Posted: Thu Mar 25, 2021 11:37 pm Post subject: Wiper Shaft Assembly, what else will work? |
Since the Vanagon wiper shaft to wiper arm connections are problem prone and the OEM arms aren't always even available new, I was wondering what other wiper shaft assembles from other vehicles could most easily be made to work on a Vanagon. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Fri Mar 26, 2021 12:12 am Post subject: Re: Wiper Shaft Assembly, what else will work? |
Wildthings wrote: |
OEM arms available through BrickwerksT3 in the U.K. _________________ This free advice is worth exactly what you paid for it.
Posted: Fri Mar 26, 2021 12:21 am Post subject: Re: Wiper Shaft Assembly, what else will work? |
Looking at the alternate arms I got through GoWesty and the OEM arms I got from Brickwerks I think you might be able to put any "new" arm on the shaft as long as it has the right lemgth and the hole for the shaft has not mounted to impress the spline pattern into the soft metal og the arm. Are the holes for the Shaft a "standard dimenson? Or are they different sizes for the weight of the blade? _________________ This free advice is worth exactly what you paid for it.
Posted: Fri Mar 26, 2021 6:10 am Post subject: Re: Wiper Shaft Assembly, what else will work? |
Steve M. wrote: |
Looking at the alternate arms I got through GoWesty and the OEM arms I got from Brickwerks I think you might be able to put any "new" arm on the shaft as long as it has the right lemgth and the hole for the shaft has not mounted to impress the spline pattern into the soft metal og the arm. Are the holes for the Shaft a "standard dimenson? Or are they different sizes for the weight of the blade? |
I think the design goes back to the Beetle which had maybe a 10" long wiper blade and a short little arm to match. What I would like to go to is something properly engineered to handle the much longer arm and blade of the Vanagon. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4794 Location: Bemidji, MN
Posted: Fri Mar 26, 2021 6:21 am Post subject: Re: Wiper Shaft Assembly, what else will work? |
all the older 'foreign' cars i've had used wimpy wiper arms/mechanisms... Fiats, Volvos, VWs, Japan stuff, even Mercedes. that's one thing the American cars have largely got right is more robust wipers. and heaters. maybe it is a climate perspective thing? then Volvo and Saab should be great, and they aren't. dunno. i've got every mechanism joint lubed in my Vanagons and i always subconsciously hold my breath when i turn the wipers on. _________________ -dan
www.thefixitworkshop.com |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Fri Mar 26, 2021 8:15 am Post subject: Re: Wiper Shaft Assembly, what else will work? |
It is a wimpy connection. Maybe on purpose? It seems at least once per winter season i accidentally use mine when still frozen to the windshield . Something has to give, id rather it was right out on the front of the van. This winter I've been really carefull every time I start the van to make sure the wipers are off. But two weeks ago the windshield looked thawed but no, the pass side was still frozen on, %#&@$$<÷!. |
Posted: Fri Mar 26, 2021 9:53 am Post subject: Re: Wiper Shaft Assembly, what else will work? |
on some of the old US cars that had really strong drivetrains, when the wipers would freeze down you'd hear a thermal cutout kick out and in as the motor struggled to move the wipers. no damage.
the VW method of damage prevention is to make the shaft a harder material than the wiper hub so the hub would strip out before the spindle. i don't like this method, just make everything strong but have over current protection when the motor is locked. _________________ -dan
Posted: Fri Mar 26, 2021 10:24 am Post subject: Re: Wiper Shaft Assembly, what else will work? |
Having worked ski areas for years, I just clip the park wire on my work vehicle so the wipers will not try to run with the switch turned off. One could also add a circuit breaker to the system to break the circuit before the wiper motor got too hot. |
