven wrong! My parents daily it and this last weekend my mom took it to a family reunion where my uncle took his Thing. It gets driven often around my quiet home town and went on a Seattle adventure! I was also curious if there was a way to decipher my VIN beyond the table in the Archives? Enjoy!
2020 Ford F-150
1959 Karmann Ghia
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13943 Location: Southampton U.K.
Posted: Sun Sep 19, 2021 5:40 am Post subject: Re: My single owner 1959 Ghia |
John Moxon wrote: |
PatterBon wrote: |
Yep, have a stroll though the '59s on The KG Lowlight Register here: http://www.kglowlightregistry.com/index.php?Year=1...ass%5B%5D=
These are the '59s registered. Most have their vin numbers recorded and some their build dates. If you're lucky you'll be able to see where your Ghia fits in chronologically |
Thank you! It would appear that mine was built somewhere around March/April of 1959. The closest VIN I saw to mine that had a build date was 05 March 1959 and it was just a few hundred off. The closest VIN to mine currently resides unrestored in Australia.
I honestly didn't realize how rare of a car this was until I started reading more into it. I've always been a beetle guy, admiring Larmanm Ghia's but never thought to own one and my beetle is the same valueless 1973 that used to take me to preschool. It's only showing 107 registered '59's with only two that are near my VIN. _________________ PNW Dub Folk & Kitsap dub Folk (KdF)
2020 Ford F-150
1959 Karmann Ghia
kingkarmann Samba Member
Posted: Mon Sep 20, 2021 8:30 am Post subject: Re: My single owner 1959 Ghia |
As evidenced by the huge smiles on your parents faces you are indeed a good son! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
