AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Tue Mar 23, 2021 2:52 pm Post subject: Accessory Mode for the VW -Save your Pertronix |
I burned out a Pertronix electronic ignition module in my 009 distributor due to power to the coil wire without the engine running. I know some people like points but I like the Pertronix module and bought a new one.
I started thinking about adding an "accessory mode" that would protect my new Pertronix electronic ignition and would let me keep the accessories on.
I could have added a switch to control power to the coil/Pertronix but that a is manual step and if someone else is driving my car, they would not know about that switch.
So, here a simple little circuit I came up with that uses the starter trigger to signal a relay as to when to power the coil. Once starter is done, the other relay keeps the coil powered until ignition is turned off.
The net effect is that once you turn on the key, coil has no power; only accessories have power. Car can be left like that for any amount of time without damaging the Pertronix. When you crank the engine with the starter, the coil/Pertronix gets powered and remains powered after cranking is done.
Dale M. Samba Member
Posted: Tue Mar 23, 2021 3:37 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
AirHead1966 wrote: |
Awesome...
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2047 Location: El Cajon, CA
Posted: Tue Mar 23, 2021 4:59 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
Can I ask why you are sitting with accessories powered for an extended period of time?
The only thing I can think of is the same reason I used to, to listen to the stereo in the car (I always get places WAAAY earlier than I need to be there).. My solution 20 something years ago was to just wire the stereo to a circuit that hot all the time. I have a detachable faceplate, so I just remove the face to turn it off.. _________________ -pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.) |
Posted: Tue Mar 23, 2021 5:27 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
tattooed_pariah wrote: |
Phone charger, radio, usb powered devices, etc.
Also, I just added Bluetooth to my Sapphire AM radio so I can see myself in future having the radio on and phone plugged in to power while I sit at a car show, cruise in, etc.
I could connect the radio and cigarette lighter to unswitched power but I like everything to be off when I turn off the car.
Most importantly, I just don’t want to be paranoid about making sure that key is not left on for even a minute without the engine running. |
Posted: Tue Mar 23, 2021 8:33 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
fair enough
looks like you got a solid plan, hope it works out! _________________ -pariah (just a novice from "that other VW site")
74 Thing Samba Member
Posted: Wed Mar 24, 2021 4:55 am Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
Yep, but my understanding it that it takes about an hour for it to reset itself if left on. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2744 Location: Hamble, Hampshire, UK
Posted: Wed Mar 24, 2021 5:19 am Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
This is clever - it will also turn off the choke power, so the engine is using zero power until you turn the key to start.
BTW there is a simpler version using two diodes and a single relay. I sketched it here - the diodes steer current to the coil of the relay either from the starter wiring, or from the output of the relay. Turning off the coil feed will de-energise the relay as with two relays.
_________________ Ancient vehicles and vessels
Posted: Wed Mar 24, 2021 5:58 am Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
mikedjames wrote: |
Very nice with the didoes. I just wanted to physically separate the starter from the coil. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Wed Mar 24, 2021 7:17 am Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
I did this a different way.
My radio, glove box light, heater, and garage door transmitter are all powered by a relay that is triggered by the SU contact in the ignition switch.
On my '73 Thing, the SU contact provides a ground connection with the key in the ignition, but with the ignition switched off.
On some models, the SU contact is used to power a buzzer when the key is in the ignition switch and a the driver's door is open.
Like this:
Good luck, Mondshine |
Posted: Wed Mar 24, 2021 7:25 am Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
mondshine wrote: |
Very nice. |
allamaabroad Samba Member
Joined: September 22, 2016 Posts: 560 Location: South Jordan, Utah
Posted: Wed Mar 24, 2021 2:59 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
Ingenious use of a 2 relay memory circuit, good thinking and well done! What's interesting is with the use of an industrial style relay, you can actually accomplish the same task using a single relay _________________ Dennis - 1973 Super Beetle ('16-'21)
Debbie- 1970 Baywindow Bus ('21 - Present)
Tin top camper/adventure bus
2180 TW: CNC Panchitos, Beehives Done Right, Web 163, Ultralight Lifters, 1.3 Rockers, CSP Python, Custom Speeduino EFI Conversion with 40mm Throttle Bodies
Distributors are lame
I have a really hard time leaving things alone...
Innovative and affordable engine management systems and EFI conversions for your Vintage VW
Visit https://debbiesaircooled.com/ |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3580 Location: viroqua wi.
Posted: Wed Mar 24, 2021 3:03 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
allamaabroad wrote: |
Ingenious use of a 2 relay memory circuit, good thinking and well done! What's interesting is with the use of an industrial style relay, you can actually accomplish the same task using a single relay |
9 pin latching relay. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Wed Mar 24, 2021 3:33 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
Maybe it’s just me but I’ve been using the accessory circuit as delivered stock for the life of my VW’s and I’ve never had a problem leaving the key on to play the radio or whatever and been using Pertronix modules since ‘91 _________________ Volkswagen!
(Compression 8.7:1) |
BFB Samba Member
Posted: Wed Mar 24, 2021 4:50 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
holley and a couple others make an oil pressure switch that does about the same thing. no power to [ coil , fuel pump, pick your poison ] without oil pressure, i believe switched at 5 or 7 psi. start wire jumped to this switch powers your poison at startup until oil pressure is above the 5 or 7 psi point at which point main power takes over. _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
balljoint Samba Member
Posted: Wed Mar 24, 2021 5:34 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
Have you gotten this to work successfully? _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Wed Mar 24, 2021 5:55 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
Why not just wire things to bypass the key?
That's the way VW did the radio. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Mar 24, 2021 6:01 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
balljoint wrote: |
Have you gotten this to work successfully? |
Short answer, yes.
Long answer, I left the power connected when I was bench starting the engine after refreshing it. I put this circuit together and used it for subsequent engine starts on the bench. So, it does work. Should work the same when I put the engine back in the car.
Posted: Wed Mar 24, 2021 6:03 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
Glenn wrote: |
That's the way VW did the radio. |
What’s the fun in that?
This gave me something to do, plus I like no power to be on when I turn off the key. |
Glenn Mr. 010
Posted: Wed Mar 24, 2021 6:10 pm Post subject: Re: Accessory Mode for the VW -Save your Pertronix |
Glenn wrote: |
Install a master cut off on the battery. It also acts as a anti-theft feature. Adding relays is just another part to fail that leaves you on the side of the road.
Member #1009
#BlueSquare |
