brownbus2 Samba Member
Joined: October 13, 2020 Posts: 244 Location: Roanoke, VA
Posted: Wed Mar 24, 2021 10:13 am Post subject: Engine/tran out, cleaning up, PM, painting etc. Almost done! |
Got the engine and trans out. Trans is just coated with years of muck as is the under side (axles etc.)
I want to replace the cv boots that are cracking. I also want to get the right seals etc. On the spot pointed out below, what seal or flange do I need?
I am also going to clean up and paint the areas imaged below:
and a before pic before I sand and prime and paint the bay.
For the wheel hub, how much sanding is ok? and should I prime before using a wheel hub paint? Do the hubs need to come off to paint or just the wheels?
Not in a time crunch, other than a camping itch. I want to do all the trouble spots...anything apparent that I might be overlooking? _________________ formerly known as Brown_Bus
1976 FI Marino Yellow Westy
Mberglo Samba Member
Joined: January 13, 2020 Posts: 383 Location: Huntsville, AL
Posted: Wed Mar 24, 2021 10:45 am Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
I replaced my entire axles which came with new boots from Rockauto. Easy swap. Make sure you use washers under the bolts to prevent them from backing out.
Painting undercarriage can be done about anyway you want. If you're looking for protection, you can get spray cans of undercoating. If you want pretty, you're going to have to disassemble and do tens of hours of prep and then spray some Chassis Black or similar. |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2537 Location: Plattsburgh, New York
Posted: Wed Mar 24, 2021 11:03 am Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
It’s a lot of work. The undercoating is tough to get off. I used mineral spirits, Dawn and hot water, every kind of brush and scotchbrite, followed by sandblasting and Master series. It took me all winter but it was worth it because I was repairing or replacing so many things at once.
SLVRSRFR Samba Member
Joined: October 02, 2008 Posts: 154 Location: Guelph, On, CANADA
Posted: Wed Mar 24, 2021 11:15 am Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
This is what you are looking for:
https://weddleindustries.com/products/091-301-197/091-301-197
There are a couple of other seals/washers etc that you can replace while you are at it - here is the list of parts I ordered from Weddle when I did mine a couple of weeks ago (091 trans).
Dont pay attention to the qty's - I ordered enough to do 2 _________________ Brian
'78 westy, '64 sedan |
Posted: Wed Mar 24, 2021 11:28 am Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
Nice! Is the gray just primer or a top coat?
I am using Dawn on the tin. Put it all in a large tote. ~~They use Dawn to clean wildlife after big oil spills.~~
Using Gunk and nylon brushes on the trans.
I also plan on cleaning up the engine -painting manifolds and fan shroud, breather, intake etc.
1976 FI Marino Yellow Westy |
Posted: Wed Mar 24, 2021 11:30 am Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
Thanks SlvrSrfr! _________________ formerly known as Brown_Bus
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Wed Mar 24, 2021 12:01 pm Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
brownbus2 wrote: |
Not in a time crunch, other than a camping itch. I want to do all the trouble spots...anything apparent that I might be overlooking? |
I’ve cleaned up and undercoated the bottom of 2 buses. I used a 6” wire wheel on my drill to clean the undercarriage, then I used rusty metal primer and rustoleum spray on undercoating to finish the job.
Here’s a pic of my ‘71. You can see the wheel wells some of the frame with the undercoating and I used high temp engine paint for the drums and back plates.
I’ve had a lot of good luck with the EMPI CV boots, they seem to last the longest. You might want to also consider replacing the shift coupler and rebuilding your shift rod while everything is out. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Wed Mar 24, 2021 12:24 pm Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
What parts do I need for the shift rod rebuild? _________________ formerly known as Brown_Bus
Posted: Wed Mar 24, 2021 1:21 pm Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
cip1 has the HD orange one as well. Not sure how much 'better' that is than the empi _________________ formerly known as Brown_Bus
Posted: Wed Mar 24, 2021 2:12 pm Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
On the tranny, you want to replace the two output flange seals, the input shaft seal, and the shift rod seal in the nose come. The shift rod seal varies with the nose cone design, there is also a dust boot. A later bus would have come with a 091 "6 rib" transmission, so you probably needs the parts for a '76 and later bus.
Unless they have been damaged, you likely do not need the lock rings for the side bearing nuts. You might remove them for inspection before ordering parts.
Your grease build up may well just be from the CV joints oozing the oil out of their grease, this is absolutely normal and not a problem. If you don't get around to cleaning and relubing the CV every few years then use a long grease needle under the small end of the boot to force a bit of new grease into the CV bearing. Note, you want to get the grease all the way into the bearing and not just pump grease into the boot.
Personally I would just scrape away any loose undercoating and paint and then use something like Waxol on the underneath side of the body. Painting that area well is a ton of work. |
airkooledchris Samba Member
Posted: Wed Mar 24, 2021 2:36 pm Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
When you clean up your tins, see if you can save the OG marking seen at the top of this photo (the drivers side rearmost tin)
You don't see many original Inspector Otto marks anymore. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Wed Mar 24, 2021 3:54 pm Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
If you really lucky you will have the rare made in Ordnung tin, labeled IO, of course. _________________ .ssS! |
The Volkswagen Ranch Samba Member
Joined: November 24, 2002 Posts: 703 Location: Arizona
Posted: Wed Mar 24, 2021 4:46 pm Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
Brown bus, I am in the middle of doing the engine compartment and the ceiling above the transmission . I used dish soap , Fantastic, Simple Green, wire brushes , nylon brushes , wash cloths..... whatever it took to get the “ muck off”. Then used POR 15 metal ready followed by POR 15 on the ceiling and and surface rust spots after sanding them. The project has taken on a life of it’s own and has been “ stop and go” with many interruptions as our winter weather has been longer and colder than usual. Make sure you clean and refurbish the heater bellows as well as cleaning the shifter rods and replacing the shifter bushings. Replace ANY questionable wiring and terminals, and of course all of the vapor line connections and fuel hoses. Several posts going on right now for reference. Not a job for the “ faint of heart”. You look to be doing an excellent job! Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Wed Mar 24, 2021 5:51 pm Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
Yes |
Posted: Thu Mar 25, 2021 10:19 am Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
If it were me I would buy the HD one with the urethane bushings and the grub screw with the hole for the wire. The wire insures the screw won’t back out on you. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Thu Mar 25, 2021 10:39 am Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
I would be more inclined to buy whatever CB Performance is selling. |
Posted: Sat Apr 03, 2021 11:23 am Post subject: Re: Engine/tran out, cleaning up, PM, painting etc. advice wanted |
in the process of cleaning and painting the tins etc. Can water/soap get inside the air intake dist.? Or should I just clean the outside as best as I can w/o getting water inside?
Also how freely should the flap inside the throttle body move? When i removed it from the air dist. I noticed the spring wasnt moving it when the spring was pulled. Pressing my finger on it did not move it until a bit of pressure was applied.
Im assuming that would make it run very erratic if it was sticking? What is suitable to lube that flap if needed?
Pics later of the progress. _________________ formerly known as Brown_Bus
